Question about Black & Decker Garden
Where can I find blades for black & Decker DN 75 planer
    Top Expert:
  • Black & Decker Master
  • 54,189 Answers
Black & Decker would be a possible source.
Posted on Oct 10, 2019
SOURCE:
  • 163 Answers
SOURCE: Black and Decker 16 in Hedge Trimmer
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
rowdy45176
  • 2176 Answers
SOURCE: FITTING DETAILS FOR MAKITA PLANER BLADES
It depends on the planer blade set that you are using. If you are using the the 2 sided blades there is a guage that goes with it to set the blade depth before installing. I would strongly recommend that you go to Makitatools.com and type in your model number and download a copy of the owners manual for specific instructions. Let me know if you have any problems finding them
Posted on Mar 09, 2009
efs_perpends
  • 1996 Answers
SOURCE: Delta 12 inch thickness planer blade change
Go to this link and at the bottom center of the page insert your model number. You will be able to download the manual for that machine.
Delta manual
If your question has been answered, or I fixed your problem, please take just a moment to rate this post...thanks!!
Posted on Mar 31, 2009
rowdy45176
  • 2176 Answers
SOURCE: can not get a blade on the Black & Decker Navigator SC500
Go to Dewaltservicenet.com and in the middle of the page at the bottom find the looking for manual box type in your model number and on the next page click on the instruction manual section for this tool, it is 4 pages long but it does reference removal and installation of the blade. If I have answered your problem would you please rate my response accordingly and thank you.
Posted on May 18, 2009
  • 226 Answers
SOURCE: PHS550B saw blade change
MOST TIMES THERE IS A ARBOR LOCKING BUTTON ON THE HOUSING NEXT TO THE BLADE HOUSING.YOU HAVE TO HOLD THIS DOWN WHILE TURNING THE BLADE SECURING NUT TO LOOSEN OR TIGHTEN THE BLADE,OR YOU CAN DO IT THE OLDFASHONED WAY FIND A VENT HOLE IN THE BLADE,STICK A SCREWDRIVER IN IT LOCK THE SCREWDRIVER IN PLACE THEN TURN THE NUT(WHILE UNPLUGED OF COURSE)HOPE THIS HELPED
Posted on May 23, 2009
Black & Decker electric planer manual
what are you asking for? a manual for a Black & Decker planer if so there is a website called "produtools manuals 2.1" it has many manuals for many differant items. Goood Luck
Nov 15, 2012 | Masonry Tools
I'm looking for replacement blades for black&decker plane mod 21286 or part # 7696,i need set of bldes
Any Internet search will yeild sources. You may find that HSS blades are more $ than carbide ones, IMO because the carbide are old-stock and have not be repriced.
But first make sure you need replacement blades. Initially because the blades are reversable, and 2nd, either the adjusting height control is not functioning OR, and was in my case, the lower plate with 2 screws has slipped inwards. Since I believe the blades slide out after the top plate (3 screws) is removed, do NOT move the lower plates
Oct 27, 2010 | Black & Decker 2 pc. Planer Replacement...
How do i remove the blades from a black and decker 7696 planer
Solution of they-slide-out (losen any screw instead of removing same is always advised) is part of another answer on this site:
http://www.fixya.com/support/t6578544-looking_replacement_blades
BTW, my supplier of replacement belts can not obtain more belts..
Jun 17, 2010 | Black & Decker 2 pc. Planer Replacement...
Planer no. kw715 spare blades black and decker please supply
The replacement blades for a Black and Decker KW715 portable planer are Black and Decker part number X24192. It looks like there are a number available on Ebay.co.uk at the moment.
There are also third party replacements for these blades. Trend PB/29 blades should work as well.
If this answer was useful, please vote for it. Thanks!
Jun 14, 2010 | Black & Decker Tools & Hardware - Others
Planer is not feeding wood through without manual force
I had the same problem...sometimes you have to take the smallest amount off (1/64th) and it might work, otherwise your blades are probably dull. Try to feed the boards through the planer towards the sides, not just the center so they wear evenly across the length of the blades. They wear out very quickly, which makes this planer very frustrating. If you take the top cover off and inspect them, you'll probably see nicks in them and it's time to replace or rotate them. Each blade has two sides you can remove all the screws using the T-handle wrench from the top cover and flip them. Also, as the blades begin to wear, the planer will become louder and louder. That's another way to tell. When you install new blades notice how much quieter it is when you plane boards.
Nov 13, 2008 | Dewalt DW735R Reconditioned Heavy Duty 13"...
Garden Logo
29 people viewed this question
Top Black & Decker Garden Experts
gggg
Nick Olsen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
