Question about HP LaserJet P4014n Printer
Error 68.2 permanent storage write fail (Hp laserjet P4014n)
68.2 permanent storage write fail.
(for help press ?, to continue press ok)
if i press ok it will print what ever job was sent but you have to kepp on pressing ok for each job send, but its not proper because its a network printe thus i need a solution that will clear this error massage for good.
thank you for yuor solution. this is for my hp laserjet P4014n printer
  • 3 more comments
  • Anonymous Oct 27, 2009
    I didn't understand what you said when you said,"Just hit the check mark button again and it should take care of the problem." What is this?
  • Anonymous Nov 02, 2009
    thank you but the problem still persists
  • Anonymous Dec 28, 2015
    really thank you for Fixing this Problem its work and the Error disappear
    my Printer is HP CP3505X and it work very well
  • 404 Answers
Hi kgrema! I will be glad to assist you in this issue,
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
Here is the link just incase it does not solve the issue.
HP Support document
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
I hope this will solve your issue
Posted on Oct 26, 2009
    New Friend:
Not resolve the issue.....
still pending
when Initialize disk appear
bellow arrow button is not working.
Posted on Aug 09, 2015
    President:
  • 3,278 Answers
Hello !
From HP Support:
68.X PERMANENT STORAGE WRITE FAIL To continue press (Select) Description A nonvolatile storage device is failing to write. Pressing the Select (check) button should clear the message. Printing can continue, but behave unexpected in response to the changed settings. Another suggestion:
Turn off the printer. Turn the printer back on and when the memory starts to count, hold down the Menu key until all three lights come on. When all three lights are on solid, release the Menu button and press the arrow back button (<) and the initialize disk should appear in the menu. Just hit the Select check mark button again and it should take care of the problem.
Hope these suggestions help.
Posted on Oct 27, 2009
6ya staff
SOURCE:
If I'm receiving Error 58.04 on th HP laserjet P4014n How do I shut it off?
this code comes from defective power supply or dc controller
Jul 13, 2014 | HP LaserJet P4014n Printer
Hp lj2420 errcode 68.2
The printer permanent storage is
full. Some settings might have
been reset to the factory defaults.
1. Press the SELECT ( ) button
to continue.
2. For 68 errors, turn the
printer off, and then turn the
printer on again.
3. If a 68 error persists,
initialize NVRAM. See the
caution and note in To
initialize NVRAM.
4. If this error message persists,
replace the formatter (see
Formatter).
Apr 04, 2011 | HP LaserJet 2420 Printer
Error 68.2 permanent storage write How do you fix the error?
Feb 16, 2011 | HP LaserJet P4014n Printer
I have one printer lj 2420 68.0 permanant storage full error
Error 68 is simm memory problem.
68 Error / Service / Cold Reset
All printers
  1. Temporary error. Cycle power to printer
  2. Bad formatter PCB
LJ4, 4+, 4P
  1. NVRAM not initialized.
68 Memory
IIISi, 4Si, 4V
  1. Bad SIMM memory. Check and replace SIMM's
Feb 05, 2011 | HP LaserJet 2420n Printer
Printer hp laserjet 2420 error 41.2 dan error 68.2
The 41.2 printer error means beam detect misprint error. To resolve this try the ff:
  1. Press c00099410.jpg (Select). The page containing the error automatically reprints if jam recovery is enabled.
  2. Turn the printer power off, and then turn on the printer power.
  3. If the message persists, click here to access the HP support Web site at http://www.hp.com/support/lj2300 ,
The error 68 regardless what number follows after it is about Storage Error. One or more printer settings saved to storage device x are invalid and have been reset to factor defaults. To resolve this:
Press c00099410.jpg (Select) to clear the error and continue printing. Printing can continue, but unexpected behavior might be experienced because an error occurred in permanent storage.
Hope this helps.
Thank you for using FixYa.
Nov 26, 2010 | HP LaserJet 2420 Printer
HP Color LaserJet CP3525 68.X PERMANENT STORAGE WRITE FAIL
Perhaps this link may help you !
http://h200003.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=de&cc=de&taskId=125&prodSeriesId=74301&prodTypeId=18972&prodSeriesId=74301&objectID=bpl11648
Nov 01, 2009 | HP Color LaserJet CP3525x CC471AABA...
Error 68.2 permanent storage write fail (Hp laserjet P4014n)68.2 permanent storage write fail. (for help press ?, to continue press ok) if i press ok it will print what ever job was sent but you have...
Hi! I will be glad to assist you in this issue.
here is the lin for additional solution:
Oct 26, 2009 | HP LaserJet P4014n Printer
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
HP LaserJet P4014n Printer Logo
9,422 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
