Question about Panasonic Audio Players & Recorders
HOW MANY WATTS OF SPEAKER OUTPUT OF PANASONIC VX 900
Gt5 12 inch 275 watts how many watts of amp best?
Depends on what output your stereo is. If you underrate the speakers (speaker watts is less than stereo output), the unit will sound louder for a while, then you end up blowing your speakers with the excess distortion. If you overrate the speakers (speaker watts is higher than stereo output) the speaker will not operate correctly and the distortion can damage it also. Its best to get a close match. Slightly higher is better. It is important you know actual wattage output not PMPO ( Peak music power output) A lot of stereos are rated at PMPO. The higher number sounds great but in reality, the figure is the MAX output and by then the sound is distorting badly. Distortion ruins more speakers than anything else...
Oct 11, 2013 | JBL GT4-10 Car Subwoofer
IM67 sound system
The center speaker 900 watts, the two speakers on sides 300 watts each and the subwoffer 500 watts. Total of the speakers power 2000 watts.
Sep 02, 2012 | Fellowes AE10 Amplifier
I bought a new panasonic home cinema model number sc-pt480eb-k. Its supposed to be 1000 watts but the output it doesn't match that output at all even with all the speakers on. What maybe the cause of this...
Hype on the part of the maufacturer's published specs.
http://service.us.panasonic.com/OPERMANPDF/SCPT480.PDF
Look at the Power Comsumption spec on page 22. "90 watts"
According to this post, 45 watts...
http://reviews.cnet.com/home-theater-systems/panasonic-sc-pt480/4507-6740_7-34024832.html
It would be a miracle indeed to extract 1000 watts of sustained power in any form, be it heat, light, motion or sound from a unit that uses anything less than 1000 watts of electricity, assuming 100% efficiency. Not to mention the dreadful 10% distortion level they use to get that figure.
To say it pushes 1000 watts is dishonest and preys on the gullible.
Apr 10, 2011 | Panasonic Audio Players & Recorders
The left side main output won't put out any sound on my Denon AVR-900.
connect your right speaker cable to the left output, if the sound comes out then the problem is on the left speaker ( the cable or the speaker itself ), but if still no sound, then the problem is on the power output of the unit, need to repair them
Oct 20, 2009 | Denon AVR-900 Receiver
Can i use panasonic SB-AK57 speaker (6 ohm) with yamaha system RX-V663 (8 ohm) ?
yes only that the current will be less on the load.
no problem you can use .
also consider the watts of the speaker and the amplifier dont forget. the speaker should have more watts rated than amplifier output watts
Apr 25, 2009 | Yamaha NS-A60X Main / Stereo Speaker
Speaker amplifier calculation
for $85 i can sell you an Almani 900 watt 2 channel amp i would stay way away from those 3 brands they are all really poor quality and i can get you any major name brand cheaper.
I can get you a hifonics 4008 amp (800 watts peak 100 watts per channel rms) for $100 shipped with full factory warranty. you find an amp you like and i will get you a price. I am a factory wholesale distributor for most brands.
Jan 08, 2009 | Legacy 2 Channel 1600 Watt Bridgeable...
How do i wire a qvc subwoofer to a 3000w 1ohm stable monoblock amp
depends on the amplifier if you have a mono block amp or a regular 2 output amp if it is 2 output make sure to bridge and that means the negative to one output and positive to the other output then need to find out the rms on the speaker. the amp should have the ability to adjust it you might want to get a digital multimeter set it to watts and make sure you only set it to the RMS of the speaker because max handling should be the 1800 and usually the RMS is half the max so it should be 900 w again it depends on the amp and were the adjusting knob is and or if it has one
Nov 04, 2008 | Car Audio & Video
Sound
Hi monmax,
I hope you are aware that in bridged mode your amp will become monaural (single channel, double power). If you still wish to bridge it:
Switch of power.
Set mode switch behind amp to "bridge" position.
Connect speaker positive to CH1+ve terminal of amp output and connect speaker negative to CH2 +ve terminal.
Be aware that now, in bridged mode your amps output power delivery is 1100 watts for a 4 ohm speaker and 900 watts for an 8 ohm speaker. Make sure your speaker can handle that.
Peace
Jango.
Mar 03, 2008 | Crown CE1000 2-Channel Amplifier
13 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
John Wardlow
John Wardlow
Level 1 Expert
Ekse
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
