Question about Eureka Vacuums
Replacing motor on eureka multi cyclonic model as2020
3 Suggested Answers
SOURCE:
reddevil6
  • 1673 Answers
SOURCE: Motor replacement for upright Eureka 4467av
Part # is 60261-11, but Eureka has it No Longer Available. But check with a vacuum repair shop, they should be able to order one for you, but they cost around $80 or so.
Posted on Feb 06, 2008
galati2k
  • 281 Answers
SOURCE: need a new motor
depends how old it is .if its quit a few years ol i would buy a new one.some of those oplder whirlwinds ar hard to find parts for and some are just not available anymore
Posted on May 05, 2009
Eureka multicyclonic keeps turning off
Start by replacing the filters. If it's clogged the motor will shut off because it gets hot
Jan 21, 2014 | Eureka Whirlwind Litespeed 5740 Bagless...
Eureka vaccum won't turn on
There is a thermal reset in the motor that will shut the motor off if it gets too hot from a clog or clogged filters. It will come back on when it cools down. If it does this try to find a clog somewhere and also replace or clean your filters
Dec 18, 2013 | Eureka 5892AVZ Bagless Upright Cyclonic...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
The handle for my Eureka 5893 AVZ was getting very hot. Finally, the wires around the switch melted and the vacuum will not work. What is wrong? Is the switch bad? Nothing else appears to be wrong.
usually if a connection gets hot enough to start melting it is usually a loose connection or high current. more than likely the switch is bad if you replace it with the same type of switch and it gets hot check the motor. make sure it is clean and isn't jammed
Nov 05, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
Need a new motor
Apr 20, 2009 | Eureka Whirlwind 4388 Bagless Upright...
My wife's Eureka 5855 Boss Bagless Wide Track stopped running
its probably something in the motor. you may have to replace the motor which could cost around $50.
Apr 15, 2009 | Eureka 5849A Boss Bagless Upright Cyclonic...
The dirt cup clip broke and can't find the part!! Eureka whirlwind lite model#4388
I am assuming that you're looking for the handle at the front of the dirt cup... Part # 28131-288N, it has been replaced by part # 74985 Dirt cup grip assembly. If you call Eureka Customer Support at 1-800-282-2886 they will be able to find you a local dealer.
Apr 02, 2009 | Eureka Whirlwind 4388 Bagless Upright...
Vacuums Logo
14 people viewed this question
Top Eureka Vacuums Experts
JoeVacs
Alan Matzke
Alan Matzke
Are you an Eureka Vacuum Expert? Answer questions, earn points and help others
