Hooking up analog fax to digital line - Office Equipment & Supplies
    Master:
  • 574 Answers
If it is older machine, not digital compatible then most likely wont work correctly, no handshake.
Posted on Aug 25, 2019
6ya staff
SOURCE:
SYED KHAN
  • 41 Answers
SOURCE: dell 924 fax
Hi ,
The 924 printer which you have is not a standalone faxing printer, in order to send or receive the faxes the printer should be connected to the computer and the phoneline should be connected to the internal modem of the computer and you will be able to send the faxes by scanning the document from the printer, you will find a software called ALL IN ONE CENTER installed on your computer , open the All in one center and then click on FAX Now and you will be able to send a fax.
Posted on Apr 23, 2008
eric moirez
  • 134 Answers
SOURCE: sending faxes
You can hook a fax to any standard phone line. That is what they are designed for. The only issue is if you share the fax with your telephone, you will need to set the machine up to receive the fax before you answer the phone.
Posted on Jun 14, 2008
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: cannot send or receive fax's with hp laserjet m1319f
Fax machines are ANALOG devices.
Posted on Jan 10, 2009
Thomas F. Schneider
  • 2715 Answers
SOURCE: ATT u-verse phone which is voip and HP 6180 All in One
Ask ATT if they have available a Digital to Antalog converter that can use for with your  fax machine.
Posted on Feb 17, 2009
leroyal
Leroy Elliott
  • 2120 Answers
SOURCE: all in one printer for Time warner phone line
ALL fax machines are ANALOG and will not work on a DIGITAL phone line. The new trend now is scan-to-email
Posted on Feb 20, 2009
ERROR T82 BIZHUBC280 IMPOSSIBLE TO SEND OR RECEIVE FAX
Check your fax line connection is the FAX line plugged into the Line jack on the copier and NOT THE TELE connector. Must be Line. Take a old phone like a old princess phone and hook it up to the wall get a good dial tone call some one any noise? Have some one call the fax number OK if hooked to the copier get the tradition noise of a fax line, Check the fax line itself use only one with two wires not four, black and yellow only no red and green. Also put on one of the EMI devices on the cable going into the copier cut down on electrical noise. Line can not be digital must be all analog (POT) Plain Old Telephone, have your phone provider check the line.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Oct 18, 2010 | Minolta Office Equipment & Supplies
Tip
A fax machine is just a big ol' telephone answering machine
There is no mystery, seriously. You send a fax exactly the same way as you make a phone call; instead of talking to a person, your fax machine talks to another fax machine. Clicks, squeals, buzz sounds.
If it says it's busy, well, it's busy
If it doesn't answer, it's not set to AUTO RECEIVE
If it says OFF HOOK another device is using YOUR phone line.
If you don't hear a dial tone when you press the HOOK or MONITOR key, the phone line is dead. Check the line with a regular phone.
If a dial tone sounds weird, it is a DIGITAL phone line. You need an ANALOG or regular phone line.
ALL FAX MACHINES ARE ANALOG DEVICES AND WILL NOT WORK RELIABLY ON A DIGITAL SYSTEM OR A COMPUTER....Magic Jack, Vonage, etc. are DIGITAL PHONE SYSTEMS. Don't believe what the Vendor tells you. They are for designed for VOICE GRADE PHONE CALLS ONLY.
The settings in your fax machine were designed by people who are a lot smarter and make more money than us. DON"T MESS WITH THE PARAMETERS.
It's all that SIMPLE !!
on Mar 09, 2010 | Office Equipment & Supplies
Not always receiving fax digital analog problem ?
prety sure there is no such thing.Most likely its your line.
Mar 30, 2010 | Brother IntelliFax-2820 Laser Fax
Can fax out, incoming faxes going to memory
Now I am very suspicious they hooked you to a DIGITAL phone line.
Make them change you back to ANALOG.
ALL fax machines are ANALOG devices.
Aug 20, 2009 | Samsung SCX-4216F All-In-One Laser Printer
Hook-up
Cable telephone lines are DIGITAL, fax machines are ANALOG devices. It will not work reliably on the ComCast line.
Dec 19, 2008 | Panasonic KX-FHD331 Plain Paper Thermal...
I can't hook up the way it says to
Fax machines need an RJ-11 phone cord and are ANALOG
DSL uses RJ-45 and is DIGITAL.
Don't waste your money on a DSL filter, they won't work reliably.
Dec 16, 2008 | Office Equipment & Supplies
What kind of phone line?
ALL fax machines require an analog phone line. There are no digital fax machines.
Nov 12, 2008 | Panasonic PanaFax UF-8000 Laser Fax
Cannot send faxes when using cable company's digital voice modem
Fax machines must have a standard analog phone line. They won't work on a digital line and can actually be damaged if hooked up to one.
Nov 09, 2008 | HP LaserJet 3050 All-In-One Printer
L75 vs DSL phone line
Fax machines are ANALOG devices designed to work with POTS (plain old telephone system).
Sometimes you can get away with a fax or two w/digital lines, but the machine will be very unreliable.
I don't think there is any damage as the machines have voltage limiter circuits built in. [except for lightning]
Apr 08, 2008 | Canon FaxPhone L75 Plain Paper Laser
37 people viewed this question
jasbo
jasbo
Ekse
Marvin
Marvin
