Question about Anne Klein Watches
How to unlock the hands on a anne klein watch
How to remove the movement in a anne klein watch because the hands are stuck on top of each other
SOURCE:
SOURCE: Anne Klein chronograph watch
The button advances the numeric day. After the numeric day is advanced one full month, the month dial advances to the next month. I just about got a blister pressing the button enough times to advance the month from January all the way around to December. Then I had to advance the numeric day to the current numeric day. The previous person told you by turning the dial 24 hours you can advance the alphabetic day of the week by one day (Sun, Mon,etc.).
Posted on Dec 04, 2008
SOURCE: anne klein watch battery replacement
My Anne Klein uses an EverReady #377. The internal time module from Hong Kong is stamped with "AL21E."
I hope this helps you.
Posted on Dec 09, 2009
disap1
  • 98 Answers
SOURCE: How do I remove links from an Anne Klein watch
Many watch companies are including extra clasps on the bands so customers can adjust the band easier on their own. Check the bottom of the band for those.
If not I suggest going to a reputable watch repair shop and have them do the adjustment for you. It will save you time and frustration of trying to do it yourself. If a screw or pin drops and you cant find it you may end up having to reorder them from Anne Klein!
Posted on Jan 10, 2010
escapement
  • 2338 Answers
SOURCE: where can i purchase 3 extra links for my Anne
Click on my profile, then click on TIPS AND TRICKS, There you will find a phone number for ordering parts from AK. Rate me, plz.
Posted on Feb 20, 2010
radar001
  • 1051 Answers
SOURCE: how do i take the
If it's a pop-off type back, (you can tell by running your finger nail around the edge between the back and the case) If you find a slight indent or flat spot near the 12 o'clock position it is a pop-off back. Use a very sharp blade and VERY gently pry the case back up at this spot. It should pop off easily. Don't force it or it'll bend. To replace: line it up in the same position it had been and apply firm pressure untill it snaps back. If it's a screw off back (it has a series of slots around the edge) you'll need a case back tool to remove it. In that case it'll be easier to go to a jeweler.
Posted on Aug 05, 2010
Testimonial: "very good"
HOW OR WHERE TO GET A NEW BAND FOR ANNE KLEIN WATCH 10/9442?
that is a pretty funky fitting! However, that is a plain leather band that is screwed to the fitting. Your local jeweler could do that job for you or contact them direct. You will get a plain strap with two holes in it.
Anne Klein Women 10 9442 Leather Strap Watch
eBay have some
Anne Klein Watch Bands eBay
Jun 30, 2018 | Anne Klein Watches
How to adjust Time and Date on Anne Klein 10/7899 6P05 Ladies Watch
You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
Nordstrom provides a generic Anne Klein manual here:
http://i.nordstromimage.com/images/default/shop/image/misc/watch-manuals/anne-klein/anne-klein.pdf
Mar 20, 2016 | Anne Klein Watches
How do I set the date on an Anne Klein watch with only a stem?????
-GB&q=anne+klein+watches+how+to+ http://i.nordstromimage.com/images/.../watch-manuals/anne-klein/anne-klein.pdf .
Hello, you can download a pdf instruction sheet at the above site. Hope it helps. Bye.......
Mar 10, 2015 | Anne Klein Watches
Replacement clasp for Anne Klein watch, caseback #12/6130-1
mcdevito75 here, Your in a spot with your Ann Klien watch. BEST BET, shop ebay and match up another Ann Klien just like yours and use for parts. On ebay Click in search, watches then Ann Klien.
Jul 26, 2010 | Anne Klein 10 7977MPTT
My watch works with movement, and will work for a few seconds then stop, even thought I'm continously moving. Is it a shortage or something? I can shake the watch and it will work but only for a few...
I would take it to a watchmaker/jeweler to have them check the battery. Some watches have a battery bar that holds the battery in and it may have come loose. Or the battery is losing charge. It should not cost you anything to have them check the battery for you. Good luck
Jul 22, 2010 | Anne Klein AK Round Brown Crystals Watch...
How do I remove links from an Anne Klein watch band (8509 SVTT model)?
Jan 10, 2010 | Anne Klein 12 1821WMSB watch
Lost warranty and information book for Ann Klein watch 107208RMRG
As you lost all the papers , there is no reason to send your watch to any specific repair centre. Just find your nearest watchmakers shop and they will sort the things out.
Alternatively you can pop in to any Anne Klein dealer shop and ask to fix your watch.
Do not forget to rate, please.
Feb 06, 2009 | Anne Klein 12 1821WMSB watch
Anne Klein 10 8755svtt watch will not keep ticking
First you have to find out if your watch is (as you say) automatic. If it is, then it is NOT kinetic and you will need a proper watchmaker to get it going.
My experiance is: there are NO automatic or kinetic watches in Anne Klein range. All of them are or were battery driven. Might be you came across the one auto, but it's hard to believe.
To make sure: Try wind it up. If you don't hear the specific sound, this is not an auto watch. If the winder(crown) is easily moving back and forth- your watch is battery driven.
Do not rate me yet, as this is not a solution, just an advice.
Want your watch working again?- Let me know, I'll guide you how to do that.
Jan 18, 2009 | Bulova Watch
Need extra link for an Anne Klein 10-7977MPTT watch
Yes you can, go to amazon and take a look: Amazon com Anne Klein10 7977MPTT watch link. Wish you best of luck.
Cheers
Jan 01, 2009 | Anne Klein 10 7977MPTT
Watches Logo
Top Anne Klein Watches Experts
Arturs Kalnins
Arturs Kalnins
Andrew Taylor
Andrew Taylor
Are you an Anne Klein Watch Expert? Answer questions, earn points and help others
