Question about LG Washing Machines
How do I reach the door lock unit in an LG direct drive 6kg front loader
  • LG Master
  • 2,500 Answers
Take top off, take control panel off, remove front panel.
Posted on Jul 13, 2019
  • Joe Strydom
    Joe Strydom Jul 13, 2019
    Thank you, was a big help!
  • HazelLDonald
    HazelLDonald Jul 18, 2019
    G­o­o­g­l­e i­s p­a­y­i­n­g 9­7­$ p­e­r h­o­u­r,w­i­t­h w­e­e­k­l­y p­a­y­o­u­t­s.Y­o­u c­a­n a­l­s­o a­v­a­i­l t­h­i­s.O­n t­u­e­s­d­a­y I g­o­t a b­r­a­n­d n­e­w L­a­n­d R­o­v­e­r R­a­n­g­e R­o­v­e­r f­r­o­m h­a­v­i­n­g e­a­r­n­e­d $­1­1­7­5­2 t­h­i­s l­a­s­t f­o­u­r w­e­e­k­s..w­i­t­h-o­u­t a­n­y d­o­u­b­t i­t's t­h­e m­o­s­t-co­m­f­o­r­t­a­b­l­e j­o­b I h­a­v­e e­v­e­r d­o­n­e .. I­t S­o­u­n­d­s u­n­b­e­l­i­e­v­a­b­l­e b­u­t y­o­u w­o­n­t f­o­r­g­i­v­e y­o­u­r­s­e­l­f i­f y­o­u d­o­n’t c­h­e­c­k i­t.
    Here .......................payshd.com
SOURCE:
  • 1294 Answers
SOURCE: LE code on LG front loader
Switch off machine, unplug, turn the heat setting on the water down. Plug it back in and select your wash setting. Good luck.
Posted on May 09, 2007
  • 351 Answers
SOURCE: LG Front Loader WD-8074FHB
sometimes you just have to force the door but first try hitting the machine near the door lock sometimes this helps the door interlock may be stuck in the closed position
Posted on Mar 02, 2008
cresguy
  • 75 Answers
SOURCE: leaking door
get a thin rubber ring of the same diameter of the door and fix it around tightly then the water wont leak out
Posted on Jul 25, 2008
  • 323 Answers
SOURCE: LG Tromm model WM2455HW front loader walks and
It should have adjustable feet with rubber pads to prevent it from walking.
Posted on May 19, 2009
SOURCE: door wont lock
door won't lock & shows d5 code what do i need to fix it?
Posted on Jun 09, 2010
LG 6kg front loader keeps beeping on pressing the power button
Try unplugging it for 5 minutes and see if it resets, if not you may have a door closed sensor issue.
Aug 18, 2016 | LG Washing Machines
Lg problem
problem with door switch bi metal,,,kindly replace door swich,
Apr 19, 2014 | LG Washing Machines
My LG WM2101HW front loader will not spin. It drains OK, but won't spin.
I would be leaning more in the direction of the door lock mechanism rather than the hall sensor as someone else posted. The hall sensor gives a very specific error code when it goes bad. Put the unit into a spin only cycle and verify that the door is locking. To do this power up the machine and only press spin speed and the start. It is also possible that it is a problem with any one of the three control boards that are on the unit but again, these normally present with very specific error codes. If the door is not locking, or even if it is but the switch isn't sending the signal back to the main control saying that it is locked then all it would do is drain and then spin 1/3 turns either way inside the tub until time runs out.
Nov 14, 2012 | LG WM2101HW 4.0 cu.ft. Washer
LG WD12020D Inverter Direct Drive 7.5kg front loader. Has never had visible water level in the drum. I have even stopped the machine, turned off the power, waited for the door to unlock, pushed the wet...
No water that high. But you may have an extra water button that allows you to add slightly more water to each wash load. Water should be just above bottom of inside drum in the back of the drum as it rotates
Jul 01, 2017 | LG Washing Machines
I have a bosch maxx Wlf1600 front loader washing machine
This will require a replacement door lock,easy replacement & part very cheap
Jun 08, 2009 | Audiovox Bosch 718 World Cellular Phone
LG Washer front loader stopped mid wash and is lock can't open door
unplug/plug unit. drain water via hose behind lower left panel on front.
Jun 03, 2009 | LG WM-0532HW Front Load Washer
Whirlpool washine machine #AWM 3082 - door wont open
Try to unplug the unit for five minutes, then plug back in. Try to start a load, as soon as the door locks agian, hit cancel. That will sometimes let you get back in. Im not sure if this is a top loader or front loader, but there is a way (if its a front loader) to remove the bottom front kick plate, then you have to reach up the inside to the door latch assm, on the bottom of that is a small round handle, pull it straight down, and the door will unlock. If its a top loader (i.e. Cabrio, Oasis, Etc), you can open the top only by unclipping the top from the base. You can do this by putting a putty knife in between the top and cabinet, then finding the clips, pushing them in and lfting, you can get your stuff out that way.
Nov 16, 2008 | Whirlpool LHW0050PQ Front Load Washer
Mar 02, 2008 | LG WM1812C Front Load Washer
Open Questions:
Washing Machines Logo
269 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
