Question about Maytag Washing Machines
How do I open the Drain pump for Maytag Maxima M washer from the back panel side?
Check under unit
6ya staff
SOURCE:
Ian Greenland
  • 351 Answers
SOURCE: removing front panel on maytag washer
some maytag panel just pull off from the bottom,they are just a tight fit.and some have screws under the hob.
Posted on Mar 21, 2008
David Coomer
  • 1073 Answers
SOURCE: washer won't drain
remove the fount panel it is held in place with 2 phillips screws located ant the bottom of the frount panel,
use a putty knife and locate the top holding clips push in with the putty knife and lift up on one side of the top repeat for the other side
once the top is lifted up push down on the frount panel and it will come off
pump on the right side check drain pipe for blockage also while checking pump
naturally drain the tub if you have a wet dry vac fastest way
Posted on Apr 28, 2008
Anonymous
SOURCE: my maytag front loader will not drain water oe comes on the control panel
On the 9700s it's even easier - three screws on the front bottom panel below the door, then use your hand to unscrew the large round handle in the front center. When you can't unscrew any more, pull gently and the filter / catcher will come out.
It's amazing how much stuff mine held - 4 breastfeeding shields, a pencil, a pen, a fake mouse, and lots of grey gunk.
Screw it back in, put the panel back on, and you're in business.
Posted on May 04, 2009
jumptrout51
steve
  • 3361 Answers
SOURCE: Maytag A612 washer washes, but will not drain
Replace the lid switch. Open the control console and find the lid switch in the center of the console.
Posted on Jun 30, 2009
Sea Breeze
John Tripp
  • 4656 Answers
SOURCE: Maytag side by side freezer drain icing
This is a pretty common problem. Sometimes the defrost cycle is not long enough because the freezer setting were too low. But most times this begins slowly until the drain finally closes and then the water has no where to go but the inside of freezer or refrigerator. I have more help topics to prevent a constantly happening over and over again. But you may have a blockage down-line from the freezer. So until you can melt the ice and pour a warm solution of water and clorox in the drain and it end up in the pan below the refrigerator I will hold off on that until I hear back from you, Thanks, Sea Breeze
Posted on Jul 14, 2009
Maytag maxima XL washer is not spinning out the water how can I fix this?
Pump, filter or drainage problem.
Check there is nothing jammed in the pump or the filter.
Make sure the drain is not blocked or running "up hill"
Mar 14, 2016 | Maytag MHW6000AW Maxima XL 27" White Front...
Error code f09 e01
Did you clean the tube that goes from the tub to the drain filter then the drain pump it is behind the front panel also make sure there is nothing in the drain pump stopping the impeller from turning.
Jan 29, 2014 | Maytag MHW6000XG Maxima High-Efficiency...
Maytag maxima washer won't drain
get to the back of the unit and take out the 2 screws on the back of the lid . remove the lid. look at the front electrical panel -remove the screws holding it in place. look inside the unit on the right and left side -- there may be 2 screws holding the front on - about 7 inches down. there may be two screws also at the bottom of the front panel. If the washer won't drain, should check the drive belt. If the belt is broken or if it isn't tight on the pulleys the washer won't drain properly, if at all. If the washer won't drain water check the drain hose. Be sure the hose did not get kinked behind the washer. Also, remove the hose from the pump and check it for obstructions. If the washer won't drain there might be a clogged pump or hose. It's common for small socks or other small clothing items to get into the water drain system and clog the hose leading to the pump or the pump itself. Remove the hoses from the pump in order to remove the article of clothing. Keep in mind that any water in the washer will pour out of the hoses when removed.
Jan 08, 2014 | Maytag Washing Machines
Getting E02 and F09 error codes on my Maytag Maxima MHW6000XW front load washer
Here is the manual. Hope it helps: http://www.applianceblog.com/mainforums/attachment.php?s=001fc13abc99c02a4aa812a23c01ac7e&attachmentid=13030&d=1381289434
Jan 05, 2014 | Maytag MHW6000XW - MaximaTM...
Machine will not turn on and door is locked.
Remove the back panel. The pump sits on the left-side of the opening. Remove the black hose from pump and the let the water drain out to open the door. You will need to take this outside to drain it.
Mar 18, 2010 | Maytag MAH6700AWW Neptune Front-Load...
Door is locked and will not open
1.) Take the washer outside. 2.) Loosen the two screws on the back panel and remove the back panel. The pump sits on the left-side of the opening. There's a black water hose with a metal clamp; 3.) squeeze the metal clamp with your fingers until it's loose enough to slide away from the pump. 4.) Separate the hose from pump and the trapped water will pour out and the door will then open; and 5.) clear any blockage from the drain hose and the pump.
Jul 10, 2009 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune door lock stuck!!!
Try these steps:
Jul 01, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Water will not drain form tub
does it sound like it wants to drain?
if the pump does run. you would have to remove the pump and clean it out. its possible that the impellars on the pump could be broken, meaning you would need a new pump. but usually its change, or small objects jammed in the pump impellar.
Jun 18, 2009 | Maytag MAH8700A Front Load Washer
I have a maytag neptune washer the water will not drain out of it
Check for obstruction in pump located at back of machine. Remove back panel and pump will be located on left hand side.
Feb 21, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Washing Machines Logo
50 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
