Question about Mitsubishi Televison & Video
My Mitsubishi #65315 65” turns on but shortly turns off by its self?
MITSUBISHI WS-55315 WON'T TURN ON WITH REMOTE OR START BUTTON
do the self check and find the error code if set shows power and then goes total dead shortly after.
May 02, 2012 | Mitsubishi WS-55513 55" Rear Projection...
I have a Mitsubishi medallion 65 and it keeps turning off,
Dear Sir,
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times.
1 - 2 = no error detected
2 - 1 = X-ray protect (high voltage or beam current)
2 - 2 = Short protect (short protect monitors low voltage supplies)
2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection)
2 - 4 = Vertical protect (usually loss of vertical from the source)
1. SHUTDOWN AT POWER WITH SELF DIAGNOSIS ERROR 2 2. CHECK FOR OPEN FUSES F9A04 PART # 283P044020 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. I hope this helped.
Good Luck, big IRISH.
Dec 08, 2009 | Mitsubishi WS-65411 65" Rear Projection...
TV turns off and on by itself
Your processor isnt powering up enough for the self diagnosis to start. Check the Horizontal output transistor and the low voltage regulator one is either shorted or opened.
Nov 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi 55 inch Digital TV WS-55807
Good Day; This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55807 TV
Tv screen tv
Good Day;
Shutdown at Power Causes: Cause #1 This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH.
Aug 31, 2008 | Mitsubishi WS-55807 TV
Mitsubishi projection tv
GOOD DAY; THE VS-45607 Model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB. GOOD LUCK, big IRISH.
Aug 17, 2008 | Mitsubishi VS-45607 45" Rear Projection...
Mitsubishi turn on then turns off
Your model has the V22 chassis when it blinks a 21 cide which is what yours is indicating that maens the set is shutting down due to xray protection. Which means a votage is raising which trips the xray protection circuit and keeps your set from operating
1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR PROPER SEATING OF CONNECTIONS TO AND FROM THE HIGH VOLTAGE BLOCK. 2. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB.
May 09, 2008 | Mitsubishi WS-65413 65" Rear Projection...
Mitsubishi WS 55807
Good Day, Y'all;
First check for fluid on the PCB's, if ok check the following:
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. SELF- DIAGNOSIS INDICATE X-RAY. CHECK FOR A SHORTED IC5A03 PART # 270P704010 AND AN OPEN R5A73 82K ¼ WATT OFF PIN 2 OF IC5A02 ON THE MAIN PCB. 2. SELF DIAGNOSIS ERROR INDICATES SHORT PROTECT. CHECK FOR OPEN FUSES F9A04 AND F9A05 PART # 283P043090 ON THE +24 AND -24 VOLT LINES. IF THE FUSES ARE OPEN THE CONVERGENCE OUTPUT CIRCUIT WOULD BE SUSPECT. 3. SELF-DIAGNOSIS INDICATES SHORT PROTECT. CHECK FOR A SHORTED IC4B01 PART # 270P261020 (VERTICAL OUTPUT) LOADING 24-VOLT SUPPLY LINE. LOCATED ON THE MAIN PCB. Good Luck, big IRISH. PS If too much call an authorized service center and have them give an estimate on their repairs in writing.
Apr 25, 2008 | Mitsubishi WS-55807 TV
Mitsubishi vs50605 turn on and dhuts down and light flashes 3 time
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB
Mar 29, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Mitsubishi VS-45607 picture goes out intermittently
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems. To activate this turn the unit on let it shutdown then press the input/device and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source) 1. MAY BE INTERMITTENT, SELF-DIAGNOSIS ERROR 23 OR 24. CHECK SOLDER CONNECTIONS AT CONNECTOR "DY" ON THE YOKES. 2. SHUTDOWN AT POWER WITH SELF-DIAGNOSIS ERROR 23 OR 24. CHECK C411 2200 UFD 35 V AND C412 10 UFD 50 V, BOTH LOCATED ON THE MAIN PCB.
Dec 13, 2006 | Mitsubishi VS-45607 45" Rear Projection...
Televison & Video Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
