Question about Solar Electrical Supplies
600lb GW Feeders&GW Solar Panels for feeders.Question,runningfeeder 6seconds twiceperday, howmuch exposure tosunlight doesthe solarpanel needtokeep the batterycharged?2spots limitedon directsunlight
Game Winner Feeders & Game Winner Solar Panels
    Sergeant:
  • 290 Answers
If you need more help, please visit at www.dieselgeneratortech.com
Posted on Oct 16, 2019
6ya staff
SOURCE:
pwmcdani
  • 10 Answers
SOURCE: need to replace casio atomic solar watch 2608 gw-300
Check out this YouTube video which walks you through the battery change process:
http://www.youtube.com/watch?v=ogCz2vjUKVg
Posted on Jul 14, 2010
tc7581
tim cargile
  • 6 Answers
SOURCE: Do solar panels get weeker over time?
You are correct they do lose the output over time. .Not knowing the specific type or brand of the panels the following is a general over all reply.
The manufacturer will give the specific amounts the panels will lose their efficiency. Newer panels I believe will 2-4% the first year then something like 1% per year. Newer panels usually have a life of 20 years. I am not sure about the smaller panels you have but I would guess they may be a little faster especially if your putting them up and down constaly.
Also make sure you clean them, that will make a very substantial difference especially since they are smaller in size and I am sure you know that shade on ANY PART of the panel may eliminate total sections of the panel producing power, depending on the type of [panels you have. Also check for scratches where you might be able to light through the panels as that may affect the output.
I would suggest a google search for manufacturer and model # and then review the spec sheets for the item. That is were you would find the information.If you don't and the company is still in business send them an email and they will let you know.
Good luck.
Posted on Oct 31, 2012
David Iezzi
  • 11 Answers
SOURCE: I have a Dell Latitude 600 laptop was broken hole where you insert the connector feeders and mistakenly had the opposite voltage connected with power supply
You most likely fried your motherboard by applying the opposite voltage.
Posted on Mar 06, 2013
Bill Boyd
  • 53755 Answers
SOURCE: I have solar panels, a battery and a electric grit connection. In case the grit connection is cut of, do I have power from the solar panels ?
check with you installer but the battery should be running the house and allowing the solar system to work as well
Posted on Feb 01, 2018
yasmine23563
yasmine
  • 5 Answers
SOURCE: how do I build solar panels
To get started, you must first decide on whether you want a 12v or 24v panel, and how big you want your panel to be. A large, flat, lightweight board made from quality wood makes for a good panel base.
Once you have decided on the board and size, it's time to acquire the solar cells themselves. This can be done through a variety of online merchants, including eBay. Try to keep the cost under $1.3 per watt.
After acquiring your solar cells, you can now put it all together. Lay out each panel where you'd like it placed on the panel, and trace around each one with a pencil. After doing so, drill a hole where each panel will go so that you have a space for the wire for each panel to come through.
When you are done planning the location of the panels, move on to wiring them together. This requires a soldering iron. Solder the positive lead of the wire to the negative lead of the next cell. Repeat for every cell until you have created a circuit that boasts a voltage of either 12 or 24 volts.
For the deep study, you can visit the site below:
https://solargenerator.guide/everything-about-solar-panels/
Posted on Jun 19, 2019
How hi should a humming bird feeder be?
Hi Andrew.
Hang the feeder approximately 5 feet above the ground, Make sure there is no foliage underneath that would encourage unwelcome guests, like mice, squirrels and even cats, to feed on the sugar water. If you wish to hang multiple hummingbird feeders, locate the feeders at least 10 to 12 feet apart.2.
read more at this link.
At What Height Should Hang Hummingbird Feeder Hunker
Jun 30, 2018 | Birds
Do solar panels need direct sunlight to work?
No. It will work in with diffused light too. Some sensitive ones will generate voltage even at moon-light.
Electro help
Nov 09, 2014 | Moultrie Feeders 12V Solar Panel
Can you splice 2224 wire to sub panel
The short answer is: Yes, you can. But, read the rest of this first.
Usually, you would want to move other smaller ampacity breakers up / down / over / as needed to create the required space for the larger ampacity feeder breaker to reach the feeder wires that supply power to the sub-panel. This is preferable because these circuit have small amp loads (hence small wires) and it is easier to splice those wires with simple wirenuts instead of splicing the feeders.
I can't see your installation, and you didn't give a great deal of details - so this last part may not apply to you. If you must splice the feeders, make sure it is an electrical box - if not done in the panel itself, a junction box that is approved for the location type, size and number of conductors that enter and leave the box can be used.
Nov 17, 2012 | Electrical Supplies
I have heard that using an elevated feeder is good for dogs. Is this true? What makes them good to use?
There are people who both support and deny this claim. Many people insist that elevated feeders help create better posture, digestion and can relieve stress on your dogs hips and shoulders. Others say that elevated feeders can cause severe bloating in your dog. I recommend checking with your veterinarian first.
Aug 26, 2012 | Alessi Pets - Others
Do feeders generally work with batteries or do they need electricity?
I can tell you that most of them work withbatteries. I wouldn't recommend getting one who needs electricity since you notalways going to have plugs closer to the pet's cages or areas. If you are goingaway for a while I wouldn't take the solar ones, especially in winter or fall.
May 15, 2012 | Pets - Others
Paper jam
Dear Friend
the paper jam in the machine is due to the rubber feeders present in the tray bin that pick the paper up and forward them.
so i suggest them to take a cloth and dip it in water and then (just like moisturized cloth) resin it completely that it do not form droplets that gets into the copier.
now switch OFF the machine and try wiping the rubber feeders with the cloth.
you will see a lot of darkness on the rubber feeders.
clean all the runner feeders with it and close the machine.
now your problem will be solved for paper jams.
thankyou
Gagan Gupta
Is that Useful?
Mar 18, 2011 | HP Office Equipment & Supplies
Paper jam
dear ram gupta
thankyou
Gagan Gupta
Mar 16, 2011 | Sharp AR-5316 Advanced Digital Imager...
Need to replace casio atomic solar watch 2608 gw-300
May 14, 2009 | Casio Watches
Electrical Supplies Logo
Top Solar Electrical Supplies Experts
Sheldon Dedek
gggg
ray gallant
ray gallant
Are you a Solar Electrical Supply Expert? Answer questions, earn points and help others
