Question about LG 42PX4DR 42 in. Plasma TV
LG plasma tv
Can a LG plasma tv be repaired. It is about 4 years old.Just switched it on, there was no picture only vertical coloured lines.
  • 1 more comment
  • Anonymous Apr 01, 2008
    SWITCHING THE TV ON AND CAN ONLY SEE LINES GOING DOWN THE SCREEN
  • Anonymous May 19, 2008
    I have vertical color lines, about an inch thick, one blue along right side, and one red, along the left side of the screen. Is this the beginning of the end?? I'v only had TV for 2 1/2 years, and have had no issues before. I still have picture, which still looks good, but have recently seen this vertical lines that now appear permanent. Please advise
  • Anonymous Nov 11, 2008
    I had the same problem this morning when I turned on my TV. It went away after about 30 minutes. Does this mean it is the beginning of the end or could it just be fluke. Needless to say, a a new TV is not in the budget. I have had the TV for 3 years. Is this a common issue with LG only
    or with all plasma TVs?
I had the repair man out today. There is a circuit board in the center that controls the two side ones. There are two smaller circuit boards that then control each side separately. My problem was on the left side but the origin was a faulty main circuit board. He replaced it and it works great. [$600] He said the circuit boards cost the same, whether large main or small side. It only took him about 20 minutes. He said this is a problem with plasma TVs but that in the long run, you save by just getting it fixed rather than buying a new one. He also said that the new plasmas have more problems and are not as well made. He said if I was to replace my older projection TV with a plasma to get the extended warranty, as many years and I could afford, because I would need it. He also said that LG brand is a good brand and the problem is not brand specific. It is found in all brands.
Posted on Nov 16, 2008
So which is it?? more expensive to fix than to buy new or the other way around???
Posted on Sep 04, 2008
Most likely it's the PDP panel wires failure. It won't cost you more to repair then to buy a new one.
Posted on Apr 28, 2008
  • 106 Answers
Most likely it's the PDP panel failure. It may cost you more to repair then to buy a new one.
Posted on Jan 19, 2008
SOURCE:
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
Tv is about 4 years old. Suddenly developed two
Your plasma screen is made up of 1080 verticle lines and now a few of these lines are not working. This is the screen itself and needs replacing.
May 22, 2010 | Samsung HP-T4254 42 in. Plasma Television
Gas keeps going is it worth fixing or is a new one better
I assume you mean that your screen is showing signs of stress 7 the picture quality is suffering. This would mean a replacement screen is needed & as this is very costly then it is more economical to buy a new TV instead.
Dec 01, 2009 | LG 50PG6000 50 in. HD-Ready Plasma TV
NEC px-42vp4g/s 42in.plasma monitor PDP:np42b3mf01...
I have the same problem with vertical coloured lines on my NEC PX-42VP4G/S. The photo only shows a black background just so it's easier to see the lines in the photo but normally the picture is OK except for the vertical lines which aren't always in the same place.
If anyone can advise on exactly what I need to replace then I would be very grateful.
Regards, Simon.
Apr 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
42" LG Plasma with 4" vertical lines at each end
LG service is non- existent . The only solution that I can suggest is "Give a wide berh to LG products. Dont ever touch any"
Mar 07, 2008 | LG 42PX5D 42 in. Plasma HDTV
LG PLASMA TV WITH COLOURED LINES OVER SCREEN
If the Video (Picture/Pix) is gone but you can hear the Audio (sound), then it could mean the YSUS PCB Assembly is gone/kaput/finish. Can replace the PCB, not repair the PCB due to timing circuitry involve. Cost maybe roughly $500 depending where you located. The PCB is located on the left hand side of your TV when you are facing the back (Back open). Might find 3-4 brown flex membrane connecting to the plasma panel. The PCB has a silver or black aluminum heatsink (big) on it.
Good Luck.
Dec 22, 2007 | LG 42PX5D 42 in. Plasma HDTV
Daewoo 42 Plasma - Model DT4280NH
I have a samsung 42 in plasma television which is three years old, it has a blue flickering light to the right of the television, sometimes can see some at the top in the middle, hope you can help with this problem, is it repairable.
Sep 02, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
LG 42PX4DR 42 in. Plasma TV Logo
517 people viewed this question
Ekse
RONALD CARTER JR
