Question about Samsung Tablets & eReaders
Limited accedd to my settings and total changeswith the home screen with the apps lost screen saver. All that after rebooting my battery. I have a samsung android tablet
6ya staff
SOURCE:
brimknows
Jason Fisher
  • 10 Answers
SOURCE: my android tablet is "frozen". Will turn on but
has anything been deleted from it when it has been plugged into a computer or has anything been deleted from the device itself from its root directory? if not and its gone like that by itself, it could be corrupted software or a missing root file which is usually bad at first, now what i know about some tablets is if it wont work theres a recovery file usually internally but this is in some tablets only that ive read about, i also have one but havent needed to try to restore it and it can be done from an engineering mode, this is possable by pressing the power button and another button like the home button at the same time once the unit is off untill it turns back on with options, but as for some models im not sure of but i will have to look this up at some stage as i am working on tablets at this time so unless you know what you are doing i wouldnt attempt it, once i have gotten through some tablets ill be able to give a better resolution on this subject with others. the advice ive given wont work for all as pressing power and home will start different options up on different tablets and versions.
Posted on Oct 26, 2011
lanloony md
SOURCE: every time I open my galaxy tab. I can not access
touch and hold on pressing the home key until a task manager note will pop out end the recent tasks or uninstall the programs that u suspect making problems. my galaxy was having problems with viber and what's up communication apps i uninstalled them and the problem was solved automatically
Posted on Nov 04, 2011
White Zombie
  • 4961 Answers
SOURCE: i need to reboot my mid android 2.2
push on power + home button on the other side and until it reboots the device.
Posted on Aug 21, 2012
Phreak Show
SOURCE: my cruz tablet 103 won't keep app open, it just reverts to home page. Any suggestions?
You need to update your tablet, or update the programming on your tablet. Apparently all the android 2.2 tabs are considered "legacy" models and don't support the newest google and java script. Since this is what the net primarily uses, those of us with the Cruz are hosed.
Posted on Oct 13, 2012
scamper_69
scamper_69
  • 11 Answers
SOURCE: Android tablet stays in Android screen
Try to do a hard reset on the tablet. Since you cannot get to the menu options, you are going to have to do it through external keys. Here is how to do a hard reset using the external keys:
1. Turn tablet off. You may need to use two hands in this process to press and hold buttons properly.
2. Turn on the tablet with power button, wait a full 2 seconds from the time the tablet starts showing the manufacturer logo, then press and hold the down Volume key. (you should not hold down the power button after it turns on and logo appears)
3. "Android Recovery" will appear on top of screen if timing is done correctly. Release volume button. (if you continue to press volume down at that message, the message will cycle through "RSD, Fastboot, and back to Android Recovery. Make sure message states Android Recovery before you go to next step). If stuck at a RSD protocol or Fast boot screen, reboot the tablet by holding power button then pressing the volume up)
4. While screen states "Android Recovery", Press volume up button, the screen will say "Entering Android recovery mode" and a few seconds later an Android robot graphic will appear alone on the screen. Release buttons
5. Hold down power button and then press the volume up key together to see the Android Recovery screen menu selections
6. Use the volume buttons to move up and down through selection in this menu
7. Using the volume down button, scroll down to "Wipe data/factory reset"
8. Tap Power hard key to select option
9. Scroll down to select "Yes, delete all user data"
10. Tap the power button to select. Wiping and formatting data will take a few minutes.
11. You will return back to the Android recovery screen menu.
12. Tap the Power button to "Reboot system now" which will power-cycle tablet and eventually power back on to the Initial Set-up / Welcome screen present when you first turned on your tablet.
Posted on Feb 27, 2013
How do I unfreeze a Google app page?
Reset the App
1. Double-click the Home button. This minimizes the app and displays the iPad's multitasking screen.
2. Drag the stuck app upwards on the screen. This forces the app to close and removes it from the iPad's memory.
3. Press the Home button to display the iPad's home screen. Tap the app's icon to relaunch it. Any unsaved data, like words you typed in a document or progress in a game, is lost, but the app opens and should respond normally.
Apr 21, 2015 | Apple iPad Tablets & eReaders
Samsung Tablet GT-N5120 I cannot find an Android App which allows me to listen to Radio 5mbs 99.9 in Adelaide Australia. {mp3 or AAC]. Can listen on desk top and laptop PC, but not tablet. Have tried...
I am using Battery Doctor right now. I have also tried Batter Saver by AnTuTu and GO Battery Saver by GO Launcher Ex. Check the reviews to see what sounds good to you.
Have you tried the Tunein app? I just tried it on my Galaxy Mega 6.3 phone was able to listen to 5MBS.
Dec 05, 2014 | Samsung Tablets & eReaders
How do I take my zeepad 7drk off demo
On your home screen tap the the app button,then tap the screen saver app. Tap Enable Screensaver to turn the screensaver mode on or off. Then remove the check to "service enable" check box.
Sep 12, 2014 | ZEEPAD 7DRK Dual Core 4.2 Blue Android...
How do I remove Demo from screen of my Zeepad?
here is a potential solution:
  • On the home screen tap the the app button
  • then tap the screen saver app.
  • Tap Enable Screensaver to turn the screensaver mode on or off.
  • Then uncheck the "service enable" check box.
Sep 07, 2014 | Tablets & eReaders
How do i lighten my screen
if you have it set to maximize your battery life, aka battery saver, it will automatically darken the screen. you must you must turn off energy saver settings and manually enter brightness level.
Sep 03, 2014 | Samsung Tab Tablets & eReaders
No sound on ipad
1. If you have no sound at all, even in the Music App, try rebooting the iPad.
Reboot the iPad by holding down on the sleep and home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider if it appears on the screen - let go of the buttons. Let the iPad start up.
2. If you lost sounds for keyboard clicks, games or other apps, email notifications and other notifications, system sounds may have been muted.
System sounds can be muted and controlled two different ways. The screen lock rotation can be controlled in the same manner as well.
Settings>General>Use Side Switch to: Mute System sounds. If this option is selected, the switch on the side of the iPad above the volume rocker will mute system sounds.
If you choose Lock Screen Rotation, then the switch locks the screen. If the screen is locked, you will see a lock icon in the upper right corner next to the battery indicator gauge.
If you have the side switch set to lock screen rotation then the system sound control is in the control center. Swipe up from the bottom of the screen to get to control center . Tap on the bell icon and system sounds will return.
If you have the side switch set to mute system sounds, then the screen lock can be accessed in the same manner as described above.
This support article from Apple explains how the side switch works.
http://support.apple.com/kb/HT4085
3. Try cleaning the dock connector opening of the iPad with a soft brush and just a little bit of rubbing alcohol.
4. Reset all settings. Settings>General>Reset>Reset All Settings.
Aug 12, 2014 | iHome Ipad/ipod/iphone Rechargeable Mini...
What can i do to fix my 7inch polaroid tab after downloading android armour nd battery booster it shut off and turns back on but while trying to load it shuts off again?
Might be your tablet not supported to that app or possibly it should not be a appropriate application :
So download this app from play store
Battery Doctor(Battery Saver)
and if this fails
possibly problem in you tablet software go to replace it .....
May 14, 2014 | Polaroid Tablet Computer PMID701
Candy crush game Helpline Call 1-8O5-225-669O We are 24x7 Available Call Now
Double click the home button to bring up all the open apps on your iPad. They will list in a line across the bottom of the screen. If you are on iOS7 or later you simply swipe the screen shot of the app upwards to close the app completely. Then go back to your home screen and open the app as you normally do. This should force the app to reboot and work as intended.
Apr 26, 2013 | Apple iPad 2
Tablets & eReaders Logo
43 people viewed this question
Top Samsung Tablets & eReaders Experts
Eric Rotmil
Eric Rotmil
Jerry Greenberg
Jerry Greenberg
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
