Question about The Computers & Internet
I need to change the two CR2032 batteries on an Elektra model 3021 electronic scale please
SOURCE:
SOURCE: electronic bathroom scale lithium battery spent
I had a problem changing the battery too. I just couldn't get it out and was afraid of prying too hard because I might break it. So I called customer service to ask them (a bit extreme) but they basically just told me to take a small screwdriver (I used a hair pin) and pop it out. I tried again by pushing down on the opposite side instead of lifting and it popped right out. The battery is just a small electronic one like in a car's keyless entry controller.
Posted on Dec 10, 2008
SOURCE: I have an old toledo electronic scale that I need
To Whom It May Concern:
I have access to the same model you mention in your post. It was handed to me for repair and I did my best to track down a schematic for Toledo Scale model 8420. Coincidentally I happen to work in the same neighborhood that Mettler-Toledo is located and getting to their CSR was easy. Bad news is this same CSR who is what we in the industry call a "Lifer" didn't have any of the service documentation for this 25+ year-old scale.
Good news is I made a request to the original owner not to throw out the scale once I returned it. If you are interested in buying the scale "as-is" and salvaging the parts needed to solve your reset and 0000 problem, this may be your best opportunity. I don't know as of this writing what the original owner, a restaurateur, will ask for the scale but estimate it won't be much. These scales are industrial strength and this particular one is in great cosmetic condition.
Because I am new to Fixya and don't have the patience to set up an account presently, you will have to post your reply as you did for your initial question. I will check the site in a couple of days to see what has transpired and go from there.
Best regards,
Chris
Posted on Nov 12, 2009
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
SOURCE: Problem changing battery for Conair Thinner Scale TH300
My scale is an older model, "can't locate model# in or outside" sticker on back plate is RH697. Scale was purposely setup so that no one can change the battery but a tech. Back plate had no instruct as to where battery is and the 4 small phillips screws were covered with rubber filler. I scraped off the rubber filler and opened it up, inside was a computer board which I took out (6 tiny phillip screws) to get to the battery (it was the expected 3V) the battery was front and back soldered in. That was enough for me, this company is nothing but a bandit forcing you to a tech (est. cost 45-60$) or to make another purchase. True piracy, I'm throwing it out. Make sure when buying anything that runs on batteries that the product offers ease of replacement, I am disgusted with Thinner.
Posted on Oct 10, 2010
  • 18 Answers
SOURCE: I replaced the battery with a DL2032 instead of a
This shouldn't be a problem, as the DR and CL are referring to the manufacturer. Both batteries are 20mm in diameter and 3.2 mm in thickness. Make sure you do have the 2032, rather than the 2023 1.5v alkaline batteries.
I would recommend taking it into the store where you purchased it.
Posted on Dec 07, 2010
My emails are displaying dates of 12/31/1969
Change the date in the settings of the BIOS or in Settings. If it reverts to 1969 every time you turn the computer off, you need a new motherboard battery. Usually a CR2032 button battery.
cr2032 Google Search
change date in BIOS Google Search
change cmos battery Google Search
Oct 05, 2017 | Computers & Internet
Need # for replacement battery, please
Many Taylor scales use one or two CR2025 or CR2032 batteties.
I usually put in the higher current CR2032. These are available online, shopping centers, pharmacies, and even grocery stores. If you Google your part number and manufacture you can download the manuel which will tell you the battery required.
May 09, 2016 | Taylor 7321 400 Pound Lithium Scale
What battery goes in the tasco propoint
Depends on the model:
Model PDP2....... (1) CR2032
Model PDP3........(2) CR2032
Model PDP3CMP..(2) DL1/3N or 2L76
Model PDTS1 32..(1) CR2032
Oct 08, 2014 | Tasco 1x25mm ProPoint Red Dot Scope
Www ehow com
Cmos battery is usually a 3 V button battery, there are variety of different brands so you need to open and check it.
eBay: ACER ASPIRE 7741G 334G50 MS2309 CMOS BATTERY - 476
http://www.ebay.com.au/itm/ACER-ASPIRE-7741G-334G50-MS2309-CMOS-BATTERY-476-/161408573087?pt=AU_Components&hash=item2594b35e9f&_uhb=1
2035, 2032 can be bought from any super market or hardware store. Need to open the PC, locate the battery, which is normally clipped to the mother board. Use a small screw driver and lift out. If battery is soldered to the mother board then need to access under the board and de-solder carefully without damaging the tracks.
2032: CR2032 CR 2032 5004LC 3V 3 Volt button cell lithium battery for CMOS
http://www.ebay.com.au/itm/CR2032-CR-2032-5004LC-3V-3-Volt-button-cell-lithium-battery-for-CMOS-/271586313364?pt=AU_Electronics_Batteries_Chargers&hash=item3f3bce4494&_uhb=1
solder types: SONY CR2032 3V SOLDER TAB Pin battery with soldering tag for CMOS Bios PLC new
http://www.ebay.com.au/itm/SONY-CR2032-3V-SOLDER-TAB-Pin-battery-with-soldering-tag-for-CMOS-Bios-PLC-new-/271570170168?pt=US_Single_Use_Batteries&hash=item3f3ad7f138&_uhb=1
Aug 30, 2014 | Acer Aspire Z5771-UR31P - All-in-one - 1 x...
Replacement battery for 5786 taylor scale
Fixya does not sell replacement batteries.
Dec 23, 2012 | Taylor Health & Beauty
Time not set and bios automatic change
You need to replace the battery on the motherboard. It is dead and the computer is reading the original bios date/time for the board. The battery is usually a 3 v model CR2032. The cost is about $3-5. rohdd.jpg
Please let me know if this is your computer problem by posting your comment.
Feb 15, 2011 | Computers & Internet
How to change cmos battery?
the COMS battery is part of the motherboard, in most PCs they are inserted in a removable slot, the battery is a watch cell the size of a Dime and can be replaced (the battery serial/model # may be CR2032)
In some they are fixed in the motherboard, it's hard to remove it in this case.
u need to open the PC box to look for the battery, it can be easily detected if you can view ur complete motherboard.
Jan 21, 2010 | Fujitsu Stylistic ST5112 Tablet PC
My computer date and time changes every time i log on. most times it reads 1 / 01 / 2003 what can i do ? thanks Jim
Change the CMOS battery Jim. It's located on the motherboard in a Desktop computer.
The battery is about the size between a US nickle, and a quarter. Has CR2032 on it.
You can go to stores that sell watch batteries, and ask for a CR2032 battery.
Unplug your computer from the surge protector before you do.
More info for identification of the battery,
http://en.wikipedia.org/wiki/CMOS_battery
Oct 17, 2009 | Microsoft Windows XP Home Edition
Open Questions:
Computers & Internet Logo
16 people viewed this question
Top The Computers & Internet Experts
Mohamed Alazhary
Mohamed Alazhary
Inky Fingers
Inky Fingers
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
