Question about The Computers & Internet
How do you transfer info from regular lock box to the pro version?
How do I get 1990 Suzuki Escudo out of 4wd
I'm not sure if you are suffering 'wind-up'.Does your car seem to suffer a huge loss of power? If so, then try jacking up one wheel off the road.
Does the wheel spin around once it leaves the road surface? If so, then you just suffered 'wind-up'. That vehicle is not meant to stay in 4 wheel drive if not on mud or slippery surfaces. This will eventually cause catastrophic failure of the transmission, usually resulting in a smashed transfer box chain.
Once any 'wind-up' has been dealt with having released it from jacking one wheel off the ground, then select 2wd and road-test the vehicle. It should now be fine.
If the vehicle still won't deselect from 4wd, then you will need to check the transfer box for fault.
The transfer box and gearbox oil should regularly be checked for any signs of oil cross-contamination. There is an oil seal between these two boxes, and which keeps their respective oil from leaking through to each other's boxes. If your transfer box oil is reddish in colour, or shows a large excess of oil when removing the oil top up bung, then you likely have an oil seal issue.
Typical issues on that particular model are:
Transfer box chain failure.
Transfer box [internal] oil seal leakage.
Other things to keep an eye on with that particular model are:
Power steering pump oil seal.
Front wheel bearings. (increased failure when fitting wide profile tyres).
Steering track rods and track rod ends.(increased failure rate when fitting wide profile tyres)
BE AWARE!
Easy entry/break-in method: Remove right, rear light cluster with philips screwdriver. Using bobby pin or short wire, randomly short circuit visible wires within connector block until central locking automatically opens door locks.
Oct 30, 2012 | Cars & Trucks
When I go to scan to the computer, I get an error message no scan options, it has worked before, I did have a new hard drive put into my mac, what can I do to get it to work,
New hard drive sounds like the "HP Printer Prog" is corrupted. If you have transfered all data from the old to the new there is a possiblity it failed to transfer all info.
Save yourself time, unistall and reinstallthe complete version from www.hp.com downloads, your mac version printer prog.
Good luck
Peter.
Feb 20, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
Error C500.
PROBABLE CAUSES:
1. Insufficient airflow during idle causing internal machine temperature to rise. Toner is backing up or solidifying in the cleaning unit box for the transfer belt causing the transfer belt drive motor (M18) to bind.
Replace the Belt Cleaning Unit (p/n 65LA R702 00) and install attached Special Printer Control firmware (version 51-PBF0 for the 8050/CF5001 and version 12-PBF0 for the bizhub PRO C500). This firmware keeps M11 (Transfer Belt Cooling Fan) ON for a period after the copy process has completed which helps keep the internal temperature at normal levels. The firmware can also be download from the Konica Minolta Download Selector. Access the Selector from SSD Web Support (CS Expert Support) by clicking on 'Download MSDS, Drivers, Firmware and more'.
Note: Firmware version 51-PBF0 is primarily for the 8050, but can be used for the CF5001. When using the ISW tool to download the firmware please select the 8050 from the drop down. If the CF5001 is selected the ISW tool will not see the file.
2. The paper exit fans (M61/M62/M63) DIPswitch is not turned ON.
Set software DIPSW 21-0 = 1 to enable the paper exit fans.
3. Dirty or failed transfer belt drive motor encoder disk sensor assembly.
Clean the transfer belt drive motor encoder disk and sensors. Replace the assembly (p/n 65AA -909 1E) as necessary.
4. Failed M18 transfer belt drive motor.
Replace M18 transfer belt drive motor (p/n 26WA 8001 3).
Jan 18, 2011 | Office Equipment & Supplies
I loaded the v scanner into my pro 96 I guess the info was previously deleted and now all the channels are locked and I don't now how to get back to regular use of the scanner
Hi, my name is John. Welcome to FixYa. All you have to do is press the HOLD button, then press the FUNC button, then press the LOCK or L/O down until it beeps twice and that's it...enjoy. Thanks for choosing FixYa....John
Nov 19, 2010 | Radio Shack Pro-96 Scanner
Nikon transfer download problem
You need to manually register the DLL, by following the instructions at this URL:
http://ss64.com/nt/regsvr32.html
You will be using REGSVR32. You may need to unregister the DLL first, then Register it from scratch.
-a.
May 29, 2010 | Cameras
Baby Lock Embroidery Sewing Machine "ELLURE" Model ESL- Problem: Defective Embroidery Memory Card (part#35205-4) used with the "PTS BOX" and the Palette Ver 1.0 Software Program to transfer embroidery...
I had the same problem and after buying a new card, found out that you get that message if the pattern you are trying to transfer is too big. reduce the size of the pattern and see if that works
Jul 11, 2009 | Baby Lock Ellure
Ne macbook pro locks up
Hey amandarx8,
That really is not quite enough information to go on. What version of the Mac OS are you using? What MS Office application are you trying to use? Are you running any other applications at the same time you are running the MS Office application? This info will help diagnose your problem.
But to answer your question, lock ups are NOT normal. Make sure you have downloaded and installed any updates from both Microsoft as well as Apple.
You might also try this site for help-
http://www.microsoft.com/mac/help.mspx
Jun 16, 2008 | Apple MacBook Pro Notebook
Loading songs - format message
if you've used wmp to rip and encode the cd to the wma file standard, the ipod won't play them. the ipod doesn't support wma or ogg vorbis (and doesn't support the pro part of mp3 pro) you need to encode your files to either mp3 or aac (or leave them as wav files, though these are very large) for the ipod to play them. this may be causing the mmjb transfer problems.
check out the software compendium on info on alternatives to rip, encode and transfer to the ipod.
Jan 09, 2008 | Apple iPod shuffle MP3 Player
Open Questions:
Computers & Internet Logo
14 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
