Question about iLO 2600 Television
Ilo 32 inch LCD wont turn on
No red standby light. TV will not turn on. All power sources ok.
  • 21 Answers
I FOUND SOME TRACES ON THE hIGH VOLTAGE BOARD THAT CAME FROM WHITE and black wires that were burned, Soldered wire to complete circuit and reinforced adjacent test point pad and trace with solder blob.
Posted on Sep 06, 2009
  • 113 Answers
Power supply bad inside of tv
Posted on Aug 28, 2009
SOURCE:
Is the red light suppose to stay on when you turn off the tv with the remote?
Yes it is supposed to stay on. This is the standby light. The television still draws power as do many electronic devices when not turned on and when in standby. If you do not want the red light to stay on you will have to unplug the television.
May 09, 2011 | Samsung LN32A330 32 in. LCD TV
Tv wont turn on
hmmm...ok...turn it off for around 20 minutes, to allow all energy to discharge. Then try it once again.
second...check to see that the power from wall is still good(always helps to check that)
Feb 24, 2008 | iLO 2600 Television
No standby
replace the power supply fuse
Aug 28, 2009 | iLO 3200 32 in. LCD Television
Ilo 32 inch LCD tv will not turn on
replace bad cap in the power supply the top will be put up
32 inch ilo LCD wont turn on or anything, no red light or green.
Hi there! You may have had a power surge. Most of these panels are not fitted with a manual on/off switch which can protect it from spikes. If you switch it off using the remote, it is still in danger of getting damaged via the power source. I would personally start with the fuse. If this fails and you are not in the know how of repairing electronics then refer to a repairer. Beware of High Current!!! Unplug from mains and replace fuse carefully with the same rating and refrain from touching anything else as the main capacitor may still be charged. Stand back when you switch on, especially your face as a fuse may explode and send pieces of glass flying. Bset Wishes and Good Luck, JUS004
Aug 22, 2009 | iLO 3200 32 in. LCD Television
Ilo 32 lcd
I have the same issue. Here's a temporary solution, which is what I've been doing for the last couple of weeks, unplug the unit from the wall, just long enough for the red standby light to go out, then plug the unit back up. as soon that the red standby light comes on, press the on button the the remote or the unit. You may have to do this couple of time before it works. Somedays it works on the first try for me and then somedays I have to do it 3 to 4 time. I sure that at some point this will stop working too.
Sep 08, 2008 | iLO 3200 32 in. LCD Television
Tv wont turn on
Is it plasma , or LCD?
Feb 16, 2008 | iLO 2600 Television
Televison & Video Logo
330 people viewed this question
Top iLO Televison & Video Experts
Steve Allison
Steve Allison
Ekse
Jerry Greenberg
Jerry Greenberg
Are you an iLO Televison and Video Expert? Answer questions, earn points and help others
