Question about Toshiba 32av700e 32" Lcd Multi-system Pal/ntsc
Toshiba 32AV700E TV have sound, no image. Backlight working. How to troubleshoot and repair? Thanks.
Hi, my tv is toshiba 32AV700E. My tv will display picture fine for some time e.g. random, 15mins, 30 mins, 1hour etc, after which the color will be discolored and slight double image seen. After tried to clean the LVDS cable and put in, the image now looks very bad and may turn completely black, with sound and back light still working. May I know what part is faulty? Thanks
    Top Expert:
  • Toshiba Master
  • 10,360 Answers
Try changing input or source if same bad board
Posted on Nov 05, 2019
6ya staff
SOURCE:
Anonymous
  • 129 Answers
SOURCE: Toshiba Color Television....now picture is black and white
Good day.
The missing color issue can be resolved by resoldering the loose contacts in your units circuitry. Your unit is still worth to be fixed.
Response is highly appreciated.
chris
Posted on Mar 24, 2008
SOURCE: tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Posted on Apr 16, 2008
Anonymous
  • 53 Answers
SOURCE: TV Color Distortion
Hello Sherry:
you will need to hav th unit repaired it ounds like there is a problem with your small signal board.
The Slash
Posted on Aug 17, 2008
Anonymous
  • 50 Answers
SOURCE: Toshiba 37AV500U randomly going black (almost sounding stuck)
Your tv has a problem inside of it, and it is intermittent that's why it goes like that, have your repaired repaired by a professional technician,
Good luck,
Posted on Jan 14, 2009
Jim Krause
  • 1779 Answers
SOURCE: 47inch toshiba lcd tv (HL167) black picture, but
Best to replace both at the same time . Yes they are easy if you can find the parts.
Posted on Dec 15, 2009
NO BACK LIGHT AND NO AUDIO ON TOSHIBA Model 50L2300U but can see and image when I take a flashlight to the screen
With both the backlight and audio not working. I suspect it's the power supply board.
You'll have to get a TV repair company. Get an estimate before bringing it in, and check reviews on the company.
If you don't know Electronics, don't open it up yourself! There are hazardous voltages even in flat screen TV's!
Jul 17, 2016 | Toshiba 50L5200U - 50in LED-backlit LCD TV
I have a Toshiba 50L2300U TV which has sound, but the screen is black. I believe it's because the backlight inverter is not functioning. What part needs to be replaced?
Hi Anonymous, The link below is a YouTube video showing how to fix a Toshiba television NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
https://www.youtube.com/watch?v=WtRuUBS9doE
Toshiba 55HT1U repair No Picture
May 05, 2016 | Toshiba 50L2300U
Toshiba led lcd
There is no 'bulb' in LCD/LED tv.
The back light is LCD or LED only.
The shopJimmy also point to the bad inverter and/or LED driver
you should evaluate the cost of part + age of tv vs new
Apr 03, 2016 | Toshiba Televison & Video
How to I remove the back cover on a Toshiba 50L1350UC LED TV. I have removed all the screws as I have on dozens of other tv repairs, but can't seem to see how to remove this back cover. Thanks.
Toshiba TV Repair - Replacing 26AV5 Backlight Inverter ...
? 2:36
https://www.youtube.com/watch?v=ZoAn6ovLVXc
Apr 22, 2013 - Uploaded by ShopJimmy.com
There are various ways to eliminate static electricity, but the most common ... Return the back cover to its original position and secure all screws. .... Hi I am having problem with my TOSHIBA46TL963 TV 3D LED TV WITH NO ...
Free Fix For Toshiba 50" TV That Will Not Turn On. - YouTube
? 2:20
https://www.youtube.com/watch?v=8-0nQ57Bvow
Mar 21, 2012 - Uploaded by rstarre ten g
Free Fix For Toshiba 50" TV That Will Not Turn On. ... Removeall; Disconnect. Watch Queue. Queue ... p.s. could they put more screws in that back panel? .... Now the TV turns on, so does theLED backlight, but NO PICTURE!
Toshiba TV Repair - How to Replace 75021540 Main Board ...
? 2:38
https://www.youtube.com/watch?v=AUOAQR_raTA
Feb 28, 2013 - Uploaded by ShopJimmy.com
Toshiba TV Repair Main Board Replacement for LCD TV Fix No ... Unscrew and remove the back cover. ... LCD & LED TVRepair - No Image & Blank Black Screen Flashlight Test - How to Fix LCD & LED TVs - Duration: 5:56.
Jan 17, 2016 | Toshiba Televison & Video
Hi I hv a toshiba smart tv it's two years old , it comes on but does not hv pic it does hv sound
if you choose the menu does it display menu items or is there no image at all? No image at all when you press menu would mean the backlight is likely not working and requires repair. If you do get menu items on screen check the image settings and ramp up brightness and contrast
Jan 14, 2016 | Toshiba Televison & Video
Toshiba 46RF350U , no image, only sound! what piece should i change?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
In some models of LCD TVS; the backlight inverter and its T'Con board will be a part of the panel itself, and will be a built-in type inside the LCD panel. If so, they can't be replaced. In this case; a panel replacement is the only repair. For some other models, the backlight inverter section circuit will be a part of the main power supply regulator [SMPS]. To such sets, the power supply section circuit too should be troubles hooted. Contact any service technician. The circuit will differ with models and versions.
Type in the brand name of your device, in the search box [at the top right] of the display window and the Search will start at once as you type in, and will show you all the related posts. It will make surf easy.
Mar 04, 2015 | Toshiba 46RF350U 46 in. LCD TV
Toshiba 37xv500p backlight fails
I have only ever done one, several years ago, but this you tube video should help
Mar 13, 2017 | Toshiba Computers & Internet
I have a Toshiba 32av500u HD LCD TV.NO picture
Its a backlight problem. Common with this model. Under warranty? If not, then its a service shop repair.
Mar 26, 2010 | Toshiba 32AV500U 32 in. LCD HDTV
Dec 15, 2009 | Toshiba REGZA 47HL167 TV
Toshiba 32av700e 32" Lcd Multi-system Pal/ntsc Logo
Top Toshiba Televison & Video Experts
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
