Which transistor number does Sonny Trinitron 21 inch uses??
    Top Expert:
  • Televison & ... Master
  • 76,100 Answers
Sony uses ,any transistors and ICs with Trinitron TVs.
Without knowing about which section of the circuit, it will be difficult to give you an answer.
If you wish to get some details; visit the site linked here. Pull up older posts.
https://electronicshelponline.blogspot.com/
Circuit diagram of different brand sets are given. You can refer and find it out.
Search the site by type in the "brand name" to your device; [Exclude the model number], in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. See the site by a desktop. Mobile view has no search box. If you are viewing it by your mobile, see it in webview.]
Visit this site too. It too has some details.
https://schematicscom.blogspot.com/
https://homenol.blogspot.com/
Posted on Aug 14, 2019
SOURCE:
nileshsingh2
  • 246 Answers
SOURCE: I have an EIZO T962 CRT 21 inch monitor with bright screen
CHECK FOR DAMAGED RESISTORS ON BOARD NEAR HIGH VOLTAGE AND ALSO ON CRT SOCKET, ITS A COMPONENT PROBLEM, RECTIFY IT..CHANGE THE DAMAGED COMPONENT, ALSO CAPACITORS IF POSSIBLE..
Posted on Oct 16, 2009
  • 901 Answers
SOURCE: lg flat 21 inch tv
You have to check the high voltage diodes near the horizontal transistor and the small transformer. Diodes might have gone leaky. Check the capacitors also.Replace the black colored diodes with new ones with identical part no.
Rarely EHT coil will have problem.
Posted on Sep 15, 2010
palaboy
  • 5807 Answers
SOURCE: sony tv 21 inch horizontal output transistor failing frequently
• Power Supply B+ is higher than normal
• Partially shorted Flyback Transformer
• Bad Deflection Yoke
• Too much oscillation on the Jungle IC
• Bad capacitors around the horizontal output transistor
Posted on Sep 27, 2012
gopakumarg43
  • 76100 Answers
SOURCE: What is the no. of horizontal output transistor of 21 inch philips tv model no. 21PT3324/71 chassis no. LO1.2A/AB?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Circuit diagrams to any popular brand TVs are given. You can get details there.
Posted on Jul 18, 2015
  • 12962 Answers
SOURCE: I want to know if i wil c5888 transistor to replace c5885 transistor in a sony 21 inch colour tv or which transistor wil i use as a replacement?
Do Google search for equivalent.
Posted on Aug 23, 2016
Which transistor is alternative for transistor d2499 ?
Id try ebay or thefind.com you may get lucky and they will suggest a substitute. Radio Shack may also. How do you know the transistor is bad?
Mar 06, 2015 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sony trinitron 21 inch kv g21q1
It means that one of the secondary output voltages are short. You ll need to check every output voltage at the smps transformer. If the set is producing a hissing sound, then either the 115 v zeener is faculty or the horizontal output transistor is faulty
Jan 15, 2014 | Televison & Video
No signal when i turn on ma tv sonny trinitron 21:no sound, no picture
What is the exact model number to your Trinitron TV?
Jan 12, 2013 | Televison & Video
Sony tv 21 inch horizontal output transistor failing frequently
Sep 27, 2012 | Jwin JV-TV9090 21 inch TV
I have an EIZO T962 CRT 21 inch monitor with bright screen. I can't adjust brightnes with conventional means ( adjusting via buttons). In the past I correct this problem on Sony trinitron 19 inch monitor...
Oct 16, 2009 | Eizo FlexScan TX D7S Monitor
SONY TRINITRON KV-2167MT power not on
Please replace Horizontal Output Transistor in KV-2167MT and TV will start function.
Nov 26, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
No sound (sony trinitron kv-2197pf 21" tv)
try to short the spider transistor along ic amplifier. it is in a mute
Oct 05, 2008 | Sony FD Trinitron WEGA KV-21CL10 21" TV
Sonny tv problem
The problem with this model is the large parts due to poor wave soldering. Locate the transistor Q605. Using a small wattage soldering iron melt the solder and add a little solder to all the large parts in the area. Small wattage = 15 to 30 watt. Stay away from the surface mounts they are not the problem. I resoldered the following: D647
Q605 C690 D645 D620 R691 Q691
These parts are located on the main board, the one the power cord connects to. Carefully press the clip on the left side of the board (as you look at it from the rear of the tv) carefully pull the main board back and out of the rails. You will find the parts on the right side of the main board about 2 inches over 2 inches down.
Dec 31, 2007 | Sony FD Trinitron WEGA KV-27FS100 27" TV
Repair of Sony 21'' flat screen television set
problem lies in the power supply check opto coupler or check horizontal output transistor and lot
Nov 22, 2007 | Sony 21" Trinitron P202 Flat Screen...
Sonny tv triniton
Buddy, Not a problem for the average Home Technician. Unless you are good at Solid state Electronics service. Problem is faulty Red Outpuit Transistor or associated components. Best to seek professional hellp.
Mar 31, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
21 people viewed this question
Top Televison & Video Experts
Ekse
