Question about LG Cell Phones
I have a problem with lg c320 requesting security code
I try default pin 1234 & 0000 but its not working
  • sheva420
    sheva420 Oct 11, 2019
    Maybe a hard reset. Press Power button to switch on device. Go to Standby screen or open Dialer. Type in this code: 1809#*101# ,or 2945#*101# Left Softkey to confirm whole process. Done, phone is ready to use.
  • 46 Answers
You can try 277634#*# and do a factory reset from this menu.
Posted on Oct 10, 2019
Testimonial: "I try the code but it only request for four digit only"
SOURCE:
  • 83 Answers
SOURCE: default security code for this phone
default code is usually 0000, or last four of your number.
Posted on Apr 24, 2009
taran_2005
  • 10515 Answers
SOURCE: What is the default security code and PIN for
Default Security Code - 00000000 or 0000
Regarding PIN, there is no default PIN set up by Samsung. If you wish, you can select a PIN for your handset. The procedure is :-
PIN (Personal Identification Number) code' is a security tool designed to stop unauthorised usage of a SIM card. You can set the PIN code on 'Security Settings'. You will then be required to enter the PIN code every time the handset is turned on.
Hope i helped you.
Thanks.
Posted on Sep 07, 2009
  • 909 Answers
SOURCE: i need the pairing code for LG KS360
The default pin code for most devices, especially headsets, is 0000 unless it was changed.
You should be able to go into the bluetooth settings on each phone, and find the security code there, or at least change it.
Posted on Sep 15, 2009
SOURCE: LG CE 0168 phone security code
http://www.lgunlock.net/LGunlockinstructions.htm
thank you i found reset number here
plz inform and give some money me
ramrolalbandi@yahoo.com
Posted on Oct 20, 2009
تليفون ال جى ce0168 ومش عارف افتحه ونسيت الباسورد
Posted on May 15, 2010
HELP, my old LG c320 is asking for a 4 digit security code. I have no memory of this and i'm in need of a working phone. Thanks.
besides the PIN number which you will have put in , there is a PUK code which protects the phone from more than 3 wrong pin number attempts
PUK codes are only available from your service provider
call them on another phone , provide proof tat you own the account and they will give it to you
Jan 02, 2018 | LG Cell Phones
Unlock code
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Nov 09, 2012 | Cell Phones
I have inserted a virgin mobile sim card into the nokia 6500 and after i punch in the pin number, it requests a security code. what is the security code?
by default the security code for all nokias is 12345 u can try it if it has not been changed.
it the default code doesnt work, search the internet for security code breakers. theae little apps find the security code when u connect ur phone to a pc running windows xp.
Mar 01, 2011 | Nokia 6500 Slide Cellular Phone
I need the pairing code for LG KS360
Sep 15, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Cell blocked
Securing your Shine
Secure your LG Shine and your account from thieves by locking your phone and your SIM card Losing a phone through accident or to a light-fingered thief is annoying, frustrating and potentially very costly, especially if the 'finder' uses your SIM card to make expensive calls. You can, however, lock both your phone and your SIM card with four-figure PIN numbers to prevent unauthorised use.
The first line of defence is to set a SIM card PIN. This means that whenever you turn on your handset you have to enter a PIN code before the SIM can be used. The default PIN code for your SIM is dependent upon your network; usually it will be found in a small booklet that came with the SIM card.
The PIN can be enabled, disabled or changed from the Security menu – but you only get three chances to enter it correctly. After those three, the SIM will get locked and can only be unlocked by entering the PUK (PIN Unlocking Key) which your network can give you. Enter the PUK incorrectly 10 times, and the SIM will be irrecoverably locked.
To activate a PIN code request, open the main menu by clicking on the scroll wheel. Click 9 to access the Settings menu and click 6 to enter the Security menu. The first item is PIN code request - click 1 or OK to open it. By default this will be set to off. To activate a PIN request, click 1; you'll now be prompted to enter the four-digit PIN. When you've done this, click OK, and if the pin was correct, you'll see the confirmation message 'Complete'.
To deactivate the PIN code request, you would simply select Off from the menu by pressing 2; you'll need to enter the PIN code whenever you change this setting.
PIN code request prevents another user from using your lost or stolen SIM card in their own phone. To lock your phone, and thus render it useless to a thief, you can activate Phone lock.
Two levels of handset locking are available. The first - called 'When power on' in the Phone lock menu - is to require an unlock code to be entered whenever the handset is switched on. This can be confusing and irritating when used together with the SIM PIN, so a second option is to only request the handset unlock code when the SIM card has been changed - called 'When SIM changed'. This means that if your phone is stolen, the thief can't use their own SIM card in it as the phone will need a PIN code to unlock.
To activate either option, go to the Security menu (clicking 9 for Settings and 6 for Security from the main menu) and click 2 to enter the Phone lock menu. Click 2 to activate When power on or 3 to activate When SIM changed. In either case you'll be prompted to enter the security code. By default this is 0000. Enter the code and click OK to confirm.
To change either code, go to the Security menu again (clicking 9 for Settings and 6 for Security from the main menu) and click 5 to enter the Change codes menu. To change the handset's security code, click 1 to select Security code, or to change the SIM PIN, click 2 to select PIN1 code. In either case you'll be prompted to enter the old code before entering the new code twice, clicking OK to confirm each time.
Jan 10, 2009 | LG Shine KE970 Cellular Phone
If your phone is blocked. You will have to take it to your nearest network provider outlet to get it unblocked.
If your sim card is blocked. You can go to your network suppliers website, where you can obtain the puck code to unblock the sim.
Dec 04, 2008 | Cell Phones
Lg cu400 cell phone IMEI # 011071003749585
The default lock code (security) is 0000. and default, PIN1 is 1111, and PIN2 is 2222
If you need further help let me know. If you get it wrong enough you will be asked to enter PUK code. Then you only need to call up your provider and they will assist you.
Thanks,
Lee
Jun 19, 2008 | LG CU400 Cellular Phone
LG CU400
Locking and Unlocking the Device: FOR LG CU 400
  1. From the standby screen, press Menu.
  2. Scroll to and select Settings.
  3. Scroll to and select Security.
  4. Scroll to and select Lock Handset.
  5. Select desired option:
    • When Power On
    • When Smartchip Changed
    • Immediately
    • Off
  6. Enter the Security Code, press OK.
    NOTE: The default security code is 0000.
Setting the PIN Code:
  3. Scroll to and select PIN Code Request.
  4. Scroll to and select On.
  5. Enter the PIN code, press OK.
    NOTE: Default PIN code is 1111.
Changing the Security Code:
  3. Scroll to and select Change Codes.
  4. Scroll to and select Security Code.
  5. Enter the current Security Code, press OK.
  6. Enter in the New security code, press OK.
  7. Confirm Security Code, press OK.
IMPORTANT: If the incorrect lock code is entered more than 3 times the phone will display "ENTER PUK". If this message is displayed contact Customer Care.
Nov 28, 2007 | LG CU400 Cellular Phone
Cell Phones Logo
32 people viewed this question
Top LG Cell Phones Experts
William Norris
William Norris
George Etukudo
George Etukudo
Sheldon Dedek
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
