I need to know the screw size that attaches the bracket on the back of the tv to the wall mount for product number ONA16TM011E
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 57 Answers
VESA Specifications
VESA STANDARD HOLE PATTERN SCREW SIZE MONITOR WEIGHT SCREEN SIZE FDMI MIS-B 50 x 20 mm M4 x 6 mm ? 4.4 lbs / ? 2 kg 4" to 7.9" FDMI MIS-C 75 x 35 mm M4 x 8 mm ? 10 lbs / ? 4.5 kg 8" to 11.9" FDMI MIS-D 75 x 75 or 100 x 100 mm M4 x 10 mm ? 30.8 lbs / ? 14 kg 12" to 23.9" FDMI MIS-E 200 x 100 mm M4 x 10 mm ? 50 lbs / ? 23.7 kg 24" to 30.9" FDMI MIS-F 200 mm increments M6 x 8 mm or 10 mm;
M8 x 15 mm ? 250 lbs / ? 113.6 kg
Posted on Jul 12, 2019
SOURCE:
  • 3 Answers
SOURCE: Tv didnt come with screws....
The size is #8-40 X 3/4". This is a specialty screw, so you're screwed
Posted on Dec 13, 2009
SOURCE: I recently purchased a LN52A550P3F
had the same problem. I went to bestbuy and they gave me the four screws and plastic spacers needed free of charge yesterday...
Posted on Nov 29, 2008
  • 5 Answers
SOURCE: PROTRON STAND
Is that a problem? Check the hole size and choose a screw with a head that is bigger than the hole size. Typically select a minimum of 4mm diameter screw.
Posted on Jun 10, 2008
  • 330 Answers
SOURCE: Mounting Th-42PX75U
1/2"
Posted on Jul 10, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: What is the screw hole size in back of tv
The screw holes are metric. The set is supplied with M5x25 screws to attach the pedestal, so the wall mount screws will be in that same range.
Posted on Mar 01, 2009
I have a Samsung UN32M530D smart TV that I want to mount on the wall. The 4 holes at the back of the TV are smooth and do not have threads for screws. How do I attach the TV to the wall mount?
You can check https://www.primecables.com/c-18871-mounts-sit-stands for mounting sets or standing desk to your Smart TV. I got a standing desk there and going to mount it soon. It's much more comfortable then to use a simple wall mount.
Oct 31, 2017 | Samsung Televison & Video
Can my tv be wall mounted and is there a special kind of wall mount
Check Walmart , all types / sizes of Wall mounts available
Mar 16, 2015 | Televison & Video
I own a Samsung DLP 56" TV for which I purchased a swivel wall mounting bracket that holds up to 160 Lbs of weight. However when looking at the back of the tv set and the such smal size screws that...
Yes it will hold,the wall mount u bought it design for weight of 160 LBS and 50"-60" screen sized right?Just make sure hook up the wall mount on and over a wall area with strong woods beams supports have many fours by fours woods beams lumbers to take off the stress of the holding of the tv by those screws alone of the screen frame screws supports only.
Jun 30, 2011 | Samsung HL-T5676S Television
Hi I have a digimate tv model modl lt321c2m1 and I am wondering if I can mount it on the wall. Can I?
Please look on the back, there should be 4 mounting holes (for Metric screws) Iin what is called VESA mounting pattern. Just measure the pattern.
http://en.wikipedia.org/wiki/Flat_Display_Mounting_Interface
When you buy the mounting bracket, it will come with a bag of Metric mounting screws to attach your TV to the bracket.
Jun 13, 2011 | Digimate DGL32 32 in. LCD Television
HI , I'm looking for the size of the mounting bolts that would be required to mount a 32 inch Sony LCD TV.
If you are talking about the mounting screws that go into the back of the television to mount a VESA sized wall bracket, then it's most likely 5mm screws. The length of the screws could differ, depending on the bracket you are attaching, but usually 12mm or 16mm can be used. just make sure that the screws are long enough to thread into the TV completely, but not too long, or they may damage internal components.
If you are talking about the Lag screws needed to mount the bracket to the wall, then use 3/8" width lag screws 2 1/2" to 3 1/2" long, depending on how deep you have to go before hitting the wood stud.
Apr 03, 2011 | Televison & Video
Can't find screw size to fit back of my 42in Toshiba Regza. I want to mount on wall. Screws that came with the 42in wall mount don't fit it. It's not a 5/16, 6mm, 8mm fine thread or course thread
M8 - according to a document I found online for a Toshiba mounting bracket kit for their LCD TVs the bolt size is M8. It should be easily available in a large hardware store or place that sells large flat screens.
Make sure you hand tighten it into the mounting hole before attaching any brackets, to judge the proper depth for tightening. Over-tightening with a long bolt could damage the TV.
Dec 19, 2010 | Toshiba REGZA 46RV530U LCD TV
LG 42" wall mount screw size
Metric M5 or M6, when you buy wall mounting bracket, it will came with a bag of screws for attaching the TV to the bracket. All my wall mounting brackets for my TV come with screw.
http://s807.photobucket.com/home/budm/allalbums
Jul 01, 2010 | Insignia LCDTV26 26 in. Television
Mar 01, 2009 | Panasonic Viera TH-42PZ80U Plasma TV
How do i attach a Wall Mount to the TV?
Hi, Ok, great.Look at the back panel and you can see four holes spaced 4" between the top and bottom, and 16" from side to side. these are for universal mount. http://www.bestbuyplasma.com/Plasma/tvmounts_land.asp I think this clears your problem regards sreejith "Please use caution if wall mounting this product. Follow all directions from the manufacturer of the wall mount and be sure to securely fasten the product to the mount. While the TV can be wall mounted, improper wall installation may void the warranty."
Jul 16, 2007 | Akai LCT3285TA 32 in. LCD Television
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
