Question about LG 50PG6000 50 in. HD-Ready Plasma TV
Gas keeps going is it worth fixing or is a new one better
    New Friend:
I have sound but the picture has gone. It is just showing vertical colour bands.
The tv is only 4 years old, can i get this fixed?
Posted on Sep 09, 2010
  • LG Master
  • 458 Answers
I assume you mean that your screen is showing signs of stress 7 the picture quality is suffering. This would mean a replacement screen is needed & as this is very costly then it is more economical to buy a new TV instead.
Posted on Dec 02, 2009
SOURCE:
I have a spin brush Conair infiniti pro and the brush stopped spinning. How do I fix it?
Replace the brush bar you'll have new brush bar better clean than old brush with new bearing which aren't available or worth the bother fitting, ps keep the filters clean makes a real difference to sucking power.
Oct 22, 2017 | Conair Vacuums
Briggs and stratton 6.5 started smoking so changed oil in hopes would help still smoking
sounds like it broke a ring to fix better to buy new moter not worth trying to fix
Jun 01, 2012 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Lawnmower has been in storage for 6 months. Has new good gas, and gas is flowing to carb. However, engine will not start without priming carb with gas, then runs until primed gas is exhausted. ...
this is from a post i just did for anothe engine but i think it applies to you also.
get a product called START. this stuff is amazing it has solved all my engine problems including a couple like yours. any wal mart should have it. add to your gas and the longer it runs the better it runs. i am telling you it is worth the 6 bucks. i had a 4wheeler that never ran right, always had to half choke it. even though i cleaned the carb twice. added this stuff and by the time that tank was gone it was running like new. if that doesnt take care of your problem then it needs to go to the shop Now your situation i know is dirt or varnish in the carb i have had this problem also. and start worked for me on that also. mix it in the gas and keep it running even if you have to keep priming it
Nov 12, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have a 2 stroke engineer leaf blower that will not start. I have spark and using starter fluid gets it going but it quits. I know I have gas getting into the carb. - I think problem is probably in...
Paul, fix the old carb. They can gum up and sometimes need to soak (disassembled and soft parts removed, like the float, gaskets and inlet valve.)in carb cleaner and then be blown out with compressed air.
Nov 06, 2010 | ECHO, Inc. PB-251C Handheld Blower
No power, is it worth fixing?
The proper answer to your question is "it depends".
- LCD's have a long operating life compared to Plasma but they will burn out eventually. If this monitor has been used extensively then even having it fixed will not be worth it because the panel may die off in just a few months
- However, if the LCD was seldom used, then it may be worth it to fix it
- LCD panels are also known to be very expensive. If your problem is just electrical then it will probably worth fixing it.
- However, if your problem is with the panel itself, then replacing it is a better alternative because the replacement panel is very expensive and will be almost as much as a new unit.
NOTE: Please rate our help to keep this free service online.
Jan 11, 2010 | LG L1932TQ LCD Monitor
IVE BROKEN THE FREEZER SHELF THAT KEEPS THE FREEZER COLD ALL THE GAS CAME OUT TOO. I DONT KNOW WHAT TO CALL THE PART OR WHERE TO GET ONE...DONT KNOW WHAT TO DO...ITS A MIELE FRREZER. kIND REGARDS Adam
Its a total waste, Get a new Freezer, it might be possible to have someone come in and solder a new Condenser coil but that is going to cost, with that the parts, labor and Refrigerant/freon its probably not worth fixing
Jan 03, 2010 | Freezers
I dropped my camera the firt time I used it and the lens got damaged. Is this worth fixing, or should I get a new one? 150.00 new. Thanks
Well you might not be able to fix it, take it in and see how much it would cost but i'd just rather buy a new one.
Dec 27, 2009 | Nikon COOLPIX S570 Digital Camera
When refueling my 300m the gas nozzle consistantly cuts off. It sounds like the tank is full, but will only accept 40 cents worth of gas. I think it is the anti-siphon screen clogged or the vent. Neither...
I have a 2003 300m and I had the same problem when mine was brand new. I took it to the dealer and they told me that there was a recall on the filler tube going to the gas tank and fixed it for me. I don't know if that's your problem but it is worth a shot.
Aug 11, 2008 | 2003 Chrysler 300M
LG 50PG6000 50 in. HD-Ready Plasma TV Logo
69 people viewed this question
Ekse
