I plug my washing machine in and the lights come on but it does nothing I've tried changing capacitors but still get the same results what's wrong
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
SOURCE: Hotpoint WMA 48, tripped house rcd, no lights on and water heating noise.
If you are not sure what you are doing, call out an engineer and have the job carried out properly with safety testing at the end of the job!
Posted on Dec 09, 2007
Anonymous
SOURCE: machine freezing with three lights flashing.
HI JOHNNYHEFF,
JUST GOT A NEW HOTPOINT STARTED TEST WASH ALL THE LIGHTS FLASHED SO SWITCHED OFF TRIED AGAIN NO JOY. TECHNICIAN COME OUT SAID THE CIRCUIT BOARD WAS GONE, NOT GOOD NEWS FOR YOU BUT THOUGHT I'D LET YOU KNOW!
Posted on Nov 11, 2008
john_cross
  • 6277 Answers
SOURCE: i put a load in
'.........and since then the water has been in the washing machine.'
It is likely that the drain motor/pump has been unable to drain all of the water out of the machine.
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Following are my complete and hopefully 'coverall' pre-typed guidance notes for checking both the drain motor filter and the drain motor ;-0)
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Sep 04, 2011
chris fuller
  • 6 Answers
SOURCE: my beko washing machine fills and then just stops - the lights are on. belt is fine. i've tried resettinf, just drain, just spin, but nothing. any ideas?
its your motor and possibly could be limescale in the pump
Posted on Aug 08, 2012
I have a Hotpoint Aquaris WF000, 1000 spin washing machine and when I put it on the lights flash and nothing else happens. What could be wrong with it please
Hi
It seems to be a fault with this make of washing machine.
I changed the door lock and that seemed to cure it for a while. However it now seems to be doing it again.
What I have discovered is the following:
Turn the washing machine off completely at the wall and pull the plug out - leave it out for about one minute and then plug it back in and switch on. This should cure the problem and it will work again.
You may have to do this every now and again to clear some fault it has in the circuit board so leave some access to your plug socket.
I hope this helps.
Feb 24, 2015 | Hotpoint Aquarius WF000 Front Load Washer
Whirlpool AWE 2214 Washing Machine won't start
I need more info about the dryer. Does you dryer make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your dryer could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine....
Dec 30, 2013 | Whirlpool Washing Machines
Want wash or spin
I need more info about the machine. Does it make any noise when the start button is pressed, if you can hear the motor turning then more than likely your belt is either after slipping off the drum or breaking. you should be able to access the belt either by the back of the macine or the top to see if the belt is broke or just after slipping. Another problem it could be is that the capacitor in your macine could have blown. To test this you press start, open the door of the machine, spin the drum by hand and close the door before the drum comes to a stop, if the drum continues to rotate after you close the door then you know it is the capacitor that is blown, this needs to be replaced either by an electrician or a specialist as it is possibe to connect the capacitor wrong and the result would be the capacitor exploding damaging your hand. Always plug out the machine before opening the top or back of the machine.
Dec 28, 2013 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Microsoft Notebook optical mouse 3000 not working
Have you tried changing the port in which the USB wireless receiver is plugged?
Or is the receiver internal to the notebook?
If the receiver is internal, try updating the drivers for your machine by navigating to the manufacturer's support site.
If you plug a wired mouse into the machine what happens? If you get the same result, it may indicate a problem with the USB settings on your machine. I would, again, suggest updating the drivers for your machine.
If that's the case, try plugging another USB device into the machine and see if it works properly.
If none of those options provide results, I recommend you return the mouse for a refund or a replacement, especially if you have the receipt.
I hope I was able to help you. Good luck!
Aug 08, 2009 | Microsoft Wireless Notebook Optical Mouse...
On/off button & non crease button flashing
Sounds like the pump and sump hose is blocked,Check both out
Oct 29, 2008 | Hotpoint Aquarius WD63 Front Load...
Indesit WIXXL146 washing machine will not turn on
sounds like interlock or pcb try lock first as this is cheap to replace regards jason
May 08, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
