Question about Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Loss of picture on LCD TV when first turned on. Must restart.
I have a Sharp Aquos 32-inch LCD television I purchased three years ago. For the past several months (sporadically) when I turn the television on, the picture immediately disappears though the sound remains. If I wait for several minutes and turn the set off and then on, everything is fine, but I have to wait for several minutes. Also now and then even when the set has been on for and hour or two, the picture just disappears and requires that I shut it off and on. Aquos denies that there is anything wrong with the set and says is may be something wrong with my cable television provider. The set is past the warranty, but I would still like to know if this is something that may be related to the cable or if it is the Aquos TV itself. The problem did seem to occur with the switch from analog to digital, but that may be coincidence. I've seen similar problems discussed here, but the answers vary.
    Top Expert:
  • Sharp Master
  • 76,143 Answers
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Posted on Mar 12, 2017
6ya staff
SOURCE:
Anonymous
  • 208 Answers
SOURCE: Sharp Aquos 46 In TV Problems:
Sharp list no issues or service tips for this model but I am sure most freeze ups are and issue of weak cable signals or defective cable receivers. If this has truly been elimnated the main digital pcb in the TV could be issue or more likely the TV may need the latest software upgrade. This is most likely only able to be facilitated by a Sharp auth. service center.
Posted on Feb 05, 2008
Anonymous
  • 208 Answers
SOURCE: Sharp Aquos LC-26D4U sound problem
This unit has a chronic problem with the insulator material used on the heat sink on the ic's on the AV Bd. The unit must be disassembled and the AV bd. removed. The insulation on especially IC 2502 breaks down and must be cleaned off of the bd. and the ic and new insulator part # PSPAZA663WJKZ must be ordered and used as the insulator pad. If you send me an email to missiontracetv@msn.com I can send you the copy of the Sharp technical bulletin LCDTV-194.
Posted on Feb 26, 2008
Anonymous
SOURCE: sharp aquos fault
Thanks to this forum, I was able to confidently contact Sharp and get my TV fixed.
My 32" LCD had the same problem (sound but no picture) and was out of warranty, however I phoned Sharp UK and suggested that it was a manufacturing defect rather than component failure and should be repaired free of charge - which they did!!
Posted on Mar 19, 2008
Anonymous
SOURCE: Sharp aquos lcd screen goes blank
i was having these same problems with the screen going black, and i found that when i hit the back of my tv it would work sometimes. so, i improvised on some of the advice on this page and so far no problems. here is what i did (its very easy):
1. lay the tv on the floor and take off the back panel. (i think 12 screws)
2. on the right side of the tv (as you are looking at the back) you will notice a large metal covering that is held in place by 6 screws. unscrew these and remove the metal cover.
3. you will notice that the three screw holes on the left side of the board have some sort of metal or solder around them, in sort of a star pattern. when i looked closely i noticed that most of the metal (solder) was tarnished, or kind of blackened. (this must mean that the ground screws werent getting a good connection and this would explain why it would work sometimes when i hit it because it would vibrate the screws enough to get a good connection! )
so, take a pencil eraser and erase all the black or tarnish off the metal surrounding the screw holes. thats it! (to be safe i took some sandpaper and cleaned up the screw holes on the back of the metal covering, but i dont know if that was necessary)
at this point i followed another gentleman's advice to do a hard reset. this involved unplugging the 8 connections although i dont know if this was really necessary because i believe my problem was a ground issue. i did it just to be safe. his advice is on this site if you want to do this step.
4. i put everything back together and it worked! i performed a soft reset at this point which puts your tv back to factory settings. just go to menu>setup>reset>return to factory settings? yes
this will turn your tv off and back on. that's it. so far so good for me.
Posted on Dec 18, 2008
Anonymous
GOOD NEWS - - According to the Sharp Technician I just spoke with a "Service Bulletin" went out to all their techs about the sound issue on these Sharp Aquos. I'm having the exact same sound probem and I'm in the process of having the technician come out at no charge so call the number given in Solution #6 and #9 (1-800-237-4277) and keep pressing #1 until you get a technician. Have your serial number ready and they will need your name, address and telephone #. They will then give you a case number and transfer you to dispatch (which closes at 5pm central). Thanks everyone for your help and posts - you made our day!!!
BTW - We also have the problem of the TV turning on and off by itself but the technician said they had not received a service bulletin about that yet.
Posted on Jul 07, 2009
Power light comes on along with OCP light. No screen or sound. internal switching noises coming from inside the tv
Sharp TV - Flashing OPC & Power Lights - YouTube
? 0:50
https://www.youtube.com/watch?v=BH1OcQ6dIEE
Jul 1, 2011 - Uploaded by Tweetssun
Sharp Aquos TV flashing a OPC & Power Lights in a pattern of 3 flashes, ... Sharp Aquos LC-32D44 - One blink lamp error - Nopicture or sound - Diagnosis ... Repairing Flat Screen TV - Blacked out with blinking red light ...Missing: 32dv22u
Sharp lcd tv power button flashing - HDTV - Streaming Video & TVs ...
www.tomsguide.com/forum/54708-4-sharp-power-button-flashing
Feb 8, 2012 - 7 posts - ‎3 authors
We have owned a Sharp 32" LCD TV for about two years. ... However a quick Bing search shows that the blinking green light usually means a bad power board, which seems ... No picture, no sound, just a black screen and two blinking green ... a cable surge block on the coax where it comes into the house. Sharp lcd tv power button flashing - Digital TV
Oct 14, 2012
Sharp hd tv blinking power no picture - Digital TV
Jan 7, 2012
More results from www.tomsguide.com
Missing: 32dv22u
Sharp Aquos LC 42DH77: Inverter, Backlight, Power and ...
www.normsweb.com/tektips/42dh77.shtml
Jan 31, 2016 | Sharp LC-32DV22U Widescreen 32-Inch Class...
When tv is turned on you get poicture and sound but there are broken horizontal lines from top to bottom of screen. this occurs on all hdmi inputsincluding roku and dvd player.
How to fix lcd lines on Sharp tv screen, hdmi video board ...
? 3:43
https://www.youtube.com/watch?v=cHki4D0EwOo
May 24, 2014 - Uploaded by Tampatec
How to fix LCD lines on Sharp TV screen, hdmi video board easy ... Make Money From Your Broken Cracked LCD LED PLASMATV ... TV Repair Help for Vertical & Horizontal Lines on Your TV Screen ... Sharp Aquos LC-32 37 46 52DH65E 66E 77E - NoPic/Sound with ... Get video URL at current time.
comments on LCD Display Symptoms and causes. - YouTube
https://www.youtube.com/all_comments?v=DedJvyNm_s4
We have frequent outages causing the TV to turn on from standby mode when power returns. (These ..... Sharp LC-70LE650U 70-Inch Aquos TV TURNS ON WITH PERFECT PICTURE AND ..... It has thin horizontal lines on the top quarter of thescreen. ..... hey there, bought a 52lg60-ua had no image/picture but had sound.
? 2:01
https://www.youtube.com/watch?v=DedJvyNm_s4
Jan 28, 2016 | Sharp aquos 52 in lcd 1080p aquos 52...
I need a pedestal stand for a Sharp AQUOS LC-32D43U 32 in. LCD Television.
i need a pedestal stand for sharp aquos 32 inch tv and do not know where to get. check on line it seem no one has it. where can i get one? do not want to spend a lot of money not more than 50 dollars.
Aug 10, 2013 | Sharp AQUOS LC-32D43U 32 in. LCD...
My sharp aquos lcd tv 32 inch usually gets hard time in turning on coz once a brownout occurs and when i turn it on only the green light appears without pictures so i have to unplug it on and off as...
Sounds like you have bad capacitors somewhere in the TV. If none of them are bad, you could also have loose grounding screws on the inverter shield. It is common for this TV and simply retightning them will keep the backlight on again.
Mar 23, 2011 | Sharp AQUOS LC-32D44U 32 in. LCD TV
32 inch Sharp Aquos is less than a year old... I changed that channel and the picture was green or gray... i changed it again and got a normal picture once but now all channels are looking blank with a...
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
Apr 26, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp aquos hdtv has sound but shows a white screen
yes and no. That particular tv you have is done for, but if you just purchased it 6 months ago, you are still within you 1 year warranty with sharp. they will ask you to take it to a authorized service center and you need to follow through with the process. about a week or 2 will pass and the service center will deem the unit unrepairable and sharp will replace it if they cant solve the problem. give em call..good luck 2u
Dec 24, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Sharp Aquos 32" screen size too big!
Check your cable remote. You might have it set to HD zoom. This happened to us when our little girl got a hold of the cable remote.
Dec 05, 2007 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
Sharp Aquos LC-37GD6U 37 in. LCD HDTV Logo
286 people viewed this question
Top Sharp Televison & Video Experts
Ekse
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
