Girbau HS-4022 shows message ERR CONF, the eprm is ok and edge connector x10 is ok any sugestions
3 Suggested Answers
SOURCE:
eradiostore
  • 1655 Answers
SOURCE: I need to know if I can fix an eprm err with the
An eeprom error can occur during programming due to several factors, it may have been as simple as a momentary glitch in the computer, radio or cable, or other unknown cause. Once you've discovered the error, you need to get rid of any saved codeplugs associated with the problem radio. You can try cloning another radio's codeplug back into the unit to see if it clears the error. If this does not work, there is nothing you can do using the CPS software to resolve the error. The radio would need to go back to the Motorola factory depot or a qualified/experienced service facility to have the error cleared and have the radio reprogrammed.
Best regards.
Posted on Mar 12, 2010
jiri_cermak
SOURCE: i can't pair my new bluetooth headset-genius (HS-905 BT) to my sony ericsson experia x10.
As of 2012: the button to hold is POWER.
1. make sure HS-905BT is off (hold Power till the blue light goes off, you hear descending sequence of tones)
2. hold Power to turn on (ascending tones, blue LED on) + KEEP holding Power till the blue LED flashes twice and you hear a double-beep. Device is ready for pairing.
Posted on Oct 12, 2012
Why does my Canon 18-55 EFS lense works ok from 24mm and upwards. From 24 down to 18 Err 99 occurs. any sugestions?
Because a circuit board has gone bad in the lens and now can't get the information it needs to the body.
Nov 22, 2014 | Canon Cameras
How can I get 6 hs-err-pid13944-Notepas deleted please?
Try going into Control Panel and find Programs and Features. See if it is listed and uninstall it.
May 24, 2014 | Computers & Internet
Girbau ms 623 lc-E
my Englesh is bad, when i start the laudry machine GIRBAU MS623, the display show ALARM U00, i need help
Jan 15, 2014 | Cars & Trucks
I can't pair my new bluetooth headset-genius (HS-905 BT) to my sony ericsson experia x10.
Jun 02, 2012 | Radio Communications
Helo ok error coming yraon last 2 days in samsung galaxy 3. of android 2.1
im also getting the same message..i think its from service provider ..wen its in flight mode this message is not displayed...im using airtel....plese post if any one found a solution
Jan 24, 2011 | Cell Phones
I have e05 message then an err 002 message, not sure how to fix. Is it possible the prongs are bent were the CF vard is input
Error 002 says memory card is full. Try to delete the card or reformat the card and observe
if camera wont allow to format the card. Try plugging it to a computer or laptop that hs Memory card slot and can read SD/MMC cards and format the card from the laptop
Jan 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
My nikkon d80 is showing err what ot do
This is a very often asked question. The answer has been posted many times on this site: The ERR message is not a good thing. Read page 132 of the D80 Manual. Also, try a factory reset found on page 129 of the manual. On the left side of the camera is the terminal cover, inside below the USB connector is the reset switch. If that does not work call Nikon digital 1-800-645-6689.
Aug 29, 2010 | Nikon D80 Digital Camera with 18-135mm...
Best regards.
Mar 12, 2010 | Motorola EM1000R Two Way Radio
Err message on heater panel
have you checked fuses? Sounds like the fuse controls the dash and the trans shif interlock. check both underhood fuse panel, and the in-cabin fuse panel.
Feb 13, 2009 | 1998 Jaguar XK8
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
