Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
I have a sony 32 inch lcd tv and if i leave it in standby overnight it sticks in standby no keys work, if i turn it off at the socket then back on its fine,any ideas?
  • 10,594 Answers
There are two possibilities for that symptoms,
Either standby power supply becomes low (less then +5 volts) so system control chip lose its function OR system control itself stops its function.
Unplugging TV resets system control and it starts work again.
First confirm standby supply is OK, if found good and correct +5 volts, then replace main board that has system control chip.
Let me know exact model number of your Sony TV written at back to find out boards and prices.
Thanks.
Posted on Nov 03, 2009
SOURCE:
Sony kdl-32ex500 error codes
B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
Nov 29, 2013 | Sony Bravia Kdl - 32Ex500 32 inch 1080P...
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Alba 42"lcd tv watching tv it just went off,
Alba is now a product of Argos, their low cost help line number is 08456040105
Nov 18, 2010 | Televison & Video
Power Tripping?
power problem for the sony KLV-32U300A . Open the back cover of the tv onplug the power supply board, In primary section where u connect AC voltage just after the fuse there is NTC (negative temperature coefficient) parallel to the Relay, replace it. this could be the cure for your tv. isn't it simple? LET ME KNOW.
May 22, 2010 | Sony Bravia KLV-32U300A 32 in. HD-Ready...
KDL 32S5500 TV When left on standby overnight locks-up, hangs.
There is a Post on the Sony Support site which I hadn't previously found. Basically there is a software bug which has come about apparently due to Freeview transmission changes. In order to stop the the machine locking up disable the 'Automatic System Update' option. A Sony centre will apparently apply a software fix to properly resolve the issue, fine if with warranty period, maybe pricey if not. I will get the fix but haven't yet done so as the workaround of disabling the System Update option works.
Sep 18, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
How to turn standby off
The TV circuit may have detected a problem within its parts. You may have to check some leaking capacitors in the board or loose solders or burned components just to make sure. Normally leaving the TV unplugged overnight should reset it.
Sep 07, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Turning off power from the wall or leave it on standby
It's safe to leave a TV on standby, till it develops a fault and burns down your house!
May 28, 2009 | Samsung LT-P1745 17 in. EDTV-Ready LCD...
TV won't come on
I have a 32 inch tv was working great then went into standby mode and wont turn back on. I have unplugged and am waiting please help!!!!
May 18, 2008 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Fix my tv
please contact ur dealer
Mar 11, 2008 | Sony KV-32S42 32" TV
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
111 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
