Question about Cell Phones
Won't hold its charge
I charge it fully and in about 5 minutes it looses its charge
    Top Expert:
  • Cell Phones Master
  • 21,945 Answers
Battery failure
Posted on Jul 12, 2019
    Master:
  • 520 Answers
Time to replace battery. All kinds have limited life span
  • 1,123 Answers
Then it is bad as there is a short in the battery. It needs to be replaced.
5 Suggested Answers
SOURCE:
SOURCE: Battery will not hold a charge
I had the same problem and then went to the website to find that you have to have the off/on switch in ON position. This solved it for me. Hope it's that easy for you too!!!
Posted on Aug 19, 2009
AndrexT
  • 27964 Answers
SOURCE: doesnt hold charge
The battery is worn out. You need to return it to the manufacturer so they can install a new one. Even rechargeable batteries wear out eventually. If they are in constant use, discharge/recharge, you can reckon on 5 years. If they are left for long periods discharged, or not used, then the life reduces dramatically.
Posted on Dec 05, 2009
leepania
  • 1099 Answers
SOURCE: will not hold charge. put in new battery and fully
How long have you had your dock and batt.?
They might be in a need of a change.
Here are the steps:
1. Clean the battery contacts.
a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth.
b. Reinstall the battery/batteries into your camera
2. Turn on your camera without the memory card.
Posted on Mar 13, 2010
johnestan
  • 5 Answers
SOURCE: my 3ds won't turn on and it fully charged
You probably have a blown fuse. Here is a video showing how to fix it. If you are not confortable doing the repair send it to nintendo to fix it.
Posted on Oct 18, 2012
Battery will not hold charge
you need a new battery. It is possible that the battery may be fried.
Aug 20, 2017 | Black & Decker Garden
Zeki 10" tablet won't load
Hi, Is your Zeki fully charged? My suggestion is to hold the on/off button for a few secs. to fully power down. Put it on the charge and let it fully charge before trying it again. Then try turn it on again.
Feb 18, 2013 | Shopnbc Zeki 10" 8GB Android 4.0 Ice Cream...
Phone won't turn on
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Aug 26, 2012 | Motorola Cell Phones
Electric lawnmower battery won't hold a charge
charger for same does not show any lights..so should i assume the charger is not working?
Apr 28, 2012 | Electric Lawn Mower
1994 Cadiallac Deville won't start because of theft system
Unhook battery, let sit for 5 mins and hook back up.
Apr 01, 2012 | 1994 Cadillac DeVille
Fully charged battery not holding for a full day
If the cell phone battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Dec 05, 2011 | Samsung Cell Phones
TomTom will not turn on its fully charged
Try to do a "Boot" .... by pressing and holding down the ON/OFF button for 5 seconds (or a lot more) until the device powers on again. Yes, at times, it may take a minute or more ! of holding that button down.
Sep 05, 2011 | Tomtom GO 700 GPS Receiver
My dewalt 18v xrp battery wont take a charge
Depending on how old or more to the point how many times you have already charged the battery, it may be worn out. All rechargeable batteries do reach a point where they won't charge up anymore. If you have fully discharged the battery and tried to fully charge it up again and it won't take a charge or only lasts a few minutes on a charge it may be time to recycle it and buy a new one.
Aug 22, 2011 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
The car is not holdong a charge. I replaced the Battery about a year ago. Today I replaced the alternator. I used jumper cables it ran for about 20 minutes and then died again. All the wires look good. Any...
FIRST, YOU MAKE SURE THE BATTERY IS FULLY CHARGED.. A GOOD BATTERY WILL GO FOR 12 HOURS EVEN IF THE ALTERNATOR IS NOT WORKING.. SECOND YOU TURN THE CAR ON.. ONCE THE CAR IS ON. YOU DISCONECT THE BATTERY,, IF THE ALTERNATOR IS GOOD , THE CAR SHOULD REMAIN ON WITHOUT A BATTERY.. IF IT SHUTS DOWN , YOU HAVE A BAD ALTERNATOR OR THE WIRING IS WRONG ONE OF THE TWO.. SHORTS ON YOUR WIRING CAN CAUSE THE BATTERY TO LOOSE POWER.. BUT NOT THAT FAST. BECAUSE IF THE SHORT WAS TO SERIOUS.. YOUR WIRING WOULD BE BURNED.. COMPLETELY..
IF THE ALTERNATOR IS OKAY,, REPLACE YOUR BATTERY,, MOST OF THE TIME BATTERIES GO BAD EASY WITH ANY LITTLE PROBLEM THE CELLS BURNOUT AND THEY DONT HOLD A CHARGE EVEN IF FULLY CHARGED THEY WILL LOOSE POWER IMMEDIATELY .. I THINK THAT IS YOUR PROBLEM.. SINCE IT ONLY LASTED LIKE 20 MINUTES.
Dec 14, 2010 | 1996 Isuzu Rodeo
Cell Phones Logo
Top Cell Phones Experts
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
