Question about Electrical Supplies
My 4300 inverter genny powers my rv ac unit for about 30 minutes and then shuts down. the low oil light is on. the oil is full on the dipstick????
  • J Rosado Aug 19, 2019
    Low oil level and low oil pressure make a differencedifference
    Master:
  • Electrical S... Master
  • 265 Answers
We have a whole Help Center and Engineers dedicated to helping people fix their Portable Generators. In addition to this we have a "Parts Search Service" if the part is not listed on our site. Check us out on our site. https://www.generatorguru.com/
Parts Spares for Generators and Small Engine Machinery
my 4300 inverter genny powers my rv ac unit for ab - image-2fwsrbehqcya13uxwt41l5dc-5-0_5.jpg
Posted on Aug 19, 2019
6ya staff
SOURCE:
Anonymous
  • 22 Answers
SOURCE: Just had oil changed, dipstick reads full, but oil light flickers
the light is probably sending an OIL Pressure drop warning ---there is a rarity however
an oil filter may be improperly installed or the OIL Pressure connection on the oil pressure
sending unit --usually next to the filter --is loose or corroded or the oil pressure sending unit may
be going bad ---on a 2001 it is conceivable
otherwise you have an internal oil pressure leak --crank or cam bearings --bad o ringy thingy somewhere or the oil pump --may be experiencing problem too or the pick up screen in the oil pan
is somwhat clogged ---for a clog --try what's called SEAFOAM in the oil ---the stuff actually works
like it says on the can --about 8 bucks --drive for a week --say 500 miles worth and change the oil filter again --just the filter ---either way OIL Pressure is nothing to ignore ---you need to fix that
asap depending on the problem source!!!
I hope this helps
HAWK
Posted on Apr 06, 2009
SOURCE: Oil Pressure light stays on. Oil reservoir is
It occurred to me that you may find it by unplugging wires on the few items under the hood which may appear they could be the oil pressure sending unit.
The light should go out when the wire is unplugged, and if it does it is bad. That's your continuity test.
If you unplug the oil pressure sending unit and the light does not go out, the cause of the oil light staying on is something other than the oil pressure sending unit.
RE pete cass posting: I believe that if the sensor is diconnnected, the oil pressure light will not light (at least because of the oil pressure sensor switch being disconnected) -- the symptom here is the light won't go off. The switch is closed with oil pressure below 10-15 PSI and open above that oil pressure -- this is a normally closed switch.
Posted on May 12, 2009
VtToolMan
Mark
  • 704 Answers
SOURCE: Dometic rv fridge runs fine on elec, lights on gas
It is key that all control switches are in the correct position, depending on what power source you are using, gas, electric, etc. If the switches are not in the proper setting, the unit will not operate.
Here's the manual for your fridge that should be printed out for your use and reference (and reading enjoyment). It has all the info needed to operate and troubleshoot it.
Typically, when using any gas appliance with a pilot light, the sensor has to first be hot enough to trigger it to allow the safety gas shutoff to open and allow the gas to flow to the pilot/burner. Follow the instructions and you should be all set.
http://gasrefrigeration.net/dom_techdata/2707_2811SM.PDF
Hope you find this helpful and best regards!
Posted on Jul 30, 2009
Anonymous
  • 332 Answers
SOURCE: RV Rooftop AC Unit
Sounds to me like your fan is hitting something
Remove the cover and turn the fan by hand ( with the power off ! ) See what it is hitting
Posted on Mar 06, 2010
kd7alt
Al Worden
SOURCE: Dometic RM3862 RV Refrigerator
This happens when your electrode fails. Replace your electrode.
Posted on Aug 17, 2010
Dometic brisk 2 AC can it be operated on a 24 volt inverter.
If your inverter puts out enough power, sure. It may drain your batteries pretty fast, though. Check the power rating of your AC and compare it to the power output of the inverter. Add a safe margin for everything else you want to run at the same time.
Oct 29, 2015 | Dometic Rooftop RV Air Conditioner
The generator shuts off after 30 minutes with an oil level alert but oil level if full
Your oil level sensor is bad. It needs to be replaced. If you unplug the wire leads to the sensor you may get the generator to run, but you'll have no low oil level/pressure protection. The oil level sensor is on the engine crankcase usually near the oil level dipstick. You'll likely see a small sensor with a couple of wires attached to it. To replace it, you'll need to drain your engine crankcase before removing the sensor.
Apr 06, 2014 | Kipor RV Generator Sinemaster IG3000
Stops generating and just idles
Check if there any alarm on monitor by pressing button several times. It has code like E-number. Replace spark plug, fuel filter. Clean carburator, spark arrester. Check wiring of thermosensor.
Mar 28, 2017 | Honda EU6500iS Inverter Generator
Yamaha EF4500Ise Gennerator won't produce power.
Doe's it have a thermal couple on it? If so it could be bad and when it heats up it is killing your power.
Sep 18, 2012 | Yamaha EF4500iSE Generator 4500 Watt...
Low oil lights and engine shuts down
Give the unit a good shake. Possible that the float that sits in the oil sump is stuck. It sits on the oil and sends a shut down signal if the oil level is low. A sticky float will give this false signal.
Jan 16, 2012 | Cars & Trucks
I have a powermate 5500 that shuts off after 10-15 minutes. I changed the oil, gas, spark plug and the filters. Help!!!
If the unit has a low oil shut down make sure the oil if filled to the proper full level.
If you have the proper level then you can locate the low oil shut down wire and remove the wire to test and see if the unit will run.
If the unit runs with the wire off then you either have low oil or a bad oil sending unit.
Oct 07, 2010 | Coleman Electrical Supplies
Inverter will not switch to invert when the ac power is turned off
I am assuming that no fault lights are showing on the remote panel, but if they are, then those indicate a problem, e.g. overtemp, or AC overload. If the former, allow the unit to cool down and/or provide more ventilation, and if the latter, reduce the AC load by turning things off. The inverter must be in "standby" mode (green inverter light slowly flashing) for the inverter function to come on automatically when the incoming AC is shut off. Also, the battery bank voltage must be between 10V and 15V for a 12V system, the inline battery fuse must not be blown, and the unit's pop-up breaker (on the right front of the box) must not be tripped.
Sep 24, 2010 | Xantrex Technology Heart Freedom 30...
Jul 25, 2008 | Dometic Refrigerators
Electrical Supplies Logo
64 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
