Question about Motorola Mobility E680 Handheld
Motorolae680i once powered on, i can not do anything with it as the touch screen is not working. if i need to power it off, i need to remove the battery. please help.?
  • 2 more comments
  • Anonymous Feb 12, 2008
    Touch
  • mvskkdi Feb 12, 2008
    touch screen of motorola E680i is malfunctioning
  • edmundumlas Oct 13, 2008
    replacement of touchscreen
  • anto21bbg Nov 27, 2008
    hi my e680i is coming on and after 30seconds it just cut off .how do i flash it
  • 3 Answers
Pls help me,or such as give me the way,or software 2 download,2 fix my touchscreen hang when ever i touch it.......
Posted on Oct 21, 2008
Speaker and ******** not working
Posted on Apr 26, 2008
  • Anonymous Apr 26, 2008
    i want its solution
6ya staff
SOURCE:
GETTING THE DISPLAY TO WORK
try holding down power button for thirty seconds on laptop.
once you think it is off remove power lead and remove battery.
place battery back in and power cord
Try pressing power button on laptop
see if anything is displayed on screen at power up
see if operating system loads correctly
suspect laptop locked up and needing a full shutdown
Jul 30, 2016 | Computers & Internet
Dell xps touch sreen just blinking blue light but blank screen
Sounds like it went to sleep due to low battery power. May be time for a new battery if it isn't holding charge well.
Plug it into the wall and push the power button once. It may come back on. If not...
Hold the power button down until the machine shuts off completely. If that doesn't work, remove the battery.
Feb 04, 2015 | Dell Computers & Internet
How do I get out of safe mode on a Casio G'zOne Commando? I have removed battery for several minutes and power cycled the phone and still it wont do anything when i touch the screen and says safe mode
power up, on the "gzone loading" screen hold down: power, volume up and the menu button ( soft key on far bottom right on the face) at the same timefor about 20 30 seconds and an option to reset screen which you use volume down to choose and power to confirm. a Android dude pops up with its guts spinning around and then the setup your phone thing starts
Apr 26, 2014 | Computers & Internet
The touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
Re: the touch screen stopped working this morning. Can't do anything. Is there a reset button for the computer?
No there is not. If the touch screen is blank and you know that you have power at the outlet, then the computer module has been fried and will need to be replaced.
Possible reasons for a computer module going bad are most commonly due to power surges. If you plug in an outlet surge suppressor then plug your computerized washer and dryer into it, that will save you BIG $$$ over time.
May 27, 2011 | Whirlpool Calypso GVW9959K Top Load Washer
DCS T70 LCD does work properly .I mean to say if i try to use one function another function gets started instead of desired function
Based on the information you've provided, it seems that the touch screen panel is not aligned. You can try Calibrating the touch screen to resolve the issue.
Calibration option is in the Main Settings 1 Menu of the Camera. Calibration option enables you to perform calibration when the touch panel buttons do not react at the appropriate points where you touch. You can use the paint pen, touch the X mark displayed on the screen. The X mark moves on the screen. Once the calibration option is finished successfully, the touch screen should work.
The Calibration option can be done only if the Menu is accessible.
You can also perform a power reset before performing the Calibration.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
This should resolve the issue.
Thanks for using Fixya.
Jan 10, 2011 | Sony DSC-T70 Digital Camera
Touch screen not working
Try to remove the battery and insert it back into your gps device and turn it on. If the screen does not still work, then you need to reset the nuvi, by holding down the power button for about 15 seconds, then the unit will restart, that way the touch screen should respond. If it still does not work, then you need to calibrate the screen to get it to work. To calibrate the screen, follow the sreps below:
  1. Turn off your nuvi,
  2. Press your finger on the upper left corner of the touch screen,
  3. While holding your finger on the touch screen, turn on the nuvi,
  4. Continue to hold your finger on the screen for about 30 seconds until the calibration screen appears (white screen with touch dot),
  5. Then follow the on screen instructions.
It might not work trying it once, so you have to try it over time till it works. Calibration is the last resort of all solutions, so if calibrating it does not do the work, then it means it a an internal problem.
Dec 25, 2010 | Garmin nuvi 650 GPS Receiver
My Garmin nuvi 200w behaves erratically until it has been turned on and warmed up for around 10 minutes. Before this time the touch screen may not work or when pressed respond as if pressed at another...
First make sure the batteries are good and at normal room temperature.
Second, based on your question your touch screen is bad or needs calibrating....
Then
Try to recalibrate your screen:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} To recalibrate the touchscreen on your nuvi 200 series follow the steps below:
  1. Have the unit turned OFF and unplugged from power.
  2. Slide the power switch to the ON position and hold for about 45 seconds.
  3. A message will display on the screen: Press Dot.
  4. Once this message displays, release the Power button.
  5. Press in the center of the Dot.
  6. Keep pressing in the center of the Dot as it moves around the screen.
  7. Once this is complete, there will be a message: Calibration Complete.
  8. Touch Ok and the unit will restart.
The touchscreen will now be recalibrated.
*Note if unit is running software version 6.00 or newer you will want to follow steps from below.
To recalibrate the touchscreen on your nuvi 205 series follow the steps below:
  2. Place your finger in the top left hand corner of the touch screen and apply pressure.
  3. Slide the power switch to the ON position.
  4. Hold pressure in left corner until the Press dot message appears.
  5. Once this message displays, remove your finger from the screen.
  6. Press in the center of the Dot.
  7. Keep pressing in the center of the Dot as it moves around the screen.
  8. Once this is complete, there will be a message: Calibration Complete.
  9. Touch Ok and the unit will restart.
Sep 23, 2009 | Garmin nuvi 200W GPS Receiver
Touchscreen does not work
Ok, remove the battery for 5 minute to reset the internal programming. once the 5 minutes are up, re insert the battery and power up. if the screen is still unresponsive, you will need to contact your manufacture for a repair ticket. the internal software that is used for collaborating the touch screen has failed.
May 22, 2009 | LG CU500 Cellular Phone
My Garmin C3550 street pilot will power up but screen is only white.
Try recalibrating the touch screen. Turn on unit while continuing to press the power button for about a minute. You will then be prompt to touch a series of dots on the screen. Once prompt to do so, release the power button and touch the dots. Press OK when calibration is complete. The unit will continue to power on. Good Luck.
Aug 11, 2008 | Garmin StreetPilot c550 GPS Receiver
Touch screen freezing up
Look at this http://www.fixya.com/support/t132057-getting_past_align_screen
you basically need to get the wire to stop touching the home key, which can be accomplished (as described in the link) with either the quick fix method, wedging something in the bottom screen, or the better-long term method of opening the axim up and taping the part that has shorted.
best,
Greg
Sep 04, 2007 | Dell Axim X5 Pocket PC
Open Questions:
See all Motorola Mobility E680 Handheld Questions
Motorola Mobility E680 Handheld Logo
143 people viewed this question
Top Motorola Mobility Computers & Internet Experts
 Paul Flint
Paul Flint
Level 1 Expert
Tom Chichester
JessicaChane2345
Are you a Motorola Mobility Computer and Internet Expert? Answer questions, earn points and help others
