Mon lecteur hs-150 fonctionne juste quand connecter a l'ordinateur. 20 heures d'usure. que faire merci
  • Alex Walker Fixya Expert
    Hi nicole cyr, I want to help you with your question, but I need more information from you. Please Call customer Support Call 1 8O5*465*751O Toll Free 24x7
  • Computers & ... Master
  • 5,040 Answers
Ok French posting to USA forums and not english
translated
for free
My hs-150 player works just when connecting to the computer. 20 hours of wear. what to do thanks
so what is wrong, no problem stated by you.?
you said PLAYER but not what MEDIA it PLAY
are you talking some old Vinyl records 16,33/45/78 RPM
that?
made in 1974 by old famous Co. called DUAL ?
Model: HS150 - Dual, Gebr. Steidinger; St.
if yes it has its own twin speakers, are those missing>?
I give up there are like 20 DEVICES with your too short name.
mp3 players,
DVD drive players.
https://www.manualslib.com/products/Harman-Kardon-Hs-150-1860146.html
endless HS150 , surly you can photo it and post it or
tell what it plays, or use the full makers name.
or google find a picture of it in 10seconds work
and post the link to it?
sure.
Posted on Jul 14, 2019
SOURCE:
  • 281 Answers
SOURCE: technics sd-s2300 ampli su-g91
tu dois voire si tu as tout les cables entre sur le stereo
Posted on Feb 18, 2008
joecoolvette
  • 5660 Answers
SOURCE: Mon laptop toshiba satellite A 105 ne s'allume plus.
It may not be the AC adapter. It may be the DC Power Jack is bad. This is round port, where you plug the AC adapter (Charger) into the laptop. Happens to a lot of Toshiba Satellite A105 laptops.
Posted on Apr 26, 2009
  • 124 Answers
SOURCE: bonjour ma xbox 360 clignote rouge( 3 LED) et ne
e74 ou erreur de rrod signifie qu'il y a une issue de matériel. Ce que vous devez faire est une réparation très simple et bon marché. regardez sur ebay pour des kits de réparation de bride de x, ce sont juste quelques mâles et la plupart des vendeurs incluent un bon guide dans la façon faire le mod/difficulté. ce qui cause le rrod ou l'erreur e74 est la bride de forme de X sur le dessous ou le conseil de mère se pliant et mis-formant entraînant la boule soudant sur le gpu/unité centrale de traitement légèrement fondant et formant des fissures de délié dans la soudure. Le kit de x-bride s'appliquera plus de pression au gpu/unité centrale de traitement et tour de déconnecter les ventilateurs et d'allumer le xbox et de lui permettre de surchauffer au sujet de la fonte les joints à rotule de soudure remplira fissures de délié. Selon quel morceau est l'issue vous peut également avoir besoin des 2000 pistolets de chaleur de watt au lieu d'employer la méthode de chauffage finie (le morceau de gpu). Le remplacement des garnitures de la chaleur sur le radiateur par la pâte thermique qui vient avec le kit gardera le refroidisseur du gpu/unité centrale de traitement et vous n'aura pas cette issue encore. Assurez-vous svp que vous achetez le kit qui vient avec les rondelles en nylon soumises à un traitement thermique pendant que les lavages en acier de ressort échouent !. Les prises de réparation environ 1-2 heures J'espère que ceci vous aide dans la fixation xbox J'ai dû utiliser un traducteur d'Internet pour traduire l'anglais au frech ainsi à moi appologise pour n'importe quoi non traduit correctement
Posted on Nov 08, 2009
  • 8081 Answers
SOURCE: Comment puis-je changer l'heure
  1. Alllume ton GPS.
  2. Tape quelque part sur l'écran. Des icônes apparaissent.
  3. Cherche celle en dessous de laquelle est écrit 'Change preferences'. L'icône en question représente une clef plate (de mécanicien) .
  4. Tape l'icône pour changer la configuration.
  5. Utilise la flèche qui pointe à droite. Continue jusqu'à ce tu parviennes à la page où il y a l'icone d'une horloge (réveil-matin).
  6. Tape cette icône.
  7. On te demandera de choisir entre la représentation de 24 h (18) ou 6 pm. ou 6. Choisis ta représentation horaire.
  8. Dès que tu appuies sur Done, l'écran change et on te demande de régler l'heure.
  9. Tu as des flèches vers le haut et des flèches vers le bas. Deux flèches pour changer l'heure et 4 flèches pour changer les minutes.
  10. Tu peux même synchroniser l'horloge sur les sattelites en appuyant sur sync.
Posted on Jul 20, 2010
FSAhead2
  • 214 Answers
SOURCE: mon Lecteur MP3 Apple iPod classic 80GB ne fonctionne pas
Réinitialiser Pour réinitialiser votre iPod: * 1. Basculer le commutateur Hold sur et en dehors. (Positionnez-le sur Hold, puis désactivez-le à nouveau.) * 2. Appuyez sur la touche Menu et du centre (Sélection) simultanément sur les boutons jusqu'à ce que le logo Apple apparaît, environ 6 à 10 secondes. Vous devrez peut-être répéter cette étape.
Astuce: Si vous éprouvez des difficultés de réinitialiser votre iPod, placez-le sur une surface plane. Assurez-vous que le doigt qui appuie sur le bouton de sélection ne touche une partie de la molette cliquable. Vérifiez également que vous appuyez sur le bouton Menu vers l'extérieur de la molette cliquable, et non vers le centre. * Si les étapes ci-dessus ne fonctionne pas, essayez de connecter l'iPod à un adaptateur secteur et branchez l'adaptateur dans une prise électrique, ou connectez l'iPod à votre ordinateur. Assurez-vous que l'ordinateur est allumé et qu'il n'est pas d'aller dormir.
Si ce permis de résoudre votre problème, vous avez terminé.
Si ne pas essayer cette
Si ne pas essayer thisRetry votre iPod avec un autre port USB de votre ordinateur, pas un port USB de votre clavier ou un concentrateur.
Si ne pas essayer ce redémarrage Redémarrez votre ordinateur et assurez-vous que vous avez le logiciel dernières mises à jour installées. Note: * Pour mettre à jour vos logiciels Windows, sélectionnez Windows Update dans le menu Outils d'Internet Explorer. * Pour mettre à jour vos logiciels Mac OS, sélectionnez Software Update dans le menu Pomme.
Réinstaller * Pour mettre à jour et réinstaller votre logiciel de l'iPod, commencez par télécharger la dernière version d'iTunes. * Ensuite, ouvrez la nouvelle version d'iTunes et connectez votre iPod à votre ordinateur. * Sélectionnez votre iPod dans la liste Source et cliquez sur "Vérifier les mises à jour" sous l'onglet Résumé. iTunes vérifiera si votre iPod doit être mis à jour et effectuer la mise à jour pour vous. * Si cela ne résout pas le problème, essayez de désinstaller complètement iTunes et de réinstaller la dernière version d'iTunes.
Restaurer * Note: étant donné que la restauration efface l'ensemble des morceaux et des fichiers sur l'iPod, assurez-vous de sauvegarder tous les fichiers que vous avez enregistrés sur le disque iPod. Toutes vos chansons, vidéos, podcasts, livres audio et jeux peuvent être chargés à votre iPod à condition que vous les avez stockés dans votre bibliothèque iTunes. Comment faire pour restaurer votre iPod: * 1. Assurez-vous que vous avez réinstallé la dernière version d'iTunes. * 2. Ouvrez iTunes, puis connectez votre iPod à votre ordinateur. * 3. Après quelques instants, il apparaîtra dans la liste Source dans iTunes. Si l'iPod d'affichage ne montre pas les «Connecté» ou «Ne pas déconnecter" vous pouvez avoir besoin de mettre l'iPod en mode disque pour continuer. * 4. Sélectionnez votre iPod dans la liste des sources et vous verrez informations à ce sujet figurent dans l'onglet Résumé de la fenêtre iTunes principal. * 5. Cliquez sur le bouton Restaurer. Vous serez invité avec des options de restaurer un ou plusieurs qui peuvent rapidement iTunes pour télécharger automatiquement de la dernière version du logiciel iPod. Les 4 options de restauration possibles sont:
Si cela ne résout pas votre problème, alors vous pourriez essayer d'appeler l'assistance Apple
Posted on Aug 20, 2010
Mon tapis roulant sportcraft tx390 ,a commencer a sentir le brule 3 jour apret que jais du ajuste mon tapis car il avais tendense a bouge sur la droite et frote donc jais fait un ajustement et cest...
bonjour, quand je fais partir mon tapis roulant il fonctionne pendant quelques seconde, ensuite le chiffre ( 3 ) s`affiche dans le coin gauche et il cesse de fonctionner, pourriez-vous m`aider? Merci
Apr 12, 2012 | Cars & Trucks
Ne trouve pas le pilote du dvd ram gt 31n le mien ne fonctionne plus
QUESTION: "can not find the driver dvd ram gt 31n mine no longer works"
Salut.
Il n'est pas clair ce que vous entendez par "DVD-RAM 31n GT." J'ai fait des recherches de ce numéro de modèle "GT 31n", sans succès. Je vais donc supposer que c'est le numéro de modèle du lecteur de disque optique interne (DVD-RAM) de votre ordinateur.
Vous ne dites pas quel système d'exploitation que vous utilisez. Vous avez également choisi de ne pas donner toutes les informations concernant votre ordinateur ou de ses spécifications. Ces aurait pu avoir été des éléments d'information utiles.
Presque chaque système d'exploitation informatique, en particulier les courants, ne nécessite aucun pilote supplémentaire pour les lecteurs optiques comme celle du lecteur DVD-RAM. Les pilotes pour fonctionner presque chaque lecteur optique sont déjà intégrés dans le système d'exploitation.
Le seul logiciel que vous pouvez télécharger pour ce lecteur optique est Firmware. Firmware améliore et renforce les spécifications de performance, mais on peut rarement réparer les défauts ou restaurer un disque optique non-fonctionnement d'une fonctionnalité normale avec Firmware.
Vérifiez l'étiquette pour le fabricant du lecteur. Il est susceptible d'avoir été fabriqué par l'une des entreprises connues pour ce produit (LG, Sony, Hitachi, Samsung, etc.) Allez sur le site Support et Téléchargements de cette entreprise et vérifiez les mises à jour du Firmware associés à ce lecteur optique et de votre système d'exploitation.
Je suis presque certain que peu importe où vous regardez, vous ne trouverez pas de pilotes pour ce périphérique.
Si l'appareil ne fonctionne pas il pourrait être un problème de Jumper Settings. Regardez à l'arrière du lecteur pour voir le Jumper Pins et le Jumper. Regardez sur l'étiquette pour voir un diagramme des paramètres différents pôles.
Si il est toujours défectueux, essayez de le connecter avec un autre câble IDE, et essayez de nettoyer la lentille laser avec un Nettoyeur de CD DVD Lens.
Si il est lente, c'est peut être un problème avec l'ordinateur. Certains systèmes d'exploitation va automatiquement ralentir un lecteur optique à une faible vitesse de base après il a démontré un certain nombre d'erreurs de lecture.
Aussi essayez de vérifier et modifier les paramètres (SATA /) IDE dans le BIOS.
Enfin, le lecteur peut aussi être défectueux et peut-être a besoin d'être remplacé.
J'espère que cela aide.
Si cette réponse va certaine manière à aider à résoudre votre requête, un problème ou de défaut, s'il vous plaît prendre le temps de l'évaluer.
Cela permet aux fournisseurs de solutions, comme moi, mieux comprendre les besoins et le point de vue des questionneurs, comme vous, et nous guide dans l'exploration des meilleures façons de fournir les réponses les plus complets de qualité, utiles et de haute et de solutions que nous pouvons.
Si vous avez besoin d'aide, s'il vous plaît n'hésitez pas à poster une autre question ou ajouter un commentaire à cette question.
Merci pour avoir utilisé FixYa.
Sep 15, 2011 | Computers & Internet
Lorsque j'essaye d'installer le driver de mon webcam sur aspire 5742 un message s'affiche unreconized camera et lorsque j'essaye d'ouvrir acer crystal webcam il y a un message...
salut !
je pense que le pilote ne fonctionne pas correctement
voila un site qui vous permet d'analyser votre ordinateur puis d'afficher automatiquement les diff?rents drivers compatibles.
juste lance la d?tection et suivi les instruction
http://www.touslesdrivers.com/index.php?v_page=29
merci de choisir fixya
May 22, 2011 | Acer Aspire 5742Z-4200 Notebook
Broder avec la singer tradition 2250
AUGMENTEZ(LEVEZ) TOUJOURS le pied de presse quand le filetage le fil sup?rieur.
Apr 25, 2017 | Singer 2250 Tradition
Probl?me de router
Si vous disposez déjà d'un mot de passe et quelqu'un d'autre est connecté, la seule chose à faire est de désactiver le sans fil.
l'autre personne est hautement qualifiés sur les ordinateurs.
Se connecter via un câble Ethernet.
Ou vous pourriez augmenter la sécurité. Dans les options, changer "WEP" à "WPA" ou "WPA2".
Aug 07, 2008 | Computers & Internet
Contr?leur IDE VIA PCI Bus Master
Quelle est la marque et le modèle de votre ordinateur?
Jan 11, 2008 | Microsoft Windows 98 for PC
Open Questions:
Computers & Internet Logo
16 people viewed this question
Alun Cox
