Question about Frigidaire Refrigerators
Frigidaire freezer model fkfh21f7hwa - shows OF, unable to turn it on.tried unplugging for 30 minutes, tried pushing down arrow
6ya staff
SOURCE:
christian nielsen
  • 358 Answers
SOURCE: HELP! Frigidaire Fridge FRS26HF7BB0 losing coldness and buzzing
That noise is typical when the compresor is trying to start but it doesn't , it could be the condensing fan motor that doesn't work and the compresor goes off on overload ; a common problem with this compresors is the relay (mounted at the side of the compresor behind a black plastic cover) goes bad , this you can replace is about $20 , and if still the compresor won't start you will need to put another one and this is an expensive job.
Posted on Aug 02, 2009
Anonymous
SOURCE: Frigidaire Affinity ATF7000E Front Load - shows pau and the number of minutes left
Its an issue with the front door sensor and the motherboard. I had to replace the mechanism since it could no longer work. Cost me 250 and almost 2 years later its happened again
Posted on Sep 29, 2009
Anonymous
  • 152 Answers
SOURCE: I just set up my Frigidaire upright Freezer, only
Rule of thumb, if you lay a frig/freezer on side let sit upright at new location for 24 hours before plugging it in.
Posted on Mar 09, 2010
SOURCE: I have a frigidaire upright
OK, this is a failed controller board, any E4* is Power supply & Controller Board, probably caused by a power spike.You need to get the unit looked at to see if it is able to be repaired, and if parts are available. If you wish to try and repair this yourself, you must get a service manual, to do so, and to be able to order parts.
Posted on Apr 06, 2010
zx5000
SOURCE: Frigidaire Gallery Series ES340 ceramic-top range:
The manual is missing a step. After pressing Clean or Quick clean you need to press the ^ button once.
Posted on Sep 05, 2010
How do i get the temperature on my frigidaire refrigerator to go down?
Thank you for your post, Sabina!
Based off what you have described your temperature will not go down inside of your Frigidaire refrigerator. You stated that you have tried pushing the down arrow, what happens when you do so? Is it still producing cool air? Is your freezer packed, full, or does it have any frost build-up? With additional information I can better assist you. -Matt
Mar 22, 2015 | Frigidaire Refrigerators
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
Error code 0F
Good Morning Stephanie Garcia, thank you for your post!
From the information you have provided your Frigidaire freezer is displaying an error code of "OF". Typically, an "OF" stands for power off, you should be able to press the up arrow three times in a row within five seconds to turn your freezer back on. If that does not help correct your issue you may want to perform a reset and you can do that by unplugging the power cord for roughly ten minutes. I hope this helps. -Matt
Jan 17, 2015 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The light bulb in my My Frigidaire fkfh21f7hwa upright freezer started blinking and the fan would stop running whenever I open the door. The control panel would also beep and flash between 0 and 1. I
Hello Ricco, thanks for your post!
Based off the information you have provided it sounds like a possible issue with your control panel or power cord within your Frigidaire freezer. I would recommend performing a reset on your freezer and you can do that by disconnecting the power cord for roughly ten minutes. If you continue to experience an issue with the freezer I would recommend consulting with a professional technician for a proper diagnosis to be completed. Best of luck! -Matt
Jan 10, 2015 | Frigidaire Freezers
My new frigidaire freezer digital display flashes off please help
Hello - Typically "OF" indicates that the freezer is turn off. To activate freezer, press UP three times until display shows "1" then press UP to desired setting. If it will not allow you to change setting and freezer continues to be off, try resetting the freezer by unplugging it or flipping the breaker off. Wait approximately ten minutes and turn it on. If "OF" continues to display, the unit could possibly have a communication problem with the electronic control assembly. Contact a professional to move forward accurately.
Nov 04, 2012 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
My new frigidaire freezer the digital display on outside of door flashes off what to do?
Frigidaire FKFH21F7HWA Freezer Control Panel Stuck at 0F
did you press and hold the freezer off symbol for three seconds
Jul 31, 2012 | Frigidaire Freezers
I have a frigidaire upright frost free freezer model number is FFU2065FW3 I put in a new electronic temperature control Board and when I plugged the freezer back in, the control board was flashing "E" and...
Apr 03, 2010 | Frigidaire 20.3 cu. ft. / 575 liter...
Refrigerators Logo
52 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Thomas F. Schneider
jasbo
jasbo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
