Question about LG 42LC2D 42 in. LCD HDTV
42 in LG LCD TV turns off by itself
After turning on my LG 42 in LCD tv the unit turns off inr 7-9 seconds! no sleeper set no auto off
  • 11 more comments
  • krinpit Feb 17, 2008
    Same problem here. I rang LG and they said that it will have to go for a service. How did you resolve your problem?
  • LGturned off Mar 18, 2008
    sleeper set has never been turned on...rechecked it just in case...checked the plug in all its connections...the tv just turned off and wont turn back on...computer and dvd is running from the same outlet... help
  • bertphil Mar 18, 2008
    We have also an LG TV 21 inches, just this morning our turned on the TV it just secons it turned off itself. So tried to check the outlet but has no problem, I tried to plug in the TV and it light a second then turned off. What is the prolem? please we need help.
  • Anonymous Jul 22, 2008
    Same problem with ours. I am curious what you had to do to fix it and how much did it cost. It appears to be a widespread issue from reviewing other sites.
  • Tracelini Jul 22, 2008
    We have the same problem with our LG 50" Plasma. Turns off within seconds of turning on. Thought it might be wrong cable connector, but can't seem to figure out. Any thoughts? We're calling for service.
  • Anonymous Jul 25, 2008
    I have the same problem with my LG LC37D. It just started this week but does not happen every time, I was able to watch TV for 2 hrs yesterday, but I am worried to watch anymore, I don't want to ruin it for good.
  • smcreynolds Aug 25, 2008
    My flat screen has a problem . It goes blank and no sound a pictures comes back on in a few seconds goes back off and has a ghost on the left side of the screen goes off again and in a few seconds the picture comes back on again. It does this a few times then the screen goes blank.
  • a415guy Sep 11, 2008
    We just hooked up Verizon Fios Hi Def this morning (9-10-08) to our 1 week old 42" LG 1080p. The off and on problem did not start until the HD cable and all the channels tuned in.. Now, it cuts off and on for the first 3-5 minutes. After a few minutes the problem goes away. Its like something has to get warmed up or the HD is searching for a channel.
  • Anonymous Sep 12, 2008
    I have the same problem with my LG 42" LCD anyone found a solution???
  • Anonymous Sep 14, 2008
    same deal, mine turns on and off, called lg, they said to get it serviced... its brand new!
  • Anonymous Dec 15, 2008
    turn on off on off then went off never come back on
  • mikolajczykg
    mikolajczykg Feb 27, 2013
    vacuum the dust out of it.
  • mikolajczykg
    Take off the back panel and vacuum the dust out. Mine has not had a problem since I did this.
Found that TV started switching off by itself. Would try to come on..green light blinked for 2-3 seconds, tv came on (with picture and sound) for 1 or 2 seconds and then it would turn itself off. Found that the issue is with one channel only. If you are facing this issue....try quickly changing the channel the moment it comes on. You can do it either with remote or with the TV buttons directly. also in the same logic, if this is still happening, try changing the source to another (rgb-pc, av1, av2 etc). Basically change it from whatever input it is on currently, if changing the channels does not work. My symptom was that the tv made a loud 'TIK' 'TAK' sound which is louder than normal.
Posted on Mar 17, 2010
How do you do a master reset
Posted on Jan 05, 2010
My 50 inch LG had this problem after a power outage. Called LG and tried the reset, but it did not work. What I did was turn on all the electronics attached to the tv, dvd player, satellite receiver, WII, Apple tv and then started hitting the input button which would take the tv from standby mode (red light) to on mode (green light) for about 2 seconds. As I flipped through the inputs finally the tv's green light stayed on as the tv was trying to reset and acquire the signal. When the green line came on I started using the remotes for the other electronics and then the tv acquired the signal from the satellite receiver and reset. Started working perfectly again.
Tony in Tennessee
Posted on Aug 30, 2009
  • Michael Drivas
    Michael Drivas Jul 22, 2017
    Bad capacitors as bad venting number one cause... My 50 inch requires me to put a fan on the back and it works fine but one day I'm certain it will go before it's time due to cheap parts...
    Problem Solver:
  • 5 Answers
Try doing a master rest on the TV, should help the problem. GS
Posted on Nov 07, 2009
Change the power cord. had the same problem with my 50" LG. switched power cords and problem solved!
Posted on Jul 01, 2009
  • Licktee May 05, 2011
    My 50" LG plasma was Turing itself off after about 5 seconds but would turn back on when I tried. I replaced the power cord after reading this post and it was fixed immediately! Thanks $1000 worth!
Unplug everything then unscrew the back panel . Clean the dust off the mother board and wherever you see dust then unplug anything that can be unplugged then plug them back in. That should work for 9 to 12 months before you have to do it again. I bought my lg 42" in 09 and it started a year after and it took me 2 years to figure out the solution. Hope it works for you.
Posted on Apr 17, 2013
  • 2 more comments
  • Johan Richards Sep 29, 2013
    Wonderful info. The best, it works!!!!
    You champion!!!
  • Sctanley Harris Oct 21, 2013
    glad to be of service
    if it happens again just repeat the procedure
What the hell it was. same problem for me.. i brought before 4 days only.. I made a mistake by buying this LG TV.
Posted on May 02, 2010
  • Pat Short
    Pat Short Jul 07, 2014
    powe supply
    New Friend:
    Problem Solver:
The wife & I have the 42" SMART TV, model # 42LN5700 & we had this problem for almost 6 months! Bought in Aug 2013; worked fine until Mar 2014; then every few days (or nites) it would do the shut down/start up thingie. It got progressively more common (sometimes several times a nite) at which point we were both ready to toss it out...the only solution seemed to be a good solid swat on the RHS back panel just above the plug in.
(I should mention we also have a 47" LG LED flat panel that we bought in Nov 2010, & it's worked flawlessly from day 1...never a problem)
After reading a few forums like this, & working my way thru YouTube, I removed the back panel using our bed as a "workbench". Simple things first; I made sure the power control panel (RHS) and the motherboard (LHS) -both as viewed from the front, btw- were tightly attached. Every screw need at least a FULL TURN!
My fix was simply tightening the screws that attach the plug-in unit on the power control panel, where the cord plugs into the TV. This receptacle mounts at a 90 degree angle, & was LOOSE & WOBBLING on the board. Since tightening it down, we've had no more problems. Just a bad connection...
Hope this works for someone else...apparently the units assembled in Mexico have some "loose screw" issues!
Posted on Dec 26, 2014
    Master:
  • 505 Answers
I had this problem before on my LG TV. My solution is to put a 12V fan on the tuner board processor powered by AC on the power board. The problem is caused by the TV overheating and the tuner CPU cuts out because it is hot and instructs the power board to shut the tuner board off (although the rest of the TV stays on). You cannot likely get a TV repair man to fix this because the LG TV's do not have adequate heat control other than vent holes on the bottom and top. This is a design flaw that started a class-action lawsuit against LG.
Posted on Dec 12, 2014
    New Friend:
It was the board screws loose that seems to have fixed the issue for me.
Posted on Nov 15, 2018
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • LG Expert
  • 158 Answers
Check your power board
Posted on Sep 03, 2015
    New Friend:
Same Prob. LG 42" turning on and off. Took off back and tightened eight screws, 4 on each board, problem fixed!!!!
Posted on Jun 21, 2015
    New Friend:
This is madness!! Try getting a Mirror TV
Posted on Oct 06, 2011
LG replaced our 50" plasma tv. repairman could not fix the problem. took a while, but we finally have a new tv. thank god for warranties!!!
Posted on Oct 13, 2008
My LG 50 turns on all the time by itself.
Posted on Aug 21, 2008
  • 1 more comment
  • 9895445163 Aug 31, 2011
    my lg 32 inc ld460 model also has the problem of of turning off by itself,sometimes it will automatically turns on back,but after few minutes it goes off,,i have tried of changinging the electricity wall plug,inputs such as laptop etc
    and i tried a factory reset ,,but no use at all
    the lg service guys are not responding ,,i have called them more than 1 20 times...
    anybody please help me................
    any method for master reset?????????????????
  • ggood82
    ggood82 Mar 13, 2013
    Hi all , My 55inch Led Lg is also turning off after 20 minutes or so and resetting itself ... After trying all sorts of things i have now realised it is the internet connection that is causing it to turn off . I unplugged the cat 5 connection as it was wired and the tv stayed on as normal . I tried to also use WIFI and when i did the TV switched off after 20 mins . I have now put the wrong password in WIFI settings to ensure it doesnt connect online and the tv has run perfectly for 2 weeks . We also swapped the TV over to a new one and this was still the cause when we plugged the internet in
  • Ice6250@gmail.com May 10, 2016
    I just bought mine from Craigslist. Go figure I'm having an issue. Lol. Anyway, it's turning off and on. I read that it may be a relay. I hear the"click" noise when it happens. And that was mentioned as a symptom to the relay being the problem. It's inconsistent. 10 minutes straight, then 3 times back to back and then nothing. Then out of the blue again. How plausible is it that it may be the relay? if so, how do I go about fixing it (I'm pretty mechanically inclined), cost, good place to buy parts, etc. Thanks. Pat from New Jersey
SOURCE:
It shuts off 2 seconds after i power on.
Several possibilities but most common seems to be power supply defect or poor connection. Check these resources. Note that other Youtubes that may address the problem are also accessible from the youtube link.
LG Smart TV Keeps Turning Off then On Again
Lg Du 42px12x shuts down fix
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
May 06, 2016 | LG 42LG50 42-Inch 1080p LCD HDTV
Why does my Indignia television turn on by itself in the middle of the day or night?
Check ur tv menu make sure ur tv is it not on a timer setting.And Sleeper mode is not on like 30,60,120.Turn off the tv timer if it on,and the sleeper mode should be off too.
Jun 18, 2011 | Insignia 19 in. Widescreen Flat-Panel LCD...
New installation, can't get anything on the screen except message: power only V.3.08.8
With your set turned on, press exit or return on your LG remote. The white screen should go away and you will still see power only. Now turn off the TV and wait a few seconds. Turn your TV on and you should be in business.
Apr 27, 2011 | LG 42LC2D 42 in. LCD HDTV
TV will not power off and volume now does not work - volume stuck on current setting
My TV done this one week ago. I unplugged it for 10 seconds and then plugged it back in. Turned it on and it worked fine. Guess it reset itself.
Jan 20, 2011 | LG 42LC2D 42 in. LCD HDTV
PICTURE GOES OFF AFTER A FEW SECONDS. SOUND OF TV
have youtryehave you tried going to menu options and turning off the power save you might try changing the scart cable any interferance will cause the tv to turn of. my little boy often knocks the scart lead on my set an the tv turns itself off when he does this ,. hope this helps good luck
Dec 11, 2010 | LG 42LG30 42 in. LCD HDTV
We have an LG 42lb1dr 42" HDTV LCD TV and all of a
The issue is the main unit board. You can go to www.shopjimmy.com or www.orlandolcd.com they carry good working parts at a good price.
Thank you
Nov 05, 2010 | LG 42LG50 42 in. LCD HDTV
My RCA 42 " LCD Is crazed. i USE THE REMOTE TO TURN IT OFF AND ABOUT A MINUTE OR 2 LATER IT AUTOMATCALLY TURNS ITSELF BACK ON. THE ONLY WAY I CAN KEEP IT OFF IS TO UNPLUG FROM POWER SOURCE. IS THERE A...
Check the sleeper timer is not on like 30,60,120 Mins.Turn the sleeper function off,should work.Not,go in ur tv menu,go to PICTURE,go down to reset the tv Tuner board,the setting will go back to the factory setting.
Jun 18, 2010 | RCA L32WD26D HDTV/DVD Combo
How do I use timer on JVC LT-42P300
For turned OFF enter in the set menu select the sleeper time(15-30...minutes).
For set the turn ON if you do not have the good signal it is imposibile.
Sep 02, 2009 | JVC LT-42X688 42 in. LCD HDTV
LG 42LC2D 42 in. LCD HDTV Logo
40,575 people viewed this question
RONALD CARTER JR
