My AKAI 4000 ds quit recording and the red recoding light won't come on
I've cleaned the heads very well detoxed all the switches and still nothing I read somewhere to take the front cover off spay the record switch and turn the record switch thirty times this should do it. I don't know where or what the record switch looks like so I spayed detox on all that I thought wcould be it. Can you help me?
  • Audio Player... Master
  • 1,581 Answers
Hi Michael, I sent you the link to your Akai service manual
I hope you can access the Rec key
Suggestion, apply small amount of contact cleaner and test
If you apply a lot, dirt will inevitably form that can affect the proper functioning of the Open Tape
I hope you can solve the problem
Greetings Franco Dosil
Hola Michael, te envio el link del manual de servicio de tu Akai
Espero puedas acceder a la llave de Rec
Sugerencia, aplica poca cantidad del limpiador de contactos y prueba
Si le aplicas mucho, indefectiblemente se formaran suciedades que pueden afectar el buen funcionamiento del Cinta Abierta
Espero puedas resolver el problema
Saludos Franco Dosil
https://www.manualslib.com/manual/997832/Akai-4000ds.html
Posted on Aug 15, 2019
SOURCE:
  • 566 Answers
SOURCE: head lights wont turn off
if you are saying the front side lights are going off but the headlights remain on ? then could you try this ? put the h/lights on main beam mode then whilst on main beam turn off lights if h/lights go off now ? then with lights still off put onto dipped beam with the switch/stick if h/light come on it is most probably the dipped beam headlights relay that has gone faulty as the h/lights have 2x relays 1for dip +1 for main beam if the above does not make any difference ? it may well be the switch assy hope this helps
Posted on Oct 19, 2008
Saaboheme
  • 76 Answers
SOURCE: headlights don`t work
Sounds like a bum relay in the main underhood fuse box. My complete illustrated tutorial for repairing this $80.00 part is here: http://www.customsaab.com/Custom_Saab_NG900_OG9-3_Performance_Articles/p2_articleid/24
Posted on Nov 25, 2008
  • 20 Answers
SOURCE: 2005 Trailblazer XT won\'t go into 4WD. Front hubs
i've been told it was the 4wd actuator located on the passenger side near were the cv joint goes in to the front axle a good test is to floor jack it up so both wheels are off the ground and have someone on the other side , put in nutrual turn both wheels one way at same time and the 4wd drive shaft should turn if not its your actuator, costs about $86 for anew actuator and takes about 5 mins to change once you have the tire off
Posted on Feb 16, 2011
traceylewis1
  • 363 Answers
SOURCE: My 2005 Saturn Ion won't start! I've had quite a
Body Control Motion device:
Common on thjis car call your dealer to see if they have a recall.
Good luck
Posted on Jun 23, 2011
  • 14585 Answers
SOURCE: 2005 Colorado headlights won't light with
The turn signal switch. Almost all of the lights run threw this.
Posted on Aug 06, 2011
Testimonial: "The turn signal switch was bad. However, lights did not work after replacement. The body control module was also burned out."
AKAI X-1810D LOW HUM WHEN RECORDING REELS
I am not an expert in the repair of Akai units- most of the time I refuse them, however just to put you on the right path, the hum is coming from a power supply issue in the record audio section or may be in the bias section. You may need to put new Electrolytic caps in the power supply to resolve this. You can also scope the supplies on this deck to find the cause. I commonly work on Teac, Pioneer, Otari, Studer, Sony and better made decks. Some brands are real trouble and are more costly to repair due to poor construction.
I have been doing repairs for 40 years so far.
Sep 05, 2012 | Audio Players & Recorders
Exceed License?
quite possibly you need to buy new license.
Dec 30, 2017 | Olympus AS-4000 Transcription Software Kit
I need akai part number ms244708 for a 4000d
If you look around you will likely find many many Akai 4000 series reel decks for sale..some for parts.. Akai 4000 series decks used basically the same mechanism and same parts... 4000d, DS, DS II, DB, Incidentally, the Akai 1700, 1710, 1722, 1731 used the same basic mechanisms as the 4000. .
Oct 24, 2009 | Audio Players & Recorders
We have a problem with one of our DS-4000 recorders that is producing a popping noise at times in the recording. We thought it might be something when it was being transmitted over the server to the...
Make sure the recorder is not being used near a cellular device or transmitter.If it isnt,definitely send it to Olympus for service as there is nothing mechanical in the recorder that would cause this.
Aug 11, 2009 | Olympus DS-4000 Digital Voice Recorder
Why would my ds 4000 loose sections of the recording and then pick back up again.
If you have the VCVA set to on maybe the actuation level set too low; the recorder stops recording when the sound level does't reach that level.
Adjust the level to a higher value.
Here is a link to the DS-4000 Instruction Manual
Aug 09, 2009 | Olympus DS-40 Digital Voice Recorder
Can't access the software for DS50 digidtal recorder
you will need to call tech support at olympus... they will work with you in cleaning up your registry and getting the software to work properly
Feb 10, 2009 | Olympus DS-50 Digital Voice Recorder
Plug in the Olympus DS-4000 handheld and the screen blinks erratically busy and then nothing pulls off of the card to the dictation module.
The memory is corrupted. You can reformat but that will delete all your files. If you need to recover the files, try PC Inspector Smart Recovery. I have had good success with that. Then you must reformat, or the problem will return. The problem is caused from static shocks to the recorder.
Nov 28, 2008 | Olympus DS-4000 Digital Voice Recorder
The slide switch on my Olympus DS-4000 digital dictation recorder is too sensitive, and often goes to the "Record" position when it should be "Off." Any suggestions in how to correct...
The slide switch on your Olympus DS-4000 probably needs to be replaced. You can ship it to PCDictate.com to have your Olympus DS-4000 repaired. The repair will most likely run around $100,
However, my suggestion is that you upgrade to the Olympus DS-5000 digital voice recorder, the replacement for the DS-4000. It is a substantial upgrade and you will not regret it.
If you want to consider another brand, Philips has some great digital voice recorders. My favorite models are the Philips LFH-9600 and Philips LFH-9500 professional digital voice recorder.
The best place to purchase professional digital voice recorders is PCDictate.com. Your recorder will be shipped the same day your order and shipping is free.
Aug 16, 2008 | Olympus Computers & Internet
Memory Error
I would suggest the XD card is corrupt. You may be able to copy the recording off the machine by copy and paste in windows explorer. If not then they are lost. Data recovery will not work very as the files are recorded in dss format.
Only option is to format the card on the PC.
Apr 23, 2008 | Olympus DS-4000 Digital Voice Recorder
12 people viewed this question
 Grubhead
Grubhead
Marvin
Marvin
