Question about Hitachi 43FDX01B TV
I have a hitachi 43FDX10B ultrascand HD rear
I have a hitachi 43FDX01B ultrascand HD rear projection tv. the green color is off when I go to convergance the green line is fuzzy and about 1 inch wide in all directions. it also dips down at top of screen and is miss aligned on the screen. The color miss alignment seems to only be on top half of the screen the bottom of the screen looks fine. any help would be appreciated
    New Friend:
    Problem Solver:
  • 10 Answers
Well it seems to me that you need to call the manufacturer to see how to reset the pixels for that tv. it seems someone has taking a magnet or something like that to the tv screen
Posted on Nov 29, 2009
6ya staff
SOURCE:
I have a Hitachi 43fdx01b rear projection tv. it's picture looks like it is 3D.It was fine, happened all at once. wHAT IS IT ?
STK ICS replace both of them STK392-110 use 150s
Call Mats Elecronics for ICs 10.95 each
1-800-628-1118
Jan 22, 2010 | Hitachi FDX Series 43FDX10B 43" Rear...
Color has changed to green tint
    According to the system the problem in your projection is convergence and the solution is to replace the IC STK's.The part Number is CZ01341. Change the IC STK both and your TV work fine again.And for parts please see the link below.
http://jr.partsearch.com/Model/Hitachi+Ltd/Hitachi/43FDX01B.aspx?SearchTerm=True
   Thanks.
Jan 09, 2010 | Hitachi 43FDX01B TV
I have a Hitachi Ultra Scan HD TV model #43FDX01B - Green line
Hitachi Projection TV Repair Kit for one or more of the following symptoms
This might not be your model but you should contact them to see if the have the parts I know they list the manual
Feb 18, 2018 | Hitachi 43FDX01B TV
How do you get the High Def. Picture?
Make sure you are using the red green and blue cables and not just the video
yellow ,red and white Inputs
the component cables will give you almost as good as the hdmi cable
The debate over monster cables and other is an on going discussion.
I personally have found little or no difference in the 30 dollar cables vs the 200 dollar cables
As long as you are running the component in on the tv you should have a very nice picture
Jan 11, 2009 | Hitachi FDX Series 43FDX10B 43" Rear...
Is my Hitachi Tv model 43FDX10B HD ready?
Probably but this hitachi has no reall HD just simulated, called D3VirtualHD by hitachi. Should work, you can always return the blu-ray if it's not what you expected or ask a good salesman if it's worth, you might try it in store...
cheers
Dec 23, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Is my Hitachi model 43FDX10B HD READY?
simulated HD, hitchi called it D3VirtualHD
So the answer is yes and no. Mean should work.
No HiDef on projection TV
u need a hd receiver to get hd on this tv. satellite or cable box. the screen blank in and out on hd signal. get use to the blackout.
Nov 15, 2008 | Hitachi 43FDX01B TV
Hitachi 43FDX01B color
sounds like bad convergence Ic's--set uses two of them, common on many projection tvs.
May 19, 2008 | Hitachi 43FDX01B TV
Hitachi 43fdx01b rear proj. hdtv
if you are using Y, Pb,Pr, connection to the tv from a sat or cable box check the red wire on both ends red may be disconected.
Feb 09, 2008 | Hitachi FDX Series 43FDX10B 43" Rear...
Hitachi 43FDX01B TV Logo
201 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
