Question about Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television
My television is cutting off and takes forever to restart. the green light stays on. I have tried to reset the tv. same ol thing. replaced the lamp its not that. a big blue screen pops up before shutting off. the tv was purchased from sound advice whom is no longer in business. the tv was purchased in 2005. mitsubishi wd-62725.
  • 261 Answers
Hello! If you haven't replaced the lamp before, I recommend you do it, since it's already 4 years old. If you already replaced it, there is a possibility you might be having a ballast issue. The ballast is the board in charge of sending all the power to the lamp so it can light up. www.discount-merchant.com/?Click=48427 These part are not that expensive and will get your TV up and running.
Posted on Nov 18, 2009
SOURCE:
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
Replaced projection lamp in panasonic multi media projection television and reset timer t_v played for a day or so then cut it off now power will not come back on green light is blinking on power
Make sure the Lamp door is tight. Unplug the TV, and remove the lamp and then reinstall the lamp making sure the door is tight. Then plug the TV in and try again. If it does not work, please post the model # of the TV.
Jun 03, 2015 | Panasonic Televison & Video
Replaced lamp. TV worked great. Never reset message code. Finally, tv started cutting off after booting up. Reset lamp code, lights on front went one green. Thought that solved problem.
After a lamp replacement, you might have to reset the lamp time. It was a must. Contact the authorized service center; as there is no chance to you to get the screen display any further. The service engineers at the service center will do the needy.
Feb 25, 2015 | Televison & Video
Tonight my Sony Wega KDF-42WE655 screen went black and the audio stopped, the standby light (green) blinked on and off for about 30 sec. then the screen came back on and the green light blinked 5 sec or so...
Replace its lamp as existing lamp has been reached at end of its working hours life and need to replace to solve this issue. Please note lamp is not not broken or dead yet so you do not see lamp light on tv front.
Lamp replacement procedure is easy and written in user manual.
Please buy Sony original lamp for god picture in tv.
Thanks.
Dec 31, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
After replacing tv lamp cartrige for my tv Mitsubishi WD-52725, the timer green light keep flasing and tv would not turn on,
Please check the installation, the lamp door is not placed correctly or still open. this is causing the door micro switch to stay open. take out every thing and put it back exactly the wat it was before you changed the lamp. it is slso easy to by pass this switch if required.
Mar 08, 2010 | Televison & Video
Win i turn the tv on the red light comes on and i can hear the tv like its comeing on but the green light comes on and cuts the tv off but it comes back on but it does the same thing
Your lamp could be burnt out. The tv will keep retrying to start for a few times then will shut down. remove the lamp and see if it looks burnt. When you replace it you will also have to reset the lamp timer. check your manual to see how to reset.
Feb 14, 2010 | Sony KDF-E60A20 60 in. LCD HDTV
I have a Mitsubishi WD-62725 that I purchased in February 2005. The manufacture date is November 2004. I was watching a DVD the other day and all of a sudden the picture just went black. I never received a...
It sounds Lamp got broken inside, please take out lamp from TV and check its glass tube. If found broken, replace it.
Lamp replacement procedure is written in user manual page-95, click HERE to download user manual copy if required.
Lamp is available in Part Store.
Thanks.
Nov 05, 2009 | Mitsubishi WD-62725 62" Rear Projection...
My Sony HD-TV KDF-50E2000 is about 18 months old. The picture went out. The green on light stays on for only a few minutes then goes off and the red lamp light flashes. You can turn the Tv on again and the...
How many times Red Lamp flashes, its important as it shows problem and its location in tv. Below is detail of lamp blinks and you may know the problem area in tv by counting lamp flashes.
Need further help, let me know.
Sep 13, 2008 | Televison & Video
Tv cuts off and green light flashes
Yup, it seems a lamp problem can give a blinking green light over the 10 times (1 - 10 times for diagnostic codes), but in my case rather than replace the bulb if it works for a minute then resets with the green light blinking, do what I did.
Take the lamp out and inspect it, it has breather screens top and bottom, if it cant breath because there clogged with dust, clean them, and you can remove the screens, use q-tips and clean the inside. I saved the cost of a lamp and it's working fine!
Jun 27, 2008 | Sony Grand WEGA KDF-55XS955 55" Rear...
Blinking green reset light
Can you please supply us with the make and model as well as the blink count of the green light. That count should be indicating the problem circuit. Once that info is posted, we should be able to give you more details and possible solutions.
Dan
Jun 19, 2008 | Televison & Video
Mitsubishi WD-62725 62" Rear Projection HDTV-Ready Television Logo
184 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
