Question about Tomtom GO 920 GPS Receiver
Doesnt hold charge
It doesnt hold its charge.after 3 hours of charging it shut off within 5 minutes of use...
    Top Expert:
  • Tomtom Master
  • 29,179 Answers
The battery is worn out. You need to return it to the manufacturer so they can install a new one. Even rechargeable batteries wear out eventually. If they are in constant use, discharge/recharge, you can reckon on 5 years. If they are left for long periods discharged, or not used, then the life reduces dramatically.
Posted on Dec 05, 2009
SOURCE:
Why does my tom tom keep going the shut down page every 10 seconds I have pressed reset but makes no difference I ride bmw r1200rt
One possible cause is that your battery is low or the battery can no longer hold a (good) charge. In this case, the TomTom is shutting down because there's not enough battery to keep it running, even though it is plugged into a power source.
To determine if the battery is the cause, try to charge the TomTom battery .... using a (USB) connection to your computer, or a direct power source (i.e. while the TomTom is not being used). Let it charge for a few hours until the batter charge indicator shows that it is fully charged (or just leave it charging overnight).
Then, unplug the TomTom from the "charger" and power it up. If the TomTom (battery) doesn't hold a (good) charge, the device will shut down within a few minutes, e.g. 10 mins or much less.
When you (then) plug the device into a power source, and it doesn't stay on (i.e. it keeps shutting down after 10 seconds), you can safely conclude that the battery is the cause of your problem.
Apr 24, 2016 | Tomtom GPS
Works fine on battery or charger with battery removed ,add battery and it quits in 5 minutes
Your battery could be old, therefore doesn't hold any long term charge.
Every time you add the battery it probably doesn't charge 100 percent therefore it discharges within 5 minutes, shutting down your laptop.
Apr 20, 2013 | Computers & Internet
I charged my psp for atleast 5 hours.....but charge ended within 1 hour......what to do??
I'm just restating what you said here first...
You plugged in your psp for 5 hours.
You took it out.
You played it for 1 hour before it turned off...
If this is true, it seems that your battery just can't hold a charge. One solution would be to just buy a replacement battery, but you could try this...
Drain your psp completely. This means keeping it on until it turns off, then turn it on again, leave until off and so on. Just keep turning it on until it stays on for less than a minute.
Charge your battery overnight.
Hope this helps!!!
Oct 07, 2010 | Sony PlayStation Portable (PSP) Console
Doesn't hold a charge
Again as above your battery may need replacing see if its still under warrenty
May 22, 2010 | SanDisk Sansa Clip MP3 Player
Motorola H500 bluetooth won't turn on!
Hold the phone button down for about 4 seconds.. The light should blink 2 times and then stay on to add device to your phone once connected light will go out...Hold button down again light will blink 3 times and go off...........
Aug 07, 2009 | Motorola Mobility H500 Wireless Headset
Flip Mino HD will not boot, charge or reset
Call Flip support, problems are happening to too many people, contact Flip support, if they cannot help, contact MacWorld or other online reviewers and let them know.
Jul 06, 2009 | Pure Digital Flip Mino Digital Camera
Batteries require several charges in order to reach fully capacity
I wont exactly call this solved but I called duracell and they think the batteries are old. They are sending me a new set of batteries.
Sep 08, 2008 | Duracell AAA NiMH Battery Charger with 4...
ARCHOS 404.. new.. won't turn on or charge
Leave it to charge for 2 hours just in case there isn't enough power for it to boot up properly until it has an initial charge.
Dec 24, 2007 | Archos 404 Digital Media Player
Tomtom GO 920 GPS Receiver Logo
102 people viewed this question
Top Tomtom GPS Experts
LP
k24674
Marvin
Marvin
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
