Question about Dryers
My drum will not turn, could the belt be broke?
Ler3624jq1 is the model number.
    Top Expert:
  • Dryers Master
  • 53,620 Answers
Or loose
Posted on Sep 12, 2019
SOURCE:
kachbibi1
  • 979 Answers
SOURCE: DRUM BELT BROKE
To replace it won't be hard. Just make sure it is back on securely.
Posted on Jan 25, 2009
mikesagenius
  • 24 Answers
SOURCE: frigidaire FER211AS2 dryer drum belt
the washer has to be tipped forward. can access from bottom (and back).
Posted on Jun 03, 2009
  • 51 Answers
SOURCE: belt broke and drum will not turn...
replace belt order belt using modle number,,,check tension pullys also for damage,,,,,,,,,www.myabcspace.com/washerwizzards
Posted on May 19, 2010
heatman101
  • 43501 Answers
SOURCE: The drum on my Whirlpool
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on Sep 16, 2010
richroth
  • 9472 Answers
SOURCE: belt is to big, it will not turn the drum
What is the model number of the unit?
Posted on Nov 11, 2012
Why doesn't it spin or drain?
My guess is the belt probably broke or slipped off. There's often a belt that attaches the motor to the drum. If it's humming, then the motor is probably turning, but the belt isn't turning the drum (the drum is the thing your clothes go in).
Google the model number of your washing machine and try to find the owners manual. It may have directions for how to check/change the belt. Alternatively, you can just search for your model number and "belt change" and you should find something.
Or, you know, call someone to fix it...
Apr 02, 2016 | Washing Machines
HOW DO I PUT DRUM BELT ON A PORTABLE HAIER DRYER I HAVE ORDERED THE BELT IT CALLS FOR FROM HAIER COMPANY TWICE AND IT IS STILL TOO LONG MAYBE I AM PUTTING IT ON WRONG help please
Your idler pulley will take up the slack in it. It won't be real tight any way once on. If there is still a lot of slack when ou turn it on and the drum doesn't turn, then take it back. Take the old belt with you so that it can be matched uproperly.
Jan 25, 2015 | Haier HLP140E 115 volt portable dryer...
Asko washing machine won't turn or spin
Check the belt, its possible that the belt came off or broke. Get me a model number and I can find the belt for you.
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 04, 2014 | Asko Washing Machines
Belt is to big, it will not turn the drum
Nov 10, 2012 | Dryers
Dryer
You need to check the belt around the outside of the tub that turns the tub, the tention pully and the motor. is the belt broke? loose? motor turning?
Aug 17, 2012 | Dryers
Belt broke and drum will not turn
May 17, 2010 | Dryers
Frigidaire sensor gas dryer will not turn on, power supply and breakers ok, Makes a noise like it wants to turn on. Drum is free and moveable.
if you can move the drum by hand and it's humming it sounds like you have a bad motor or the belt broke and is jamming the motor and that's why the drum moves,you have to get in there and check it out,open the door and the model number should be there,next time send model number
Apr 13, 2010 | Frigidaire FGQ332ES Gas Dryer
Kenmore dryer drum will not turn.
This is commonly caused by a broken dryer belt. If you post back with your model number, I can explain to you how to verify and/or replace the belt.
Aug 29, 2009 | Kenmore 63942 Dryer
Dryer drum does not turn
Most likely the belt broke, replace the belt
Aug 14, 2009 | Dryers
Model number flse60rgs2 drum won't turn used
the belt has broke or come off and the squiling was the nilion pads the drum runs on are worn out
Jun 19, 2009 | Dryers
Dryers Logo
18 people viewed this question
Top Dryers Experts
Marvin
Marvin
Craig Butler
Craig Butler
