Question about Panasonic TH-42PWD3 42 in. Television
Cant get the subtitles of the screen been pressing the subtitle button thanks.
  • 60 Answers
Are you sure they are subtitles rather than closed captioning (if it is TV rather than DVD, it is closed captioning)?
If it is closed caption, pressing subtitle won't turn them off. If there is a button that says "Closed Caption" or "CC" press it. If not, press menu and look for the CC option (it should be under video or audio depending on the TV). Turn it off.
If you are watching a foreign language movie on TV (not DVD) it is likely hardsubbed (you can't turn the subs off because they are burned into the video).
Posted on Sep 19, 2009
Testimonial: "thanks m8 but my tv is linked through a reeview box and cant get subs of."
SOURCE:
How do i turn off subtitles i've pressed subtitle button
Hello, J -
If you have not pressed the subtitles button (closed caption / cc) again, press the Power button on the remote control to turn the TV on and press the subtitles button (closed caption / cc) again. That should stop the closed captioning.
Best wishes.
Oct 01, 2018 | Televison & Video
Cant turn off subtitles
Normally the remote control has a button with the name Subtitles press the key for turn Off.However you must sure if the TV has Turn ON the captioning.God bless you
Jan 30, 2013 | Sylvania NE801UD
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
How do i turn on the english subtitles
there may be a subtitle button on your remote. After pressing if it doesn't work then there mayn't be subtitle available on your dvd disc.
Aug 23, 2009 | Audiovox D1718PK Portable DVD Player with...
Unable to access subtitles whilst watching digital channels
Contact your TV service supplier to be sure that subtitles are available in HD ...
Jan 07, 2009 | LG Televison & Video
Closed caption
Try setting your subtitle language to "OFF".
■ Selecting a subtitle language
Select your preferred subtitle language. (The disc must contain the selected language.)
You can also select another available subtitle language during playback with the
Subtitle button on the remote control during playback.
1 Press the Setup button, then press < or > button to select Preference Page.
2 Press ∧, ∨ buttons to select SUB TITLE.
3 Press the Enter button or > button and then press ∧, ∨ buttons to select
your desired language.
4 Press the Enter button.
5 Press the Setup button to resume normal playback.
Note: Supported subtitle languages are English, French, Spanish, Portuguese, German,
Italian, Russian, Chinese, Korean and Off.
Oct 18, 2008 | Akai LCT2721AD 27 in. LCD Television
We have a RH397D digital recorder. We cannot get the subtitles to stay off. Every time we change channel the subtitles come back up again. Where do we go on the menu to keep the subtitles turned off?
Easy Menu
Setup
A – DTV Closed Caption - OFF (Make sure it is turned off) I am not sure what activates this to ENGLISH but it can be switched off.
Aug 05, 2008 | Televison & Video
Can't turn subtitles off
I want to thank whomever suggested the following...it works. I had been trying for days. Here is the solution:
Turn off the cable box and hit the menu button on the universal remote. The screen with the closed caption selection appears. Scroll down to the line regarding subtitles and turn it off.
Jan 18, 2008 | Philips Magnavox 27MS343S 27" TV
How to shut off closed caption on my dvd
There is a "subtitle" button to the right of the "3" button. Press that until it says subtitle or caption off.
Dec 29, 2007 | Durabrand DVD-1002 DVD Player
How i can view divx whit subtitles (.srt, .sub.ssa)?
it is quite easy to play those anoying subtitles first name the same way both files (video file and subtitle file) example movie.avi movie.srt be sure that both files are in the same folder second: insert the cd/dvd in the yht-630 when the menu appears select the subtitle file using the arrow keys and press the "subtitle" key after this at the screen you will see -> subtitle selected finally select the file that contains the movie (again arrow keys) and press "ok" or "play " key the movie will start and the subtitles will appear. it functions with sub and srt files
Jan 25, 2006 | Yahoo YHT-630 System
Panasonic TH-42PWD3 42 in. Television Logo
1,007 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
