Question about Edge Computers & Internet
What voltage and current do i need for a diskgo! edge model hd-d1-u2 USB disk drive?
2 Suggested Answers
SOURCE:
bob_computer
  • 3153 Answers
SOURCE: I need a power supply for an Edge DiskGo! USB
Also ensure the current rating is the same or slightly higher
Eg 500 mA
Do not use one with a lower current rating as this can cause problems.
Posted on Sep 18, 2009
Hard drive crashed. New hard drive does not recognize Diskgo Edge, Suso I can restore
Hello Sharleen,
Your question is not understandable, If your hard disk has crashed, only professional data recovery services may help you out.
Make sure you go to DiskGO and get the new update for your drive, I some cases your hard drive needs updates to be recognized by your system
Sep 29, 2015 | Hard Computers & Internet
When I plug my HD in, the blue light comes on, but the motor isnt running.
Have you plugged in the AC power adapter? The blue light means it is connected to the computer but USB power is not enough to operate this drive.
Mar 25, 2014 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
Drive is plug in to the usb laptop drive port and don't see a new drive letter
If you are using Windows, go to Control Panel, select
Admin Tools, then Computer management. Now select Disk Management and wait for the display to populate.
There will be your new drive. It will need initializing and then formatting before you can use it.
Oct 27, 2013 | EDGE Tech Corp EDGE Tech DiskGO 500 GB...
Write protection
Write protection means you can view the information stored in it but you can't write and transfer the information to it.
For removing the write protection follow the below mentioned steps:
1. Right click on the USB stick
2. Go to properties and uncheck the read only or write only protection option.
May 12, 2013 | EDGE Tech Corp Edge Diskgo Mini - Usb...
Doesn't turn on
Some external harddisk contain switch in front of it. try switchin on
Regards
Jyothish
Feb 22, 2013 | EDGE Tech Corp 500GB DISKGO BY EDGE ULTRA...
I have a DiskGo! edge external model number HD-D2-U2 and i can't get my windows seven pc to see it. i am also unable to get it to format it so i can see it any ideas?
1. Check for possible damaged USB cable.
2. defective USB electronics
3. new USB case needed
4. can be purchased online
5.Check for Possible damage USB PORT. Try another port.
Jul 11, 2011 | Peripheral Enhancements DiskGO! Hard Drive
This was bought from a friend who no longer has the manual and I am still not quite sure what it is or what it does.
This is a case for 3.5" HDD that make any 3.5" HDD become external Drive. Here's the product description from Amazon :
The CoolMax HD-360-U2 USB 2.0 3.5" External Hard Drive Enclosure is portable size and excellent quality. The 3.5-inch hard drive aluminum external enclosure is specially designed for high capacity hard drives. And its aluminum material design is great for heat dissipation, so you don't need to worry about your hard drive overheating anymore. The HD-360-U2 Series gives you the freedom to work anywhere, no matter if you're in the office, at home or on the plane. This portable 3.5" HDD external enclosure provides maximum durability, flexibility and portability with various interfaces. Once you download your information to the HD-360-U2 series, you can connect it to any system and gain access to your programs and data files anywhere. With built-in hot swap technology, you can connect and disconnect the drive any time.
Features
  • Supports high speed data transfer rates up to 480/400 Mbps
  • Fully compatible with 3.5" IDE 133 HDD
  • Soft-start for slow turn-on feature prevents high inrush currents when initially powering capacitate loads
  • Anti-shock design, protect the hard disk from damage when moving it
  • Insulating designed PCB
  • Aluminum case transmits the heat quickly
  • Powered by a DC 12V-2.0 A transformer
You can visit the website : http://www.coolmaxusa.com/extenclosure.asp?item=3.5 for more details
Feb 07, 2011 | Coolmax HD-360B-U2 USB 2.0 External Drive...
Pc cant see my disk go edge 80gb
Hi and welcome to Fixyah,
The problem that you having was the enclosure of your Hardisk and the need to exchange it. I suggest to you if ever that is under warranty sentit back to your reseller or take the disc out and buy another enclosure for you to be able to get all your files.
Aug 11, 2010 | EDGE Tech Corp DiskGO 80 GB USB 2.0 Hard...
Edge DiskGo HD-D2-U2 External Hardrive not recognized by Vista
Hi
I having samsung E-250. I want to load dictionary in my mobile .How can I do that
Apr 08, 2009 | Peripheral Enhancements DiskGO! Hard Drive
Computers & Internet Logo
13 people viewed this question
Top Edge Computers & Internet Experts
Marvin
Marvin
Toby Lee
Toby Lee
Andrew Taylor
Andrew Taylor
Are you an Edge Computer and Internet Expert? Answer questions, earn points and help others
