Question about Serfas Cycling
How to fit bike into case
Have lost instructions on how to break bike down to fit into bike case
  • 921 Answers
Take front wheel off, turn handle bars sideways or off and let hang and remove both pedals...remember pedals loosen the opposite way...oh and take seat off or lower it.
Posted on Oct 05, 2009
SOURCE:
When the bike warms up in 4th or 5th gear it acts like it's out of fuel
hi depending what bike it is all bikes are different
some bikes the carbs have little diaphragms fitted under a panel on the side of the carburetor
if the diaphragm has a tiny hole in it that can make your bike react like that
other than that a plug breaking down
or ignition timing may be out a little but that could also be down to a plug breaking down
Oct 06, 2018 | Motorcycles
2013 v-rod. Fitted a new battery but bike keeps shutting off when engine is hot after a ride of 10km. And if I start the bike its OK for short time
indicates an ignition control/ coil problem that is happening when an internal component is breaking down from heat
take it in to a bike shop that handles your make and have it tested and properly diagnosed
Sep 18, 2016 | Motorcycles
Life gear exercise bike
This bike looks to be of the Lemond Revmaster series.
first, dial the resistance knob back until the leather break pad is no longer touching the flywheel. Get down on the floor and postion yourself between the flywheel and pedal cranks. Slowly turn the cranks arms and listen and feel for a roughness in the bike.
This has bike has bearings and a belt. It should not make any noise.
Now with the right pedal at a 2:00 position tighten the resistance knob down all the way so the flywheel will not turn. Then get on and push very hard on the right pedal. If the belt is loose, the pedal will move. Austin Fitness Rentals Rent Commercial grade Fitness Equipment in... ">
May 16, 2014 | Exercise & Fitness
Can i fit any type of ignition barrel to replace my old broken one on my motorbike?
what is the type of motorcycle you are talking about
please rate these
Jan 14, 2013 | Motorcycles
I lost the instruction guide for my exercise bike. Can anyone help me?
I don't knowwhat make or model of exercise bike you have but here is a link to a site thathas a lot of different manuals. Just look through the alphabetical list. http://fitness.manualsonline.com/manuals/device/exercise_bike.htmlIf yours isn'tthere, contact the company you bought your bike from and they should be able tohelp.
Jul 30, 2012 | Exercise & Fitness
I spent hrs looking on the internet looking for a manual for this bike. The original has been lost. Weslo would not take the model #wlex 61408.8
Try with this:
http://fitness.manualsonline.com this is download free.
2) www.fitnessrepairparts.com in this case you must pay.
3)http://manualsfactory.com in this case you must pay.
sincerely.
e.cuadra
Nov 04, 2011 | Exercise & Fitness
I have a bernina activa 130 and when you turn the wheel to insert the needle into the fabric the needle breaks. I am not sure what to check.
Check that your needle is centred when straight-stitch is selected and / or that you have the correct stitch-plate fitted. Is the needle breaking because it is hitting the stitch-plate or is it breaking when the needle goes down through the slot/hole in the stitch-plate. If you are sewing zig/zag or patterns, you must have a slotted stitch-plate fitted. If it's breaking when the needle passes below the stitch-plate, then take the bobbin /bobbin case out and the hook/shuttle and see if it still happens. If it does, the timing on your machine may be out and need professional adjustment. If it doesn'y happen after removing just the bobbin case, make sure the bobbin case is being correctly fitted.
Sep 19, 2011 | Bernina Activa 130
What size dynojet main jets are required for honda cbr 600 91-94 in the UK bike fitted with K n N filter and viper end can , and how many turns out on fuel mixture screw. ( lost my instructions) thanks,...
HI A DYNOJET KIT INCLUDES MORE THAN JUST MAIN JETS, AIR CORRECTORS, SLIDE NEEDLES, AND IN SOME CASES NEW SLIDE SPRINGS ARE INCLUDED, SLIDE LIFT HOLES ARE ALSO DRILLED OUT TO GIVE QUICKER THROTTLE RESPONSE, AS DAFT AS IT MAY SEEM YOU NEW MAIN JETS IN MOST CASES WILL BE SMALLER THAN THE ORIGINAL JETS, IF YOU ARE THINKING YOUR BIKE HAS BEEN DYNOJETED BUT ARE NOT SURE CONTACK DYNOJET UK FOR HELP, HOPE THIS IS OF USE FOR YOU,
http://www.dynojet.co.uk/jetkits/index.htm
Oct 27, 2010 | Honda Cb 400 F Motorcycles
Instep bike trailer assembly
This is the manual for the model that you have. Pictures included. http://www.instep.net/productInstepPDFFiles/168pdf-1pdf
May 25, 2010 | InSTEP EZ Bike Trailer
I have lost my keys to my 2005 Victory Vegas. I
the bike only has 2 locks? Just get a set of locks and keys - maybe from breakers yard or ebay, cheaper than dealership or locksmith... and just as effective, but you have to fit the locks yourself.
Jan 20, 2010 | 2005 Victory Vegas
Cycling Logo
87 people viewed this question
Top Serfas Cycling Experts
Jesse Garza
Kardoc
Donald Ayers-Marsh
Are you a Serfas Cycling Expert? Answer questions, earn points and help others
