Question about LG Washing Machines
How much water is used by a LG top loader washing machine
6ya staff
SOURCE:
douglas smith
  • 1462 Answers
SOURCE: LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Posted on Apr 02, 2007
Anonymous
  • 734 Answers
SOURCE: Kitchenaid Top Loader leaks
It leaksYour washer can develop several types of leaks. You can track down a leak based on when it occurs:
During fill only
During drain and spin only
All the time
During fill only
If the washer leaks only during the fill cycle, check these:
Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it.
The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak.
Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak.
A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
All the time
If the washer leaks all the time, check these:
Hot and cold water fill hoses - Check the hot and cold water hoses from the household plumbing. If either hose is leaking, tighten it or replace it, as appropriate.
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace. You probably should call a qualified appliance repair technician.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you need to replace it.
Outer tub - Over time, the steel or plastic outer tubs can rust, split, or be punctured. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 12, 2008
Anonymous
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
Dissolu
Gintautas Maldzius
  • 221 Answers
SOURCE: I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Posted on Aug 07, 2009
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
Lg top loader washing machine wont drain?
watch if the water pipe is connected
May 19, 2015 | Washing Machines
How do i use LG front door washing mechine
These are very similar to top loaders, with the exception of the fact that the use a fraction of the water the older top loaders use. To work best, use the recommended amount or less of your favorite detergent that is available as an HE formula. The HE detergents to not create as much suds as the non HE types; which is required with the small amount of water the machines use. It also ensures the clothes will rinse all soap out completely. Resist the urge to use the less expensive "regular" detergent instead of the HE types - it will cost you more in the end if you don't - trust me. Like top loaders, don't overload the machine either.
When done washing clothes for the day, leave the washer door open over night - to allow the insides of the machine to dry. These doors are water tight as opposed to the top loader and allowing it to dry will prevent nasty mold from forming inside. You might consider running a clothes-less cycle with hot water and bleach to kill mold or as a preventative measure once a month or so too.
Feb 20, 2015 | LG Washing Machines
Require an owners manual for L G -H950 top loader
Do you mean the LG WT-H950 top loader? LG' s Australia site had the manual for the washer on their support site: http://www.lg.com/au/laundry-floorcare-appliances/washing-machines/LG-top-loader-washing-machine-WT-H950.jsp . Click on the Support tab and the link to the PDF of the manual is on the right hand side of the page.
I hope this helps. If you have a different washing machine, please add a comment with the full model number.
Feb 28, 2012 | LG Washing Machines
I have a LG top loader Fuzzy logic 6.5kg model WF-T655th spin cylce not working, the light is flashing. I have a load in the machine, how do I emppty the water out of it. Have misplace the manual.
I have a LG washing machine WTF655TH, it has stopped working, its full of water, but when you push the one button, it trips, how do i get it working again
Jan 16, 2012 | LG Washing Machines
LG Top Loader washing machine leaking when not in use
Remove the top of the washing machine cover to access thehot and cold water solenoids. Disconnect power to the washer and wioe clean around the the manifold. See where leak is coming from . it could befrom the solenoid valves threads.
Nov 25, 2017 | LG WFT1071TP Top Load Washer
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Jan 13, 2009 | LG WFT1071TP Top Load Washer
Washing Machines Logo
54 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
jimorris77
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
