Question about Toys
What controller works helicopter T-6 gallant tier one
Skygiant rchelicopter when i sync it and then give it throttle all the lights on the helicopter syart flashing red and it dosent do anything
I bought 2 off brand ,of the same remote controlled Helicopters which cost about $30.00 each. The controller has A_B_C setting helicopter has none, You can set them up any way, either all on one or separate channels per controller which is channel A.
1st turn off Helicopter switch to off and controller off .
Set controller -1 to channel C , , then (controller-1 ) throttle knob to max, turn power on to controller -1 , throttle down and up 3 cycles and left and right 3 cycles
Turn on Helicopter 1 with controller -1 still on, it should work on channel C
Jun 11, 2014 | Team International Hawk Talon V3 RC Indoor...
Just purhased two Tier-One Gallant helicopters. They say they are 3 channel. I see no channel selectors on remote or helicopter. I want to fly two of them but don't think I'll be able to unless I have them...
You cannot easily change the frequency these helicopters operate on, they are not designed for multi channel use. To change their operating frequency you would need to find and replace the small crystal inside the helicopter and also inside the remote control.
The 3 channel you are referring to is the number of functions (channels) you can control on the helicopter, not it's frequency channel.
Dec 31, 2013 | Air Hogs Havoc Heli Helicopters
Do the helicopter itself have a on/off switch..tech-one gallant
After fights between teh kids (he's crashing my helicopter) I think I figured it out. The instructions says to select the frequency on the helicopter, but there is no switch. When you first bring up the helicopter and controller, sometimes the green light on the controller blinks a few times. That is it synching up with the helicopter. After you charge the helicopters, turn then both off, Then turn on one helicopter and one controller. The key is when the green light above the one off switch is blinking. I did it with trial and error, so I am not sure exactly how to get it in the mode where it is in pairing mode. RIght now I am reluctant to mess around with it because they are set correctly and the kids are playing with them. I will post later if I figure out the exact sequence for getting them in pairing mode
Dec 26, 2013 | SYMA Toys industrial New Syma S107 Radio...
Sanhaun 6050 helicopter manual
dear sir i need sh-6050 heli menual
Dec 25, 2013 | Falcon Radio Rc Helicopter
I got a tier-one viva helicopter for Christmas. There was no owners manual in the box and only a USB cable for a charger. I have tried to charge the device but am getting no response from the copter. Any...
i have one to first time i got it it did work when i tried charging it it didnt work i guess its the battery or the rotors maybe usb trust me i work for that company take it to where you got it or buy a battery to replace the evo t1
Dec 25, 2012 | Toys
How do you charge the iwave helicopter?
In the controller unit (the controller holds the 6 AA batts) there is a compartment just under the green charge light. Open the compartment by sliding the compartment door down in the direction of the arrow. This will expose a wire with a white plug on the end of it. Insert this plug into a socket found on the underbelly of the helicopter next to the on/off switch. On the controller, turn the switch to the 'on' position. The red and green light on the controller will light, indicating it's charging. After about 15 minutes, the green light will go out, indicating that the helicopter is fully charged.
Dec 26, 2010 | Jumbo RC JUMBO HELICOPTER
I have 3 s107 and I it says 3 channel on the box and the transmitter says A B C but will only let me select 2 of them. What's the trick on flying 3 at the same time?
Mine's exactly the same as yours. Although the transmitter shows A B C the switch has only two positions, so there's a choice of two only. I doubt it's possible to fly 3 at the same time.
Nov 08, 2010 | SYMA Toys industrial New Syma S107 Radio...
Purchased Helicopter MINI AIR WOLF Model UJ417. from RiverCenter Mall vendor in San Antonio, Texas 3 days ago, while on vacation...live in kansas.Hope i didn't get scammed. Vendor never said it would only...
My wife bought one of thsoe for me for my birthday. I charged it for an hour - turn off the helicopter power switch and plug in the charge plug on the control - the control must be on. anyway the thing doesn't have enough lift to get off the ground. It just skitters along the ground. Also the tail rotor doesn;t do anything. The parts list identifies a tail motor so it should do something. Going to return it to the mall. That's a hassle! I would try to fix the tail motor, but if the thing can'e even get off the ground what's the point? Any info send it to rsockey at yahoo dot com.
Sep 01, 2010 | Toys
Toys Logo
16 people viewed this question
Top Toys Experts
Marvin
Marvin
Andrew Taylor
Andrew Taylor
ray gallant
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
