Question about Cell Phones
I purchase a Fashion Case and my phone does not fit it.The number on the case is HB1822819HEis10P.
    Top Expert:
  • Cell Phones Master
  • 30,503 Answers
There is no question posted.
Posted on Sep 23, 2019
  • Making more cash just by doing an easy work in part time online using laptop or PC from $14-k to $16-k. Now its time for you also to get this and start earns online by follow instructions on this web......http://xurl.es/vc4tv
Posted on Oct 15, 2019
SOURCE:
Benimur
  • 6966 Answers
SOURCE: pvs12701b need a power cord and case
As have been posted here and here of similar concerns...
You can try calling Target Customer Service 1.800.440.0680 and inquire cost & availability of the charger for the TruTech PVS12701.
Additionally, you may want to contact the manufacturer direct.
ALCO Electronics, Inc.
8392 Six Forks Rd., Suite 104, Raleigh, NC 27615,
(800) 252-6123)
Should you need direct Customer Support, please try here.
Alternately, you can just look for an AC adapter/charger that has the following specs:
Input Voltage - your country's standard AC mains;
Output Voltage - 12VDC
Output Current - at least 1.5 Amp (the higher the better)
Connector - one that will fit and match the polarity of the TruTech PVS12701. (am guessing crown type center positive, pls confirm with the store. It may also help to bring along the unit when doing the purchase over the counter).
Hope that this be of some help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
  • 921 Answers
SOURCE: how to fit bike into case
take front wheel off, turn handle bars sideways or off and let hang and remove both pedals...remember pedals loosen the opposite way...oh and take seat off or lower it.
Posted on Oct 05, 2009
SOURCE: Singer 4562 t bobbin case won't fit properly, what am I doing wro
Make sure the bobbin case sets sort of on top and not under the ridge of the metal ring. There is a small latch on the upper left of the bobbin case. It is metal. rotate the latch to cover the bobbin case and this should stabilize the case without making it immobile
Posted on Aug 01, 2010
  • 3278 Answers
SOURCE: I recently purchased a new
Hello.
Unfortunately, there doesn't seem to be a way to disable that function. But, there is a $.99 app called Dock Blocker that would prevent the Droid from going to that screen when using a holster or tight case.
Hope this helps.
Posted on Mar 15, 2011
SOURCE: does the Singer Fashion Mate 252 use a bobbin case?
yes, it does. if you don't have a bobbin case or need a replacement
check with these sites
sewingpartsonline.com
sew4less.com
if you need a manual check with singer
Go to the singer website
Go to the home page
Go to customer service--click on it--it will show a small menu--click on instruction manual
In the box put the model number (example 252) & click search
Posted on May 30, 2012
Find telephone number of Brenton isitt
sorry we are not the phone company .
Nov 20, 2016 | Lands Phones
Will a LG4 case fit a LG G Stylo phone?
Amazon.com: Questions And Answers: Does lg4 cases fit lg g stylo ...
www.amazon.com/Does-cases-fit-stylo-phones/.../1?_...
Amazon.com, Inc.Sep 5, 2015 - Probably not. The case is fitted perfectly to the G4's curved body. It would not fit on the G2 or the G3 either. Amazon Customer answered on ...
LG G Stylo Case Cover Accessories LG Stylus LS770 Case
Jan 01, 2016 | LG Cell Phones
I have a singer fashion maker rotomatic sewing machine..its bobbin case is broken..i have purchased it but don't know how to install it
I believe that is top loading Apollo bobbin case if so, facing the front of the machine underneath bobbin cover/door there should be a bracket on the left (holds bobbin case) move it back, set case in with the cut out pointing to the back of the machine, you may have to wiggle it a bit until you feel it is seated the move the bracket back over the bobbin case
Oct 31, 2015 | Singer Sewing Machines
I ORDERED A LONG MONK DRESS IVORY SIZE 12 ORDER NUMBER JP2015040374
1: the order number is not an indicator of what you ordered...this number is only meaningful to whom you placed the order 'With'
2: If you have the gown in your possession, you may wish to have it professionally altered to fit by a skilled seamstress. In such a case, a larger size could be fitted closer to your fit than trying to expand a smaller size.
3: fashion online doesn't tend to be available for long periods of time. it is possible that the original manufacturer is out of business, making other styles, or any number of frustrations..... if you are looking to go smaller, having more material to work with is a blessing. But it may cost alteration
Apr 02, 2015 | Clothing
My new case won't close correctly as if too small. I got from Amazon and was informed it fit iphone 5s. Is this wrong or what can I do. I watched all the videos and retried several times to get it to fit
It is possible they sent you the wrong case. I would say call customer service. There is a number on phones that will tell them exactly what model your phone is, including any carrier specific changes, year to year differences and so on.
Jun 11, 2014 | Griffin Technology Survivor Catalyst...
Bobbin problems
I can only think of one problem and that is that you have not fitted it properly. Open the bottom section, remove the bobbin case with the cotton reel and with your fingers press against the parts left behind. You may find something is loose, therefor not fitted correctly. You can also run the machine whilst the bobbin is out and listen if there is any noise or anything shaking. Refit everything taking care that the parts fit tightly.
Jan 10, 2014 | Sewing Machines
The end of my replacement watch band is to wide
If you are talkin about the end piece that attaches to the case...and its too wide then it must be cut down to fit! Any reputable watch repair shop should be able to do that for you! You could try it yourself but its very easy to scratch the case and/or band!
Jan 17, 2010 | Timex Men's Fashion Classics Easy Reader...
I cant get my case to fit my nokia 7373. i cant work out how it fits on at all with out braking the phone! can you help me?
What kind of case is it???
If its a housing you will need to take the phone apart to fit it...
If you need a dissassembly guide let me know?
If its a crystal case, they just clip on, if its a leather case they just slide on and if its a pouch case it just slips in :)
May 13, 2009 | Nokia 7373 Cellular Phone
MOTHERBOARDS THAT CAN FIT A ADVENT T9102 CASE
The Advnet case you have is a micro ATX (mATX) case. I would suggest that you purchase an inexpensive ATX size case. You'll have more room to work and the potential for better air flow for cooling.
Feb 01, 2009 | Computers & Internet
Cell Phones Logo
85 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
Are you a Cell Phone Expert? Answer questions, earn points and help others
