Question about Refrigerators
My 4 door sandstrom fridge freezer displays E1 Error. What could that be?
    New Friend:
  • 6 Answers
Check the fan, make sure it is spinning. Might also check for dust buildup in same area.
Posted on Oct 03, 2019
SOURCE:
SOURCE: fridge display
the high voltage baord is bad. order part # 12920710 and replace.
Posted on Apr 19, 2007
SOURCE: Fisher and Paykel model RF610
The F24 error show that the sensor in the ice maker is out of normal ranges. The usual fix is to replace the sensor in the ice maker.  Also worth checking it to see is the water to the ice maker has frozen up in the value (switch the fridge off for a day). If the error still exists after that you will need to replace the ice maker sensor. You have a 2 year warranty on these parts so the fix should be free.
Posted on Mar 24, 2009
ZJLimited
  • 17970 Answers
SOURCE: Subject: 'New' Kenmore bottom freezer
This is a bad fan motor (click here like a sample replacement) inside the back wall of the freezer, you will need to replace it with part number that could look it accroding with your model. You can order the parts you need from the following places:
- http://www.apwagner.com/
- http://www.repairclinic.com/
- http://www.searspartsdirect.com/
So, according with your comments, if your device has few months, before to take off some part, I suggest contact your dealer or technical service keeping under warranty service.
Hope this helps.
Posted on Mar 09, 2011
  • 170 Answers
SOURCE: I have a sandstrom SDW60W10 and its showing a E1 fault code
Unplug it wait about a couple minutes then plug it in. It should be to rest the computer in it. Hope this helps.
Posted on Dec 12, 2014
  • 53746 Answers
SOURCE: Our Sandstrom American style fridge freezer is making a really loud vibrating noise from the back of the freezer area. We've had the fridge for 5 years-never made this sound before. What could it be?
compressor mounts loose and vibrating on the frame
Posted on Mar 18, 2017
My door alarm on Kenwood fridge/freezer beeps when I close the door and freezer temp flashes -88 before going back
Hi Both - I had this problem this week. Fridge is under warranty.
Engineer visited today and said it's the wiring loom to the door display.
On inspection part of it was worn meaning power being disconnected during opening & reconnecting on closing. The reconnecting of the power lights up the display but it looks like an error.
He's ordered a new wiring loom as he suggested fixing it doesn't work well.
Until the loom is replaced he's unplugged the door connector to stop the beeping, stop the display being turned off/on 50 times a day and reduce electrical risk.
Hope this helps - A
Jun 03, 2018 | Refrigerators
The sandstrom fridge freezer model sff4ds11 not working
check compressor and start up capacitor
Aug 16, 2016 | Refrigerators
Sandstrom manual shfjmc11
if you look at the rear of the ipod cover you will see a black plastic flap that is also the ipod lever when it is open, protruding into the door. you need to insert a thin knife blade and push this flap back so it clicks into position flush with its housing. this will take the lock off.
May 03, 2013 | Radio Communications
Errorcode EE in display. Whats wrong?
E1 - Freezer thermistor open circuit.
E2 - Freezer thermistor short circuit.
E3 - Fridge thermistor open circuit.
E4 - Fridge thermistor short circuit.
E7 - Evaporator thermistor open circuit.
E8 - Evaporator thermistor short circuit.
E9 - Temperature set switch open circuit
EA - No feedback from Baffle
EB - Fridge Baffle motor operating continuously
EE - Defrost time out
This was the only code listing with an EE error code - which is a Hotpoint - so if your's isn't a Hotpoint it is probably incorrect.
If you do have a Hotpoint Refrigerator then either the defrost timer is not functioning correctly or your heater element is malfunctioning.
Jun 20, 2011 | Refrigerators
Kenmore Elite model # 795.77564600 refrigerator stops cooling; display on left side door reads ER FF
This is an error code that pertains to the evaporator motor but could also be the main board.
If the evaporator motor is running, the main board will probably need to be replaced.
It could be a wiring problem but it's not very likely.
If the motor is not running, some voltage checks will need to be made, at the motor and board, to determine which component has failed.
These checks require a meter and can be difficult to make, even for a technician.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 15, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio Fridge - Getting ER F5 error on display
Er-FS error code: Failure of freezer sensor.
I have been finding the fuseable link in the defrost system on these models open preventing the defrost cycle.
This would involve removing the freezer back panel and removing the sensor and fuse from the evaporator.
It's just a plug in.
May 23, 2009 | Kenmore 73503 Stainless Steel Bottom...
LG LRSC26923TT freezer not freezing error display
You have a defrost problem that requires a service call from a qualified LG technician.
Apr 02, 2008 | LG LRFD25850 French Door Refrigerator
Samsung SRS2028CVW fridge freezer
check out this samsung diy repair channel on youtube ... some great stuff on samsung
samsung fridge freezer problems
Nov 02, 2007 | Refrigerators
Refrigerators Logo
91 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Marvin
Marvin
