Question about Kyocera KM-1505 Copier
J-11 when am try to get photocopy from kyocera KM 1500 display meter showing J-11, drum assembly and toner is new one
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 167 Answers
J11 is telling you that the copy paper has not fed from the 1st paper cassette under the machine.This may be due to incorrectly loaded paper,cassette requires adjusting or the feed roller requires cleaning.The feed roller sits in the machine and you will need to unplug the copier and remove the paper cassette to gain access,Clean the roller with lint free rag and spray and wipe.
Posted on Oct 12, 2009
6ya staff
SOURCE:
What make the buttons of my Kyocera Mita KM 1620 stop working
the buttons stop working because the internal pressing are crash and you should replace it or join it by welding. but first of all you may blow the panel it could be some dust.
Sep 18, 2014 | Kyocera Mita KM1620 Black Toner Cartridge...
C-7 980 error code
can you give us the error code?
waitin for your reply.
May 08, 2008 | Kyocera KM-1505 Copier
Erreur c7 980 kyocera KM-1500
Waste toner reservoir overflow
probrem (when the total number of
copies is less than 100 thousand
sheets)
• After E31 is displayed, 1,000 sheets
are copied. Or waste toner exceeds 5
g.
Jul 21, 2011 | Kyocera KM-1505 Copier
My photocopier has been displaying this error code message C-7990 a photocopier kyocera KM-1500
C7990 is
Waste toner reservoir overflow problem (when the total number of copies is 100 thousand sheets or more)
• After E31 is displayed, 1,000 sheets are copied. Or waste toner exceeds 5 g.
Defective waste toner sensor or engine board (KP-5061).
Shake the process unit from side to side and turn the power switch off and then on. If the problem cannot be solved, replace the process unit. After replacing the process unit, turn the power switch off and then on. If the problem
cannot be solved, replace the waste toner sensor or the engine board (KP-5061).
I hope this is helpful,
Shawn
Mar 05, 2011 | Kyocera Copystar CS-1820 Black and White...
We have a kyocera mita km-1505 photocopier. The error message coming up is AP. Can you tell me what we need to do with it?
just check the toner cartridge maybe the toner is empty if its empty just replace a new one
Dec 06, 2010 | Kyocera KM-1505 Copier
When am try to get phoyocopy from KM 1500 kyocera machine its showing in display meter as an J 111
you have a paper jam in your copier... open it up and search.. best I can tell you...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Oct 07, 2009 | Kyocera KM-1505 Copier
Requist for sugasion kyocera km-1500 toner
it is support cnon np 1215 toner
first time
you clean copier toner unite clean complite previous toner then put canon np 1215 toner print ok
May 28, 2009 | Kyocera KM-1505 Copier
Kyocera fs 1750
First check the neck of the bottle and clean it if dirty
secondly if this does not cure the fault then the sensor in the drum assembly is probably dirty. You will ether have to strip off the end of the drum and clean the led and photo sensor or replace the drum unit.
Aug 25, 2008 | Kyocera FS-720 Laser Printer
KYOCERA KM-1820 COPIER
follw these steps, it should work
turn off copier.
open top toner cover.
turn copier back on.
when you see message "close top cover" press "system menu" button.
scroll up to "service setting" then press the # button, green "start" button and the "enter" button all at the same time.
then scroll down to "maint mode"
press "enter"
then enter 163
press" enter "
turn off copier then turn back on
close toner cover
you should be back in business
May 17, 2008 | Kyocera Copystar CS-1820 Black and White...
How to find meter reading on KM-1500
I believe you hold down the Clear/Stop botton and hold it and you will see PT- in the display then it will show the Total count in three sets of #'s in the LED display. It may also be that you hold down the "0". It's been awhile, but it is one of the two.
Mar 26, 2008 | Kyocera KM-1505 Copier
Kyocera KM-1505 Copier Logo
1,121 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Marvin
Marvin
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
