Question about Canon Office Equipment & Supplies
My canon iR3300 is displaying error code E000580-0000 please help me
  • Alex Walker Fixya Expert
    Hi Atta Asirifi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    and Send Email us on livehelp987@hotmail.com
    Master:
  • Canon Master
  • 836 Answers
That error indicates there is a malfunction in the finisher unit .
Posted on Jul 13, 2019
SOURCE:
SmartFix
  • 89 Answers
SOURCE: what is error code e000014-0000 on canon IR3300
This error is idicating that the fuser motor is not turning. Rotate the green fuser knob to see if it is hard to turn. If freely turning then a gear, motor, or DC Controller board is bad. If hard to turn then try to find what is keeping it from turning. The motor Assy is behind the cover right next to the fuser knob. Good Luck.
Rate my response!! Thanks, SF
Posted on Jan 28, 2010
SOURCE: Canon IR3300 showing the error code E000602-0003
ERROR CODE E000602-0003 what i do
Posted on Feb 08, 2010
canontech
  • 1219 Answers
SOURCE: error code e000733-0001
E733
0001 A fault is detected by the main controller PCB in the communication between
the DC controller PCB and the main controller PCB.
Main cause The connector has poor connection. The DC controller PCB is faulty.
Action
1. Connector, DC controller PCB
Is the connection between the connector J1015 on the main controller PCB
and the conductor J316 on the DC controlled PCB normal?
NO: Correct the connection.
YES: Replace the DC controller
Posted on Apr 30, 2010
  • 89 Answers
SOURCE: canon ir3300 is giving me error code E6002-0003, h...
Turn off the copier using the power switch on the right. Turn it on again holding 1 and 9. You should see rectangles on the screen. Once this is finished the copier should be in download mode (If this process hangs or doesn't get started the disk will need to be replaced by a tech). Once you reach download mode you'll need a tech to flash the hard disk to get the copier going again. If this doesn't work, the hard disk will need to be replaced. In any case your hard disk is dying and will need to be replaced soon.
Posted on May 24, 2010
  • 23 Answers
SOURCE: what is canon iR3300 error
Hold down the 1 & 9 buttons on the keyboard and
turn the machine on using the switch on the side of the machine
hold down the buttons till the screen goes black a white square appears now take you fingers off and let the machine run untill the screen is filled with the white boxes. turn of and on and hopefully that will fix it. the error is caused but the hard drive being currupted. if this does not fix it then the hard drive needs to be replaced by a canon service agent.
Posted on Nov 01, 2010
When the Canon IR 3300 switchs on it displays the Error code E000602-0003 please help me what to do
This error belongs to the Hard disk of the copier. Please re-install the system software in HDD or replace the HDD with new one.
Oct 08, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
How do i solv error 100 code in canon ir3300
Hi Raj
please follow link it will give you all the error codes and also will tell you what your one is..hope this helps
Dec 23, 2014 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Error occur led displayed *E000261-0000
canon ir3300 E000261-0000 code solution please
Jul 27, 2012 | Canon Office Equipment & Supplies
I am getting the error E00007-0000 on the display of my Canon iR3300 printer.please advise how to solve the problem
Aug 29, 2010 | Canon imageRUNNER 3300 All-In-One Laser...
My canon ir3300 screen is showing E602-0001
Hello sir; The error code you display it means " hard disk" problem go to replace one.
Oct 11, 2009 | Canon Office Equipment & Supplies
How to rectify the continious error in copier IR3300 canon
the last error generated is from the fixing unit you have to clear the error again,but if this error code (Error 003) returned a thorough check on the fixing unit is needed.Or could be the AC supply to the machine is not stable.Go to program mode got o display> analog check the fuser/fixing temp hope this will help
Jun 30, 2009 | Canon Office Equipment & Supplies
My canon iR3300 is displaying error code E000002-0000. Please help.
My canon iR3300 is displaying error code E000003-0000. Please help
Jul 30, 2008 | Office Equipment & Supplies
18 people viewed this question
Clive
Clive
old marine
old marine
