I've Dixon 32 LCD so when I connect the Dstv cable it show "No Sync " message on blue screen
SOURCE:
  • 98 Answers
SOURCE: Akai LCT3201AD 32 in. LCD
This is not a Samsung/Akai tv, but it is a cheap Chinese "counterfeit" tv. Here is the makers' info:
APH USA Inc.
5900 Canoga Avenue
Woodland Hills, CA 91367
United States
Phone Number: 800 837 4685
Fax: 818 702 2289
Posted on Jun 09, 2008
SOURCE: LG LCD Flat screen 32 screen blank red light blinking cable on
The Lg lcd was srtruck by a remote and now looks like a small crak on the inside towards the bottom right hand corner and there is no picture but audio does work
Posted on Nov 09, 2008
  • 36 Answers
SOURCE: Connecting Compaq Presario CQ40 to LCD tv Toshiba REGZA '32'
Check your resolution output from laptop it maybe set to high for the TV to handle, also go to the Display Properties and ensure that the second monitor out is enable. Good luck!!
Posted on Aug 03, 2009
Benimur
  • 6966 Answers
SOURCE: I just connected my new
Hi and welcome to FixYa,
Initially, a couple of checks:
  • verify that the P/N switch is set to the color system of your country. N (NTSC) for US and P for most of Euroope and Australia;
  • depending on how "old" the TV, the Screen Resolution of the Toshiba may have to be brought down to the lowest possible setting;
  • additionally, the Screen Refresh Rate may likewise need to be lowered say 60 Hz;
  • all of the connections you mentioned are video connections. However, only 1 should be used. You may have to experiment (again depending on the TV) which setting & connection would give you the best picture;
  • offhand, the component connection (if applicable, the red/green/blue cable) would give the best connection followed by S-Video and last would be yellow (composite).
Please postback results of initial checks.
Good luck and thank you for asking FixYa.
Posted on Aug 07, 2009
leecom72
  • 4806 Answers
SOURCE: cannot connect acer extensa 5220 laptop to hd tv via aga
Hold down Fn and tap F5, you may have to tap F5 a couple of times to get it to switch screens.
Regards.
Posted on Feb 19, 2010
MY PC IS CONNECTED TO SONY BRAVIA KDL 32S5500 VIA 9 PIN VGA CABLE BOTH SIDES AND THE SCREEN STOP WITH INDICATION NO SYNC AND RESTORES AUTOMATICALLY. CAN SOMEONE HELP.KIND REGARDS
Change the cable with an other one and check. If any among the sync carrying wire inside the cable has a break, this kind of display can be.
Jul 01, 2013 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Ilo won't work with ps3
The set receive no signal at all. It will be best get it repaired by any experienced service technician.
Apr 22, 2012 | iLO 3200 32 in. LCD Television
No Sync message on the TV screen
Is the VGA port enabled? Have you set the computer to send data to the port? (The first may be part of the BIOS or the Device Manager. The second is in the graphics properties - right click on the desktop.) Reboot the computer to make sure it sees the new hardware with the monitor/TV on. Is the cable good? Try another one.
I hope this helps.
May 28, 2010 | Insignia 32" 720p Flat-Panel LCD HDTV
Cable input is not working
Sounds like you mabe be on the wrong source. Try hitting the input button on the side of the set to change inputs. Input channel up or down find tv hit input again. If on the wrong input you will only get a blue screen and message no signal that will apear for a few seconds.
Sep 21, 2009 | Polaroid TDA-03211C 32 in. LCD HDTV
Green purple and blue bars rolling through screen
It is probably the main total assy needs to be replaced.
Jun 26, 2009 | Samsung LN32A550 32 in. LCD TV
''no signal'' message on blue screen after watching for 10-30 min
First try another signal input like a DVD player or other source, is the signal displayed ok? Then you have lost the signal on one input from whatever the device is.
Mar 16, 2017 | Spectroniq PLTV3250 32 in. LCD TV
I cant see anything on my vizio 32 inch television
I just spent an hour trying to fix the VIZIO with the same problem. The screen had no picture at all, but could hear the sound perfectly!! But we i figured out the solution! UNPLUG THE CABLE BOX AND LET IT RE-BOOT! and it WORKED!!!!!
Aug 05, 2007 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
12 people viewed this question
Top Televison & Video Experts
Ekse
