I push the power button,screen lights up,release button screen goes black. Why?
  • Barry Kelly
    Barry Kelly Jul 12, 2019
    Hi Jack c Rodgers, I want to help you with your question, but I need more information from you. What are you pressing the power button of?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 6 Answers
What is the device you talk about sir?
Posted on Jul 12, 2019
SOURCE:
SOURCE: monitor goes black 1 second after coming to full screen
Same problem here. Does anybody have an answer?
Posted on Jul 17, 2008
jcoady
  • 79 Answers
SOURCE: hear power on, black screen. wont do anything.
Two suggestions:
Toggle the display by pressing Fn+F8 (Function key+F8). Wait a few seconds between attempts in order to allow the system to switch display ports.
Attach an external display to the system and power it on. Once you think it has had time to boot, toggle the display as described above.
Do Either displays work at any point during either test?
If no, the display chipset on the system board has failed & the system board would need to be replaced. If only the external display functions then you have a failed LCD, or the cable/connectors between the LCD and the system board are suspect.
Posted on May 27, 2009
SOURCE: Vizio 50 inch plasma tv has no picture and no
check the Y-sus and Z-sus board
Posted on Nov 02, 2009
panchal643Ja
  • 279 Answers
SOURCE: tv does not stay on, screen goes black
Checked all connection given properly checked your cable connection some time cable connection not proper than also its display no signal
Posted on Jan 23, 2010
  • 4 Answers
SOURCE: Inspiron 1525..black screen. The screen is black
or screen probably is burned...
or inside crystals are broken..
u have to buy a new laptop
Posted on Apr 11, 2010
Vizio e500ib1 50"smart tv power on light then that goes out. has 5volt stand by only, there are voltage that come up but fade out. screen is black no sound. was working great perfect picture,
Do you have voltage (3.5V) on the PSON terminal when you push the start button on the TV...if you don't its the main board that has failed
Feb 09, 2018 | Vizio Televison & Video
My green light is on but nothing is happening
is it a ps3? and is it just showing a black screen? if so you should try this, when it is off (red light is glowing on power button) push and hold down the power button when you first push it you hear a beep while you hold it down you will hear another beep when you do release the button and see if it comes on, I had the same problem and that solved it
Nov 07, 2015 | Video Game Consoles & Games
Why Screen won't respond to any touch?
Ur touch pad is gone bad get it replaced
Apr 24, 2014 | T-Mobile Prepaid Prism II
I push the power button the kocaso screen comes on and tells you injoy colorful life and then goes to a screen that said android for five or six seconds and then shuts off well it does not shut off it...
I used this link and found it had a 50/50 chance of working...
http://forums.androidcentral.com/android-4-1-4-2-4-3-jelly-bean/347622-kocaso-m1066-tablet-system-ui-has-stopped-working.html
I know it's not for your exact model, but manufacturers often have the same method of hard reset for all of their devices. Specifically:
"The button to hold down is the menu button next to the home button. With it powered on hold down tthe menu and power buttons until it goes off, then release the power button and then hold it again while holding the menu button. An android with an exclamation and triangle will appear. Tap the power button and the menu for reset or updates appears. Select factory restore and follow instructions then select reboot at next screen and you`re done."
Hope it helps u too
Chadman
Dec 27, 2013 | Kocaso M M9100 9-Inch 8 GB Tablet
Wont turn on screen remains black as in not on black and it stays this way even when plugged in
1. Push the "Power" switch downward into the "Hold" position.
2. Press and hold the "Menu" and "Record" buttons at the same time until the device resets.
3. Push the "Power" switch upward all the way to turn it back on.
OR
1. Grab a steady hold around the device.
2. Push the "Power" upward and hold it there until it powers off.
3. Power the device back on by releasing the power switch and then pushing it upward again.
OR
1. Unscrew the screws on the back of the device (or simply push the lid off if it is a model without screws.)
2. Take out the batteries from the slot and wait until the screen goes black.
3. Insert the batteries the same way they were mounted and attached the lid again.
4. Push the power switch upward to turn on the device.
Sep 30, 2009 | SanDisk Sansa e250 MP3 Player
It doesnt turn on just the blue light on the wheel
OR
OR
Sep 29, 2009 | SanDisk Sansa View 8GB MP3 Player - Black
My hp 3310 wireless printer freezes and displays a blue screen (on the printer) with alpha numeric characters
Hi
Try resetting the printer
POWER DRAIN:-Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON buton for 30-60 seconds.
PARTIAL RESET:-Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait untill the ON light flashes, then release the buttons.
----(for below reset cartridges must be removed out)---------
SEMI_FULL RESET:-Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait untill the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off dont worry release the button and Push the ON button.
FULL NVM RESET:-Take the Ink Cartridges out, Unplug the printer power cable while its ON, press and hold OK and CANCEL button and connect the Power cord while holding the buttons.keep Holding the buttons until the printer goes off ,release the button and Push the ON button.
(Notes - resets will take a while)
Thanks
Riz
Dec 29, 2008 | HP Photosmart 3310 Printer
The machine is frozen, can it be fixed or time to replace?
Hi
We need to reset the printer, please follow the below steps to resolve the issue.
POWER DRAIN:-
Turn off the printer, Unplug the power cable from printer and from the wall outlet.Press and hold ON button for 30-60 seconds.
PARTIAL RESET:-
Unplug the printer power cable while its ON, press and hold # and 3 button and connect the Power cord while holding.Wait until the ON light flashes, then release the buttons.
SEMI_FULL RESET:-
Remove the ink cartridges, Unplug the printer power cable while its ON, press and hold # and 6 button and connect the Power cord while holding.Wait until the ON light flashes,or wait for 20 seconds,hen release the button.If the printer goes off don't worry release the button and Push the ON button.
FULL NVM RESET:-
Thanks
Riz
Dec 29, 2008 | HP OfficeJet 7310 All-In-One InkJet...
Screen goes black...
possible memory problem
Nov 21, 2008 | Computers & Internet
Power lead
The Switch is non-powered except by the board.
Black should go to power or + side
It's like a wall switch for the light (power comes in on one side and out on the other) If it were a push in to a detent (like the Old 386's and 486's with AT power supply) to connect and a push in to release the detent it would make a difference. With these power buttons on the cases now, it doesn't.
Apr 19, 2008 | MSI K9VGM-V Motherboard
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
