Question about Brother DCP Office Equipment & Supplies
How to solve ink full box on brother DCP T310?
SOURCE:
SOURCE: unable to clean message in brother dcp-115c aio
I saw on this site codes for another MFC to clear memory and reset the cleaning unit count code to zero. It worked on two of my brother mfc 820cw units. The third mfc 5840cn had unable to print error message 46- nothing at Brother. they want you to take everything to a repair shop.they don't help at all. Then the error went to 4F when I tried toclear the memory.As Iunderstand that message- it means I have to replace the printer head. Have no clue where or what it is. But I can read a manual as well as anyone and follow directions to fix it! Can't be worse than it is now! Good luck
Posted on Jul 25, 2008
SOURCE: Brother dcp-150c, black ink wont work
Ink may be new, but their nozzles may be blocked; depending on manner of storage. To be sure apply a folded tissue paper to the ink nuzzle and press firmly. If the tissue comes off well blotted with ink it means you still have a good amount of ink in it and the nozzle is not blocked. If not blotted or scantily blotted, it means ink is really low or nozzle is blocked. To be very sure of this, place nuzzle in a plate/saucer with a bit water so that the nozzle is soaked. Leave for about 10 minutes. Then apply the tissue again. If still not well blotted it means ink is really low or empty. If new you should return it for a replacement. In the case of blocked nozzles, the procedure may be repeated over to get results.
Posted on Feb 14, 2010
  • 526 Answers
SOURCE: i have replaced my empty ink cartrages, but when i
two possibilities, first check to make sure the inks are really there. take the cartridges out and look at the little plastic window on the cartridge and see if you see ink. if you dont, you will need to get a new cartridge again, if you do see the ink, most likely the sensor board is damaged. Usually this damaged because of generic ink.
thanks
Posted on Jul 25, 2010
Testimonial: "thanks for the info,i have double checked and there is ink in the cartridge,so if its the sensor board i take it will be cheaper to buy a new printer "
  • 8 Answers
SOURCE: Brother DCP-195C Compact Colour Inkjet ... i have
Brother DCP-195C Compact Colour Inkjet error unable clean 46
Posted on Sep 07, 2010
  • 525 Answers
SOURCE: where do I get an ink absorber box for my brother
There is no reason to clean or replace. Just reset counter with this procedure.
the proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons OK, Menu, Mono Start one by one, followed by up arrow key four times. this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press blue MONO start button to select PURGE which requires it to be pressed a number of times before PURGE appears on the LCD screen of the printer
4. then use the up'down key and OK button to enter the reset code 2, 7, 8 and 3 keys to reset the counter : Note this does not overwrite the number next to PURGE on the LCD screen but once the last number is added it gets reset to 0000
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Posted on Feb 02, 2011
My brother printer j140w problem massage coming on screen "ink box full"
It may refer to the ink "overflow" box. When your printer cycles, it will dump a bit of ink which goes into a collection box. Most likely, that box is full and needs to be emptied, replaced, or whatever.
Dec 24, 2016 | Brother DCP-J140W
My brother DCP-J140W printer ink box full .. please help how to fix it.
The Brother manual says that you are required to replace the ink absorber box at a Brother Service Center. This is not an item covered by warranty.
http://www.manualslib.com/manual/437931/Brother-Dcp-J140w.html?page=44
Sep 09, 2014 | Brother DCP-J140w Wireless Compact Inkjet...
INK ABSORBER PROBLEM
Brother Printer Dcp-j125 Ink Obsorber Full
Jun 26, 2012 | Brother DCPJ125 All-In-One Inkjet Printer
How to do the clean unable 50 in brother DCP-165C
Hi Good day!! try this method
- Machine off
- Switch on the machine while holding down the "menu"button until all the leds are flashing on/off. Now you are in "maintenance" mode.
- press 80
- press the "mono start" button several times until you see "purge: xxxx"
- press "2783" in order to reset the purge counter. You will see: "purge:0000"
- press "99" to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don't replace this ink box!
Don't forget to vote thanks!!!!
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
How to solve the clean unable 46error of a BRother dcp-130c printer.
Clean unable 46 means you need a new flushing box. It's where the ink goes when it cleans the printhead, and yours is full. You need a shop to replace it.
Jul 18, 2009 | Brother DCP 130C All-In-One InkJet Printer
Open Questions:
19 people viewed this question
James Cagle
James Cagle
Jim Keysor
ctnozil
