My ps2 scph 90006 had no power. i think it got short. when i open to clean it i accidentally drop the screw in the top of the board of the power supply, then it spark just a little bit. then the power led light in the switch has gone. how to fix this?? pls reply
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 18 Answers
When you stoped the screw it caused some of the components to short out you can change it or get professional help to diagnose which parts went bad
Posted on Jul 12, 2019
    New Friend:
  • 88 Answers
There are tiny "in circuit fuse(s)" that most likely blew. If you know how to identify these types of fuses you can test them.
    New Friend:
    Welcome Back:
  • 16 Answers
Sorry to say it likely not fixable other then replacing the power supply or whole box. If you can see where it sparked you might be able to use solder gun to replace that part from electronics parts store. Here's a long shot that worked many yrs ago for my old similar Colecovision tv video game console. with game in and unit on, nothing on tv ... with bottom cover off exposing circuit board, I tried a large flat nail head here and there thinking it might spark it back in to action ... worked ... circled those 2 solder points to connect in future ... worked good many times then eventually was fully fried. Be sure you not grounded touching sink etc. Plus maybe avoid the thicker high voltage connections.
SOURCE:
nai6378
  • 58 Answers
SOURCE: AUS A7N8X -X Mother board AMDAthlon 27648 CPU No picture
if this is a built sustem out of the box with old monitor try another monitor oddly enough some arent compatible, you can check by looking at the prong patern.
Posted on May 10, 2008
  • 70 Answers
SOURCE: Sony PS2 SCPH-30003 No data error. PLS Help
Adjusting the white gear is usually a temp fix. If your lucky and you move it one click at a time, It'll offset to a point where it will read the discs again.
Whats happening is the drive shaft is warping. This is a very common problem in all of the ps2 units.
You have 2 options.
They sell replacement ps2 cd roms if you look around with google.
Option 2 would be purchase a new ps2. Its roughly going to cost you $80.00 US to get a replacement cd rom for the ps2. Price different for a new one would be 30 bucks or so.
Personally i'd just snag a new system. The newer one's have fixed the cd rom problem so it won't happen.
Hope this helps ya.
Posted on May 26, 2008
  • 13 Answers
SOURCE: how to open PS2 Sony cover, model is SCPh-50006
the screws are underneath the rubber feet and little plastic covers.
here's a video detailing disassembly.
PS2 Disassembly
Posted on Feb 03, 2009
  • 17 Answers
SOURCE: my ps2 slim 90006 series can't play orig dvd movies why?
its the new psp it never plays originals only originals with upgrades
Posted on Mar 17, 2009
SOURCE: PS2 power ribbon on eject/power button
http://www.youtube.com/watch?v=HdMgd0y3DIg&feature=channel_page
my video
Posted on Apr 07, 2009
Ps2 freezing games
I was experiencing the same problem on my ps2 slim scph-90004. When I put a game in my ps2 it loads but after some time it just freezes at the same spot.I went to many shops but they dont recognize my problem.Then i open my ps2 slim (Warning:Opening of ps2 my void your warranty) and saw the lens which was not adjusted. SO,if you are experiencing the same problem then use the above method(For slim only).Look at the rod near the lens which has two small clips on it. Open the screws on the clips and take out your ps2 lens.Clean it with a cotton.Set the lens in some different position and load your games .
Apr 20, 2013 | Sony PlayStation 2 (PS2) Console
PS2 is on, but no signal
The tray has become misalligned. If you want to fix it on your own heres what you do. Remove the 6 (or 8 depending on generation) screws on the bottom. Remove the warranty sticker on the back by the power switch. With the front towards you, lift the top while tilting slightly toward the front and pivoting it by the power/eject buttons. Either remove the button assembly by popping it off the lid or just be careful not to tear the cable. Remove 4 philips screws from the cd mech lid and lift off. Remove two philips screws from the tray hinge. Lift and slide tray out of front. Push white gear frame at front of tray area to the right and hold it there while you put the tray back in. Reassembly is reverse of disassembly.
Sep 13, 2007 | Sony PlayStation 2 (PS2) Console
My ps2 slim 90006 series can't play orig dvd movies why?
Mar 17, 2009 | Sony PlayStation 2 (PS2) Console
How to open PS2 Sony cover, model is SCPh-50006
PS2 Disassembly
Feb 03, 2009 | Sony PlayStation 2 (PS2) Console
Model 50001 fat ps2 cleaned the lens adjusted the arm...
If your lens is not moving up and down the track at all even in bootup then sounds like your motor is fried. What i'm referring to is this:
You can find similar parts like this .::HERE::.
To verify this, open your dvdrom tray. Power off the PS2 via the swtich on the back of the PS2 (thus leaving the dvdrom tray open) Tare down your PS2 and remove the four screws on the top of your DVD-ROM unit (if this is a fat model, if it's a slimline model you'll have to remove that whole platic piece covering the unit itself) You may have to do some research on this next part (via google) but remove your DVD-ROM tray so you can see the guts of the DVD-ROM. Then power on your PS2. And ask yourself the following questions as you observe.
1.) Does the lens move at all even right after bootup?
2.) Is the siver bar part of the motor(pictured above) turning at all to make it move?
If it doesn't turn at all then there is your problem. If it does turn, and the lens doesn't move at all then the ribbon cable that connects the lens to the board maybe damaged or the lens itself is damaged.
Hope that helps
9x|
Nov 08, 2008 | Sony PlayStation 2 (PS2) Console
PS2 Modded Trouble Reading DVDr's
Your DVD potentiometer pot on the back of the PS2 laser lens needs to be readjusted. Some people will try to tell you it's out of alignment but if that was the case it would not read CD's. Some people will try to tell you the laser lens is bad. If that was the case it would not read CD's. On the back of the laser lens are two potentiometer pots. In english? Two lil screws that are turnable. One controls the power of the DVD laser one controls the power of the CD laser.
http://www.cyber-mag.com/station/laserV9.htm
That link will give you pretty lil pictures of what i'm talking about :)
In a nut shell the story goes like this folks. If your PS2 won't read certain game DVD's that are of a certain color or if it all of a sudden mysteriously fails to read games it once read but will play cd's just fine, the voltage of the laser for DVD's is not set correctly. (this does needs manual tweeking from time to time if you take your ps2 and move it around alot or if you take it over to friends houses etc etc. Basicly alot of movment in general can take this out of alignment. Even keeping the PS2 on it's side could theoreticly (just my opinion) based on gravitational pull, unbalance the potentiometer.
RESOLUTION:
Step 1 identify your PS2 version:
Version 1 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U1"
Version 2 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U0"
Version 3 - SCPH-30001, 10 screws on bottom of case, serial no. starts with "U2"
Version 4 - SCPH-30000, 30001, 35001, 30002, 35002, 30003, 35003, 30004, or 35004, 8 screws on bottom of case
NOTE: Version 4 has 2 varieties of motherboard: Gap/No Gap, the difference between v4 "Gap" and v4 "No Gap" is the "Gap" is there's a spot in the center of bios chip where each side lacks solder points.
Version 5 - SCPH-30000R, 30001R, 30002R, 30003R, 30004R, or 30006R. Also, some SCPH-30000, 30001, 30002, 30003, and 30004 models have a V5/V6
NOTE: Version 5 & 6 - the difference between these two versions is one of the connectors in the corner.
Version 7 - SCPH-39000, 39001, 39002, 39003, 39004, 39008 or 37000
Version 8 - Only in Japanese consoles. SCPH-39000, or, SCPH-39006 (GH-022 BIOS 090)
Version 9 - if you have SCPH-50000, 50001, 50002, 50003, 50004, 50006, or 50007 you have a v9 or v10 board.
Version 10 - SCPH-5000x, with date code "3D" to the right and below the serial number on the back of the console. (GH-026 board)
NOTE: To know if its a v9/v10 start up PS2 with no game in it ,press triangle and check dvd driver version dvd ver 3.00 = v9 & dvd ver 3.02 = v10.
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find a small ''a'' under the SCPH number or have DATECODE "3C" you have a V9 PS2 main board. (GH-026 board).
If your model # is SCPH-50000, 50001, 50002, 50003 or 50004 AND if you can find DATE CODE "3D" as shown below, you have a V10 PS2 main board. (GH-026 board).
Version 12 - The new slimline PS2 consoles are referred to as PSTwo here, but elsewhere they are also known as "v12" units... their numbers are SCPH-70011/SCPH-70012, and also SCPH-70004 CB (Belgium).
Step 2 use either google or the link above. If you're using google your keyword search will be something like "ps2 v12 laser lens adjustment" *replace v12 with your ps2 model.
In either case navigate to the site and follow instructions to set the pots back to their factory default settings.
Oct 11, 2008 | Sony PlayStation 2 (PS2) Console
Playstation 2 doesnt work
You are posted in the Big PS2 section, so I hope you got a Big PS2, not a slim. If you do have a slim, I think your motherboard is shot. If you do have the big PS2, you need to open th case up and Disassemble it to find out whats wrong.  Your probably have a SCPH-50001 and when you dropped it some of the plastic inside broke.
You need to remove the 8 screws on the bottom, which are hidden by square screw covers. You can pop the screw covers up with a knife blade.  Remove the Warranty label on the cases seam next to where the power cable hooks in. Lift the case from the back slightly and pull it forward just enough to clear the CD drawer. Then roll the over cover counter clockwise being carfeul not pull reset/eject button cable loose. In this motion lay the case cover to the right side upside down.
Now remove the little screws holding the cd Drive cover on.  Yo may ned to use a screwdriver to put in the rectangle holes and pry outward to release the catch at the back of the CD drive cover.  See if you see any damage and write back a comment here . Hope this helps.
I can fix it for a reasonable price for you if you're in the USA.  www.playstationclinic.com
Oct 21, 2007 | Sony PlayStation 2 (PS2) Console
PS2 110 volts charged to 220 volts
Hello. I think is it is repairable. Please give me the model SCPH..... and I will try to help you. Best regards, Arpi
Apr 08, 2007 | Sony PlayStation 2 (PS2) Console
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
