Question about HP LaserJet 5550 Printer
10.00.01 Supply Memory Error. on hp printer 5550 dn
    New Friend:
This chang catrich after this view error suply..
Posted on Dec 07, 2009
6ya staff
SOURCE:
Supply memory error
go to hp.com and see how to cold reset the machine that should wipe the memory and clear the error
Nov 11, 2013 | HP LaserJet 5550 Printer
The printer turns on. Starts to reboot and then turns off, and on?
sounds like bad power-supply inside.
it will take a savvy technician to fix.
the question is, Is the labor less than a new one.
in the USA we throw most things out. brocken.
do to that 1 fact.
i dont like them but there is geek squad. ask them for a quote.
if no quote given , walk.
just like car repair,
Sep 28, 2013 | Xerox 5550/DN - Printer Phaser 5550/dn
HP Color LasrJet 5550 dn Error code 59.30
The error says that the printer has a "fuser motor startup error".
Not a good error to get.
Possibilities are a bad fuser motor, bad DC Controller or fuser drive assembly.
If you haven't already, power cycle the printer.
If the error persists, you are going to have to have a tech look at it.
Feb 28, 2011 | HP LaserJet 5550 Printer
How to reset page details on hp 5550 dn printer
go to page setting of the printer. reset it to default.
Aug 13, 2010 | HP LaserJet 5550DN Printer
Hi my machine has a 10.00.00 supply memory erro message can you tell me what is wrong with it please
Memory Supply Error 10.00.00 The printer is unable to read or write to the print
cartridge e-label, or the e-label is not on the cartridge.
Basically what is happening is the printer cannot read the small chip on the toner cartridge. The chip is located on toner cartridge as it is inserted into the printer. 1 - Make sure the toner is firmly seated into the printer. 2 - Power cycle the printer with the toner out of the printer. Install the toner back into the printer. 3 - Install another toner cartridge. 3 - Verify that the e-label connector is firmly seated in connector
Contact a local HP Authorized Service Center for further assistance.
Aug 03, 2010 | HP LaserJet 5550 Printer
I need hp 5550 dn drivers
For which os? (operating system)
Mar 06, 2010 | HP LaserJet 5550DN Printer
HP color lasejet 5550 dn does't print. Is this message: 10.00.03 supply Error memory. Can you help me Thank's
hello
You could try with different cartridge try to clean the contacts , check wether the cartridge is seated properly , make sure weather the strip is removed from the cartridge
OR
If you use a HP original cartridge, then you shouldn't have this message.
Anyway you can print, it's only at startup that this message appears.
If it is a HP toner, then change it.
Or
try this link and you will find answers for all your printers errors
http://www.all-laser.com/cgi-bin/webc.cgi/error-code.html
Mar 05, 2010 | HP LaserJet 5550 Printer
On Initialization the following error appears 10.00.01 Supply Memory Error.
The printer cannot read the memory tag on the black toner catridge. Power the printer off, swop the black toner cartridge for another colour.ie put the cyan, magenta or the yellow in the place that the black should go and fit the black in to space left by the colour. Power the printer on and see if the error remains the same.If it's the same error then it could be the cartridge reader in the black position.If the error changes, then it's possibly down to the black cartridge.
Oct 14, 2009 | HP LaserJet 5550 Printer
Hp 5550 dtn 10.00.00 supply memory erro
the chip is faulty on the black cartridge, change the black and it'll work, alternately you can out it diagnostic made and run without the cartridges being monitored
May 09, 2008 | HP LaserJet 5550 Printer
HP LaserJet 5550 Printer Logo
1,288 people viewed this question
Clive
Clive
Ekse
Thomas F. Schneider
