Question about Nortel Lands Phones
Step by step instructions on how to CHECK voice mail on a Nortel 3904 phone.
    Top Expert:
  • Nortel Master
  • 53,620 Answers
Google (nortel)(3904)(manual) without parens.
Posted on Sep 12, 2019
SOURCE:
  • 287 Answers
SOURCE: i need instructions how to connect my h350 blue tooth to my lg cu400 cell phone
With the headset power off, press and hold
the Call button for 6 to 10 seconds until the
blue indicator light turns on and remains
steadily lit.
Note: The blue light will flash as you press and hold the Call
button. Continue holding down the Call button until the blue
light is steadily lit.
Note: If you let go of the Call button before the blue light is
on and steady, ensure that your headset is off before trying
again.
The default PIN or passkey is 0000 (4 zeros)
You need to enable bluetooth on the phone and go into pairing mode, search for devices or similar
HIH
Posted on Jul 12, 2008
SOURCE: Remote Voicemail - How do you do it T7316
Call the phone system.
When you hear the voicemail greeting,
Press "* *" (thats 2 stars)
then just like sitting in front of the phone.
Posted on Nov 20, 2008
consultel1
  • 860 Answers
SOURCE: How do i set up a voice mail greeting on my nortel phone?
bodell,
The short version of getting to your greeting is:
Feature 981 or open voicemail key
your password
"8"for admin
"2" for greetings
"1" for record
"1" for primary greeting
"'1" to record your greeting
at the tone record your greeting
"#" to end recording
after you record press 1 to listen 2 to retry or # to accept
press "rls" key when finished
hope that helped.
Posted on Feb 09, 2009
  • 9 Answers
SOURCE: I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
Posted on May 21, 2009
consultel1
  • 860 Answers
SOURCE: How to change the time and date on nortel phone
Programming2.gif is done on 7310, 7324 and 7316 type sets.
Enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say A. Configuration. The 4 top line/feature keys are now used for programming.
Press "NEXT"(bottom right arrow)
display should read B.General Administration.
Press the show key (top right arrow)
display should read 1.speed dial
Press the next key 2 times(bottom right arrow) .
display should say 3.time and date
display should show current programmed time
Press the Change key
Enter in time in 12 hour format
press ok
press either Am or PM when prompted
press ok
press the Rls key when finished
Posted on Nov 04, 2009
I need to set up my voice mail for conssumer cellular on my Iphone 4
Good Morning, Here are Step by Step Instructions on Setting Up Your Voicemail. Hope This Helps..
You must set up your mailbox the first time you use your U.S. Cellular Voice Mail. Please ensure you are using your wireless device for the initial set up.
  1. Access your mailbox by dialing *86 or your 10-digit wireless phone number + SEND
  2. Follow these prompts to set up your mailbox:
    1. Choose English or Spanish as your language preference
    2. Set up your 4-10 digit password
    3. Record your voice signature
    4. Record or select your greeting
  3. Start using your Mailbox Password
To protect your privacy, the new Voice Mail system doesn't allow "easy-to-guess" passwords, including repeating digits (3333), consecutive digits (1234 or 4321) or ascending or descending even/odd numbers (2468 or 7531). Your choice of a unique password will be an important step in protecting your Voice Mail service.
Mar 10, 2018 | cellular Cell Phones
Nortel phone voicemail
Hi Oscar,
It sounds like your voice mail and your phone extension are either totally different from each other, or your voice mail isn`t licensed properly.
Sep 13, 2013 | Nortel Lands Phones
When outside people call us from a touch phone, it asks them to dial
Hi there
The Nortel and any other of PBX come with the voice mail, and you configure the voice mail as a phone ring.... If you can not pick up your phone in 3 time of ring then automatically your phone transfer on Voice mail and there as you setup..........In voice mail it asked which number you want to call and say the details Example: - Dail 1 to Drawing Room Dial 2 for Dinning Hall Dial 3 for Bed Room..
You just configure you voice mail system and solve you problem.
Thanks
Mar 22, 2012 | Nortel T7316E 2-Line Corded Phone
I have a KX - T7730, how to set voice mail and to forward calls to outside number? The manual instruction is too confusing...
http://www.walterbridge.com/manuales/KXT7720-User-Guide.pdf
Get that guide, it is very straight forwards.
Setting voice mail, is only done, through the phone, not by, the phone. page 6 shows you how to log/In out. You need to do this first to be able to access the voice mail. Again, in same page, it shows you step by step via a drawing of buttons, each row of words explains another way to call forward, you just press the corresponding numbered button
Mar 24, 2010 | Panasonic KX-T7730 Corded Phone
bodell,
your password
"8"for admin
"2" for greetings
"1" for record
hope that helped.
Jan 15, 2009 | NorStar T7316E Corded Phone
Voice Mail recording
the voice mail key is the #1 key on the keypad as well it should have an envelope icon on the keypad as well, just press and hold the #1 key and follow the step by step instructions to setup you voice mail.
Sep 28, 2008 | Sony Ericsson W850i Cellular Phone
SONY ERICSSON K850i
you will need to follow the step by step instructions when activating your VM
Sep 04, 2008 | Sony Ericsson W850i Cellular Phone
I have a cordless phone Philips CD 440. I cannot turn off the red flashing light after having heard and erased a voice mail. I need step bystep instructions on how to turn off the voice mail indicator...
It is the responsibility of the telephone company to shut off the voice mail signal. They have been notified and will fix the problem.
Thanks.
Aug 29, 2008 | Lands Phones
Going to voicemail
The phone you have can go on several different Norstar phone systems and you can have several different types of voice mail. Your voice mail (and possibly the phone system) needs to have programming changes, not the telephone. Your first step is to determine which Nortel phone system you have and also what model voice mail. You will need manuals for the phone system and voice mail. Hopefully you already have a programming or administration manual for the voice mail. Someone should have gotten this information when the system was first installed but that could have been many years ago.
What happens when you are waiting for that time? Do you hear absolutely nothing? Instead of being sent directly to your voice mail box, it may be sending callers to a voice mail branch where you would normally have a recording "press 1 for this, 2 for that" If there is no recording the system will wait for a response that the caller has no idea of and usually replay the message 3 times before defaulting to your mailbox (in this case a blank message). That is my best guess with the information I have from you so far.
Nov 01, 2007 | NorStar T7316E Corded Phone
Lands Phones Logo
11 people viewed this question
Top Nortel Lands Phones Experts
martin hogg
pbxinc
Sanjaya Sahu
Sanjaya Sahu
Are you a Nortel Lands Phone Expert? Answer questions, earn points and help others
